Radio stations Logos database updates
Full marks for finding the manifest. Suspect it's poor QA.
  • Replies 264
  • Views 142.3k
  • Hello, I wrote to <email address removed> waited a long time, but today I received a response from <email address removed> that: We have considered these new logos in our next update versi
  • MartiniB
    MartiniB
    links in head post have been updated MQB2_Europe_v1.10.66 MQB3_JND_Europe_v1.31.66 MQB3_LGe_Europe_v1.31.66 ICAS3_LGe_Europe_v1.31.66
  • Thanks MartiniB.   The MIB3 (Superb etc) file loaded successfully into my Karoq's MIB3 Amundsen, and seems to have created some of the missing radio logos. (Pity I still haven't got any for
I have Octavia 2024, Mib3.
So is there a way to manually add logos fore certain favorite stations?
I have tried this method from the manual, but the device just doesnt see logo files on the USB.
No, you can't add them manually like older units. Where did you get the manual from, it can't be for your car
Edited by Dave77
Well that was also in Seat manuals. It's those technical writers of old that computer companies use to write like ICL. There is a spec but programmers don't write to the spec so the two  don't tally.
It's the back door into mib units for toolkits in mib2 so management twigged to protect mib3 from hobbyists they had better prevent usb import. That's what is thought. The source of why the technical spec is at variance to the software.
It is for my car. Here is the cover page of the pdf.
They didn't do a re-print. It's whatever newer pdfs say but they may not be right. The issue effects all Vag cars. In the UK missing logos tends to effect the commercial stations more than the BBC. So yes it's a pain for mib3. Phonostar seem to have the license to maintain the logos for Vag via that download. The download isn't available for Seat but is for VW and Skoda. Seat get them over the air, that file is an update but if isn't  "uptodate" it's no good. Its all locked down on encryption signatures. Case of Vag over engineering it since that are frightened of hobbyist programmers that might write better code than them. Petty.
Edited by Tell
pressure of the owners on the producers isn't strong enough 😞
when upload of whole base is safe for Mib3 security
then also single logos upload procedure can be implemented by the same safe method
The latter would be similar to the old online destinations through their website. Probably too lazy for them to implement that. Saying that they pulled the plug on the mib2 support sites in 2020 when mib3 came out apart from navigation map import. Their record isn't good on support once the infotainment unit is changed. Not sure whether "mib4" uses the same files as mib3. I see there is also a range of different mib3 navigation files. Audi / Vw seem to have different ones. Not totally following that area. You see them on the Russian sites.
caught v1.31.50 for Mib3, size and content hugely increased
1,13 GB
previous v1.31.48b had 162 MB
I've tried now to update logos with latest zip file, but update doesn't start at all. I have followed instructions from phonostar.
1,13 GB
Wonder if they have now put Seat in it again. It comes and goes reading a French Seat board. Has those SE markers in it as discussed. Can't beat mib2 🤣.
7zip is the best extraction tool, Vag recommended. Because of the encryption signature any noise in the file or wrong placement in how it's presented and it won't be seen. It's like mib2 high map presentation you have to get it spot on. A lot of posts in the past people were incorrectly presenting the file or it was scrambled by Mac OS. CleanMyDrive if using a Mac. They place a character sequence in each line which blows the signature encryption. These are just stumbling block in file preparation which stop the upload being seen.
Distinct lack of SE in those, so as per normal, Seat / Cupra gets the roar deal over VW and Škoda.
Hi friends.  Updated my superb FL RSDB
and finally appears my wished station  logo.
Great.
Just update mine to v1.31.50, used 7-zip this time. No logos for Radio X or Absolute stations yet  :sadsmile:
Edited by Dave77
Any radio logo files for octavia mk4 vrs touchscreen?
The database radio file uploaded ?... but they just haven't added the logos in ?. It's not that it didn't read the database ?.
It read the file and said it was completed. I guess it doesn't have those logos in the database
El 11/12/2024 a las 13:32, Vegarz dijo:
Hola amigos. Actualizé mi magnífico FL RSDB
y ultimente aparece el logo de mi estación deseada.
Genial.
Vaya, ¿puedes explicarme cómo lo hiciste? Llevo mucho tiempo intentando poner el logo de RockFm.
Gracias
Simply.
Go to first post of this tread and download the update that you need.
Done,
Thank very much  @MartiniB @vegarz
Edited by Xurde
I've downloaded the latest database. My Audi Harman MQB2 high wont accept it via SD update. I get a conflict error. Can I and rename stl.1vw to VW_STL_DB.sqlite and update via more incredible bash tool as it needs a sqlite file?
Cheers fellas.
You could try opening it in SQLite and if it looked like the other one. Failing that you'd have to deploy your SQL skills in a query 😏. Been a while.
Presume bash tool isn't fussy about signatures and checksums else you'd be working those out.
As far as mib2 high is concerned I just download the missing graphic to in fill a station which you can do... think you can do the same. The bash update must overwrite the built in ones of the mib2 high incanarnation on Audi. Mib3 as we know are stuffed on this except using these files which don't work on Seat... the poor relative of the Vag family. Under resourced.
I have just renamed it and opened it with sqlite. It does indeed look like the same file format the older version so I'll try and update it via MIB
Updated successfully using MIB and renaming the file to sqlite
