Today
Remap options for 2023 Mk4 vRS TDI
Pretty sure there’s a lot more than two companies. I know Darkside do it, although it is an additional £350 charge. Not sure if they unlock it in-house or outsource it - you’d have to ask them.
Regular False Tyre Pressure Faults
I actually saw a video on this the other day. I want to say it was TikTok. I’ll have a look - but IIRC the guy was saying that the system was giving false alarms, but that both the ABS sensor and ring were absolutely fine!
Anyone had success requesting a key code to get spare key cut?
What he said. You can get it done by specialists, but the people I know charge basically the same as the dealer anyway. It’s one thing to replicate the physical key blade profile, and another to do the RFID chip.
the rear hatch window normally has heated elements, i.e. demister. i don't know if this was an option in some markets or specs.
Garage Labour Time Per Job....
Hi Alasdair I'm still waiting to get a full response addressing my query from the garage. Apparently they're looking into it. In the meantime, thank you for your comments. Just to expand on the points you've mentioned. Possible Problems? - On failing the MOT the garage rang to give me the bad news and gave me a quote for replacing both CV boots. I presume at that stage, no attempt would had been made to remove the old CV boots so it wouldn't be known if the job might turn out to be anything other than straight forward. I presume the job did turn out to be pretty straightforward as my invoice shows no difference in the time taken and charged for replacing the CV boot on each side. As per my opening post, the garage didn't mention any difficulties were encountered carrying out the job, either on the day of the repair or since. Number of hours Charged? - The invoice shows 2.50 hours labour charge for each side (Not Both). Travel Time Included? - There wouldn't have been any as the MOT, service and the repairs were all carried out at the same workshop location. Road Test? - I'm not sure. However, since collecting the car it is pulling to the near side and the steering wheel is off centre, neither of which occurred prior to the day. I presume both these things would have been picked up during a road test. I've advised the garage of this in my email queering the invoice price/hours charged. Alignment? - I wasn't informed by the garage of alignment being carried out, and there is no mention of it on the invoice. As mentioned, the car is now pulling to the nearside. Anyway, thank you for your interest Alasdair. I'll update on here when I have more news.
Yesterday
staticshock joined the community
Octavia 2l tdi cupa egr cooler bypass what is needed and how to do it ?
Good effort getting them both from the top! Coolant use has slowed a bit since doing the bypass, but still having to top it up, might just be air purging out. I did run the coolant bleed though so should have got most of it out, but didn’t vacuum fill it or anything
Is yours a hatch? Does the hatch not have a heated rear screen?!
Top mount
I’ll send you a message with link to the manuals which may help.
Did you find out what was up with yours ? I managed doing the bypass from top of engine but deffo needed a 21 or 22mm connector because the coolant hoses where a bit slack on the 19mm but I fastened them on with jubilee clips really tight so hopefully will hold .
I just finished work and the windscreen was frozen…. 1st time using the heated windscreen… wish the rear screen had the same system
Photography Thread
- Amundsen MIB1 Firmware update finally completed - MSTD_EU_SK_P6230 MU0490
Top mount
Made an error when I removed old top mount. I didn't notice which way it was located in regards to the tab where the bearing locates
Top mount
You bolt a piece of 4x2 wood to the anti roll bar drop link connection and jack it up to compress the spring. If you have spring compressors then I assume you can just compress the spring in situ to the same effect. The secret seems to be the positioning of the expansion tool and how you wiggle the brake disc.
Top mount
Thankfully have use of another vehicle. I undone pinch bolt , compressed spring and man handled the shock out. Whats the 4x2 method? As will be doing the other side.
Top mount
I hope you have alternative transport! This is always my fear when doing a job such as this; not having sufficient parts to get back on the road and no way of getting them! Did you split the hub to take the strut out or use the 4x2 method to compress the spring?
oil pressure problem
Oil got expensive recently thanks to Trump.
thsts tomorws job £51 FOR A OIL AND FILTER OUCH
When you say high mileage, how high?
Constant creaking / rattling from the doors of my Kodiaq Mk2
ŠKODA now want to keep my car for 48rs and reapply the grease then keep it in the workshop overnight to see if the noise returns. I have told them that I can guarantee it won’t return after 24rs as the grease resolves the issue until it wears off. Again I’m keen to know if anyone who has this issue has any paint treatments applied. I’m going to have to let them keep my car for 2 days which is a total waste of time.
Filter will do that for you, it doesn't mean there's no debris anywhere. See how it is after oil and filter change.
Ben23 started following Skoda Karoq
oil looks clean
Top mount
So finally got around to tackling the top mount. Total ball ache. Then noticed what you guys have mentioned. A jagged end to the spring. Was at the very top. Just out of site. I did hit a big pot hole a couple of weeks ago . But was on the near side.
mvasev joined the community
kzolee joined the community
Hi everyone, I'd like to share my experience with the same door creaking issue on my Skoda Kodiaq Mk2, manufactured in July 2025 and purchased new in January 2026. I've been investigating this problem for some time, and my observations are very similar to those reported by @Marcinek and @minimumcharacters. Here is what I've found: The creaking noise disappears when the windows are slightly lowered, even without opening them significantly. Cleaning the upper flocked/felt door seals noticeably reduces the noise, although this does not appear to be a permanent solution. I also experimented with masking tape at the contact area between the upper seal and the bodywork, which helped me investigate the source of the noise. My Skoda dealer adjusted the door strikers, but this did not conclusively eliminate the creaking. Based on these observations, I strongly suspect that the noise is caused by friction between the upper flocked door seals and the painted bodywork, particularly when the body and door frames flex slightly during driving. My impression is that the pressure exerted by the fully closed windows may also play a role, since lowering them immediately changes the noise. I believe this is primarily a seal-to-body contact issue rather than a loose component inside the door. I haven't yet found a confirmed permanent solution. In my opinion, the most promising approach would be to investigate the seal material, the contact surface and the door alignment rather than relying exclusively on lubricants. I would be interested to know whether anyone has achieved a lasting solution through seal replacement, anti-friction tape or a specific adjustment recommended by Skoda. Thanks to everyone who has shared their findings. This thread has been very helpful in understanding the problem.
