  2. Gateway Change, but it is CP Master, you need a Skoda Partner with odis online You will need to re-enable the functions; otherwise, certain features will not work. Do not forget the coding and the dataset.
  3. Ahh. Yeah. Good point! 😳 The gateway is a 5Q0 so it’s a no-no then? Could the gateway be changed JR or would this create issues with other systems?
  4. Today
  5. Yesterday my 69 kodiaq went into.limp mode but i managed to get it home , noticed smoke coming from the bonnet and upon lifting the bonnet I discovered this mess when I unclipped the heat cover .. day before I replaced the dpf pressure sensor with a new bosch one but the car was still coming up with the sensor error .. any ideas guys ? Thanks in advance
  6. Since the introduction of the MQB platform with Immo 5A, there is no longer a "key code" in the traditional sense. When you order a replacement key, it is requested based on your VIN; it comes directly from the factory rather than a central warehouse. The key blade is manufactured by a supplier to match your specific lock—as recorded in the vehicle documentation—and the electronic component is programmed with your VIN. This allows the dealership to officially register (teach in) the key to your vehicle. Alternatively, you could purchase a key from a source like AliExpress and find a skilled CNC operator or locksmith capable of accurately cutting the blank (note that there are two different versions of the key blade). Furthermore, the CS (Component Security) code—which is essential for preparing the key and registering it to your vehicle—resides within the instrument cluster, which acts as the "Immo Master." The tools required for this process typically cost around €1,000.
  7. Yesterday
  8. Hi guys been having trouble with my kodiaq 2.0 tdi 69 plate , then yesterday I managed to get home whilst in limp mode and discovered this damage to my newly fitted dpf pressure sensor .. Just kept flagging up a dpf sensor fault even when it was replaced.. do you have to code the sensor to the car at all ? Just ordered replacement parts from a scrapper of the same year kodiaq ... my car in the last couple of weeks seemed to be in constant regen mode .. any advice would be greatly appreciated..
  9. tommyboy68 started following Melted Mess !
  10. There's probably a huge margin and lots of labour in swapping an engine. Does no-one repair engines anymore?
  11. They did check the hub on both sides and said they looked okay. Checked them for misallignment or warping.... frankly I would like to think you were right as thats a lot cheaper repair than what im starting to think....
  12. Brkicn joined the community
  13. Hub damaged due to heavy kerbing at some point in its life - they should have checked hub face runout after the first replacement discs "went bad".
  14. Hello all. New to the forum, and relatively new to skoda... I have a really puzzling issue i hope someone can help with I have a 2015 fabia mk3 1.4 diesel. Purchased last year. About 6 months ago the brakes developed a pulsation... as if they were snatching rather than biting, so lurching on braking. Took to garage. Warped front discs. Replaced... and about a month later the pulsation returned... same warped discs. Replaced again... now on the 3rd set and its back again. So further investigation undertaken at garage. They ran the car under braking and managed to get the brake temp up to 90 degrees, but brakes were still releasing as they should with no binding. Important... also NO warning or fault lights on the dash So according to the mechanic that eliminates calipers and master cylinder. They do have a vague theory but they are really unsure and ive already had someone else say they can't be right so rather than put it in people's heads ill let people throw there own thoughts at me first. I really hope this can be sorted as I do like the car and would rather not let it go. Any help would be greatly appreciated
  15. JackMaines joined the community
  16. steve2602 joined the community
  17. That seems to be a popular "fixing" price, my mate got that cost/quote when he took his 2019 VW T-Roc 1.5TSI DADA DSG in to get its DSG sorted - he turned it down and sent it to WBAC instead!
  18. ian-inhome replied to ian-inhome's topic in Skoda Karoq
    I followed the instructions in the app to generate a key,then it said to copy it and paste it, only problem is I couldn't find out where to paste it. Google suggested suggested using Google assistant app but that has now changed to Gemini and you can't use that.
  19. Tasior joined the community
  20. Appreciate this is a bit of a bump of an old thread, but I wanted to register to say thank you for this - it's been driving me nuts for years and your post helped me "fix" it in half an hour. Cheers!
