Update to Version 1969
Hi! Does anyone still have and could share a link to SW 1896?
  • Replies 534
  • Views 145.2k
  • The update files for the update can be found here, credit to @Giannis20 for providing these. megaload link:  https://mega.nz/file/994DUTwL key to access file on Mega  u22UzB0cTcz6sutX
  • I haven’t tried exFAT unfortunately and not sure why I decided to format to ntfs after fat32 didn’t work:) Well it sounds like both ntfs and exfat are supported and importantly the update didn’t brick
  • New Download Links:   I have uploaded the file to a couple of my cloud services, and no password is required. Give them a try and let me know if they are working okay for you.  The firs
That's one you're probably going to have to get a dealer to do.
Hi guys!
Can update to the last version in this case?
10 minutes ago, dinamo1975 said:
Hi guys!
No.
So, what are the supported versions that I need to install to get to the latest version?
Thx!
Thx!
First 1896 after that you can go to 1941 or to latest
Can you please mention the LINK to 1896 + 1941?
Best regards!
for the 1869
Edited by Giannis20
3 minutes ago, Giannis20 said:
for the 1869
I read all the posts but I don't find a LINK to 1869 version...
Edited by dinamo1975
Best regards!
You can go straight from 1896 to 1985 (the latest) I did so myself
I know that but at this moment, my car has sw 1803
I know that, but what I was getting at is you don't have to go to 1941, or 1969 for that matter in between...
Above, another user ("vran22") suggested that I should first update to v1896 and then I could barely update to v 1985.
Yes first you need to have at least 1896 before going to 1941 or 1969 or 1985..
OK, I understand that, but the car doesn't update to v1896... that's why I was thinking of doing it myself but I can't find this version to download. (v1896)
I dont know if anybody posted version 1896 for download.
I know for 1941 and 1985.
successfully upgrade from 1969.
Thanks a lot!
Hello Guys , I am new here , and I would like to kindly ask you  of support, I have 1805 version of FW and need to upgrade it highest version ,  My infotainment is frozen a lot and after first start , i have problem with parking asistent or front asistent.
Thank you
  • 5 weeks later...
Hi everyone,
I can confirm that I have successfully updated from 1803 to 1941 in one go, with no issues. And then from 1941 to the latest 1985. Used the latest instructions in this topic, with the engine running and hood open. The update hase solved my problem with android auto connection of the latest Samsung phone. Thanks for information you share here! Hope it helps :)
Samsung S24? Witch  problems? Where can I download latest version please?
Yes, Samsung S24, after the first connection AA works fine, but after infotainment system turns off completely, it doesn't see the phone at all. Only reset to factory settings helped, but only till the next turn off.
I have downloaded 1985 here, posted at the previous page. There is also a special thread for 1985 in this forum
Octavia Infotainment Update Version 1985
https://drive.usercontent.google.com/download?id=1SV2ZyzWSfl2-txiI-CagSGEnvhgOnPLd&export=download&authuser=0
Edited by VV25
I have Samsung S24 Ultra and 1969 version and AA always work without problems.
Actually, I had this issue with galaxy s24 before any update, with the old version 1803. This was the reason for update. Maybe all 19XX versions are fixed for this issue
Someone can confirm I can update with 1985 posted here in the link? Thanks
Yes you can update
