- Are drum brakes rear axles different to disk brakes?
JD52 started following Abs module long coding
mick25 started following Abs module long coding
Hi guys i accidently reset the abs module on my 2018 skoda octavia vrs 2.0 tdi to factory reset using my obdeleven with out doing a back up first and now the long code is all zero's and i have alot of flashing lights on the dash which wont clear what can i do to restore the abs module thanks
337 started following Google Maps etc. in Virtual Cockpit
aronisk started following Off-road and snow modes
I have the 4x4 tdi version, and I was wondering, what are the main changes in car s behavior, when these modes are involved...it seems that manual is not that clear, and also minor differences apply depending on production period...mine is 5/25, so production period is 11/24 -6/25...
sumoevo8 started following Hellos and Goodbyes
sumoevo8 joined the community
2012 to 2019 Superb Refresh
Be aware there are 3 “280” engines: EA888.3 pre GPF CJXA 280 EA888.3 GPF DNUA 272 EA888.4 GPF DNFE 280 Won’t tell the difference in standard form but the Gen4 is revised and has bigger turbo. For an off the shelf (RacingLine/Revo/APRetc) remap it also turns 280 into c.400 because of the big turbo. No impact on economy - I can get the same results as numskull on a longer run.
- Yesterday
- Apparent stalling
scotthugh3s started following Apparent stalling
Superb Matrix Headlight
Hope so, 1 owner car L&K wagon 4x4 DNUA <40K miles
Priming can be done w/o VCDS. Just with setting contact ON and OFF (w/o starting the engine) several times. 10s ON / 15s OFF. Then start the engine and rev at 15000rpm for 20-30s to get rid of potential bubbles.... I've done this on 6 TDI engines over the last 20 years. No problem at all.
Cybertruck!
Cybertruck killed Did Elmo get to Mars yet 🤣 https://apnews.com/article/cybertruck-cybercab-discontinued-musk-sales-6938a145d365f8e31b26bb9c45264b24?
Thank you, it is a good car you will like it!
So you should be able to get going by swapping over parts OR wiring. I have no experiance of the new Superb lights, but hopefully I will start learning if the one I see next weekend is the right car. Good luck!!
So the “new” ones are used ones. (Perfect condition, from the outside.) So the “new” ones are built in, with the factory control module( i bought it with it.). I tried with the old one but the symptoms are the same sadly. But if i just unplug it and plug the connector to my old one, that one works perfectly. I mean here that the old one do everything except the new one which is not doing the calibrate and not leveling.
In the UK we call it CP Component protection. Your dealer would have been able to release it IF it had CP using ODIS I would have thought using function enabling. Did your lights come with new modules or did you swap them from your old lights?
Škoda Approved Used – should outstanding scheduled maintenance have been completed before sale?
I purchased my current Octavia, a year ago under Skodas approved used scheme, yes the servicing was up to date to Skodas service schedule, I checked, prior to buying. Although their oil change was 1/4 of a litre low on the max level of the dipstick, as I checked it when I arrived home, cold & hot read. I just topped it up. My car has just been in again for it's last Skoda service (a year later), as the supplying dealer offered me a one off free MOT with them. Plus they collected & dropped my car off for free. Again I checked my oil level, again a 1/4 of a litre down from the maximum level, may just be standard practice. I've just paid them £230 for the minor service, inc the free mot. Next year, I'll be using an independent. I also purchased a previous Octavia, within the past, different dealership, under their approved used scheme. This time they deceived me with regards to it's previous service history, it was missing one service, they promised me that it had a fsh, just their systems were down, couldn't print off a copy. After I purchased it, I again chased the service history up with them, eventually I received a printed copy, 1 service missing. Fortunately with a bit of detective work, I tracked the missing service down to an independent, checking it's mot history. I rung the independent, explained the situation, they emailed me proof of the service. Regarding your original question about missing servicing items, I'm not surprised. I've been buying used cars for a very long time, generally speaking dealerships just want the sale, often cut corners to achieve it. I'd first ring the service manager up within the supplying dealership first, explain that the car is not fully serviced, would he rectify this for free? As it's an approved car. If he won't, I'd then possibly take it up with Skoda directly, put in an official complaint in writing, stating that you'd expect an approved car to be fully up to date with it's servicing, what resolve you are expecting, await their response. Or another option, as you are within the 30 day rejection period, look to reject the car with the supplying dealership, due to it not being serviced up to a satisfactory standard & it being faulty, not fit for purpose, as the start & stop system is not working at all. Again you'd need to put this in writing to the dealership, send it recorded, so that you have proof of posting. Regards to your S/S, sounds like your battery is getting down a bit, may need replacing, coding in. I've never found any S/S system to fully work 100% of the time, but if I were to use it (I don't), I'd expect it to work at least 50% of the time. All really depends how strongly you feel about this, how far you want to take it. I've always found the friendly option, ringing them directly, first, the least stress option. I purchased my current Octavia locally from a Skoda dealer, not for better service, just closer to go back to within the event I had an issue.
I am going to watch it tomorrow. What if it is have component defense?
Mattw924 joined the community
2013 1.2 TSI exhaust heat shield removal
Many thanks for that, very much appreciated. I'll give it a go in the next day or so 🤞
- Front Wishbone nuts just spinning
https://youtu.be/3MglpJZ2bTs?si=7ulA3bTA7_AJ8eO1 You can see the wires I'm talking about when he removes a module to check the seal. But obviously for the motor instead.
- Hey everyone
Check oil level warning - level seems fine
- Hey everyone
DDX_unknown started following Hey everyone
Yes. The solid wires drawn in the CFD for the headlight are actually normal wires. So it will have a live an earth and a feedback to the module.
DDX_unknown joined the community
- Škoda Approved Used – should outstanding scheduled maintenance have been completed before sale?
Do you mean that wire that one is it inside the headlight?
Its clearly working so I would suggest the feedback signal wire could be broken which (if it is) will prevent the basic settings from setting correctly.