  21. molop joined the community
  22. Just an update. It was the seat belt tensioner. It must have been bedding in as it stopped making the winding noise after a week or so. Now you can just feel it tensioning up but no noise 👍
  23. Thank you that is very interesting to hear! I hate to appear defeatist, but I have a health condition and after the battle ensued, and continued for a few weeks I had a horrible flare up. I have to put my health before a car V dealer battle, but at the same time I have no protection if the limp mode happens again. The dealer said please don't hesitate to come back if you have any more trouble..... however I have no faith that they would be willing to try properly to find an answer. It would need to be before march when the manufacturer guarantee expires.
  24. Hi all. I took my V5 into Western Skoda of Dunfermline today. The service department kindly printed off any service history they had on the car as promised, but the parts adviser said he couldn't get me the key code to enable another key to be cut. Was he just being difficult? Can I try another garage or is it just impossible if I don't have the black tag with the number?
  25. Transport Pack, which gives you an inverter, variable boot floor, net programme & other bits
  26. You are correct that taking on Skoda and a dealership is too stressful but don’t sell yourself short. I do think that the forum is of little help for such situations. The car is not safe for you and it’s not your fault. I suspect that for someone who commutes longer distances and lives in an area with free moving traffic the limp mode issue may never surface. Anybody who has experienced limp mode in heavy traffic would not downplay the seriousness of the matter. There's a lack of empathy by some on here. I live close to a major motorway junction and the motorway is frequently gridlocked. There is heavy traffic almost everywhere. The school run is horrendous and the roads are constantly subject to temporary traffic lights so potholes and small sections can be repaired. The Fabia 4 could achieve 40mph if I averaged over 16mph on a short run. In practice that rarely happens and not because I’m choosing to crawl along in low gears. I would move faster on an electric scooter. A few weeks without the limp mode issue is not grounds for thinking all is well. We are still very uncomfortable driving our Fabia despite the last such breakdown being months ago. We so hope that the software update has removed the problem. Realistically, nobody connected with Skoda is interested. I'd go further and say that our local dealership doesn't understand much about their cars. Sales staff are far more competent than the service dept. The question is what to replace your car with. Not easy to decide but I am sure that cars are no longer built well or with reliability in mind. They are too complicated. I’d keep well away from cars in the VAG group which includes Skoda. Maybe something like the Honda Jazz with a petrol engine is worth a look? Honda no longer produce the petrol version of the Jazz which now has a hybrid power train. The Jazz doesn’t come in 57 varieties like the cars in the VAG lineup. It's basically just one Jazz. Any issues will have been identified and sorted by Honda - unlike with Skoda.
  27. On 14 November I made an online order for Mud Flaps. In SKODA packaging. Borská 3040/47a, 301 00 Plzeň 3, Czechia https://www.skoda-parts.com/ Box arrived today. Good service. Very easy. And most important, much cheaper than UK dealers. As test run worked OK, I've ordered a few more bits.
  28. Hey there, I've just bought a 2018 Rapid Spaceback with a 5Q0035874C headunit. I was hoping to get CarPlay set up on it but am not entirely sure whether the unit is compatible or whether my current USB port would support wired CarPlay. Has anyone had any success in getting it working with this specific headunit model? It's running SW train version MST2_EU_SK_ZR_P0468T and has 2 SD card slots. Have had a look for whether I can find out the USB port model based on the VIN but no luck. VIN is <Removed by Briskoda admin> Thanks in advance!
  29. The speed to De-ice, defrost & heat an EV,s interior is my favourite thing about EV,s. Also their ability in winter conditions when the appropriate tyres are fitted.
  30. Good news, I've solved the problem! Following an internet search and an AI list of suggestions, I cleaned the boot catch (which didn't look dirty but I cleaned it anyway) and the boot seal (which had some moisture and leaves). Then I turned on the engine and magic! - the flashing and chiming had stopped. I've driven a few miles today with no recurrence.
  31. Could you advise how you did it please? Some simple steps and what problems you hit please?
