  2. Deny joined the community
  3. Update: All of the problems have persisted and some new ones have emerged: under downhill braking with a full load (three people plus luggage) the whole car was vibrating the infotainment system is very buggy, often freezing or generating random characters when entering an address into the SatNav or sometimes activating a different random function when pressing an icon on the menu "Stop/Start system error" messages occurring on the dash display The Stop/Start often doesn't even attempt to activate (with the crossed-out A icon showing on the dash display) Cruise control often surges/brakes (feels like I've changed down to 2nd and briefly got massive engine braking) Tacho display showing nonsense gear suggestions, e.g. 6 -> 1 @rum4mo I've bought a 12V plug-in voltmeter. I tested it against a multi-meter on an external power supply and in the car against a multi-meter connected directly to the battery terminals - both times it was within 0.1V, so I know it is accurate. When the car has been sitting for a few hours or overnight, the voltage is ~ 11.7-11.9V and after a journey - even a long motorway run - it is usually ~ 12.3-12.4V. This seems a bit low to me. The car has been back to the dealer twice now. The second time I discussed all of the issues in detail with the Workshop Controller when booking the car in. The first time they said they had "updated and reset all of the software" and the second time they said they had "done some more software updates". To be fair, the brakes are a lot better, but the other problems are just the same. I'm considering my next steps. Should I... buy an OBD2 scanner - is this likely to show anything useful? take the car to my local garage, where I have had previous vehicles serviced for many years, and get an independent assessment go back to the dealer and try to get some redress under the Consumer Rights Act 2015, i.e. a replacement vehicle or a partial refund be done with it and sell the car Anyone got any wisdom to share? Thanks, Andrew
  4. Today
  5. 2022 VRS estate.Mostly solid.Occasional glitches , usually phone connection issues.Had the entertainment screen replaced under warranty this year after it developed a dead spot. Apart from that no trouble whatsoever.
  6. This is interesting. Maybe Jaguar does have a plan after all? It is a shame if traditional buyers are effectively frozen out by this divisive design, but as I said many times before, nobody was buying Jaguars. I'm also taking this article with a pinch of salt, but there's no smoke without fire, I reckon... https://www.motor1.com/news/811711/jaguar-ev-50000-people-interested/
  7. Replaced the DSG T-stat a second time with an oem VAG. Problem is still not fixed. Just thought i got a bad dsg stat in the first place. Havent put in the hotter 92c mhale T-stat yet. That will be the next step. Will keep you posted.
  8. Yesterday
  9. Hi JN12 Need to find a fabulous independent myself. Sounds like you are a problem solver. Useful asset to all
  10. Hortiguy started following Hello at last!
  11. My head unit (central screen) is completely black and not responding at all. The screen between dials on instrument panel is however, fine. Have I bricked the head unit, or does it just need a re-code? I did take it out, as needed to clean the space behind it. Not wanting it to dangle, I did disconnect it. Recently changed the battery, but that was weeks ago, and didn't cause any problems. I've found that the cabin filter only has foam on two sides, not four, so dirt was taking the easy route instead of going *through* the filter 🙄 I have ODBII, or would i need VCDS?
  12. I suspect you’re not talking bol*x Bollix :)
  13. It does indeed replacing the factory intake system. On the TDI. The EA288 and EA888 are totally different engines. The actual intake duct is probably very similar, but the airboxes themselves are not. You can, from what I've seen, potentially modify the TSI intake to fit the TDI, although I've no idea why you wouldn't just get a TSI intake to begin with. There's no shortage of Racingline/Forge examples.
  14. Just to add - the jacking point on the sill is actually only for emergency use. The car isn't designed to be lifted here, if at all possible. Absolutely get a decent jack pad.
  15. Well, this thread was a bit of a rollercoaster. I've given my car all it needs, and more, yet it keeps throwing up issues. I've now got an issue with the steering system (probably the rack, unless the drop links have decided to suddenly go), and having just spent over £800 getting some jacking point damage on the sills fixed, it''s pretty gutting. What are you thinking of next?
  16. Thanks Norman. I appreciate the comment. Not how I wanted to bow out of 16 years of driving Skodas but there we go.
  17. Fingers crossed. Interesting - on old BMW E36 forums it used to be: Car idling rough - camshaft position sensor Car idling rough and stalling - crankshaft position sensor.
  18. Hi, the below shows what you described and with a nice chunk of wood to ensure you won’t damage anything I would say this seems fine.
  19. Cyco started following Axle stand location
  20. AutoKULTUR joined the community
  21. And what do you expect after 65,000 miles without an oil and filter change? The manufacturer claims 80,000 miles without service—lol, that’s advice for the gullible. As a rule, transmission fluid in these models should be changed every 60,000 km (35,000 miles). Sure, the service schedule says engine oil gets changed every two years... lol. Of course, the engine will last as long as the warranty holds, but afterwards—you'll be left wondering, "What was I thinking?" For RS models—and especially TDI models—the engine oil should be changed every 10,000 km, and the transmission is a whole other story. RS models are driven much harder and pushed to the limit—you really need to change the transmission fluid every 35,000 miles.
  22. Use my part number in ebay with word genuine, and you get item number 277634634997 New genuine at about half price compared with dealership if you use the coupon.
  23. maonus joined the community
  24. John202020 joined the community
  25. so do you have myskoda app? when you register you have all the brochures there .
  26. I had 2 rs tsi 2021 and 2022 year. the problem is not so much in the software, as the problem is in the mib, those devices were assembled with old processors where procurement was in chaos due to covid. there were no chips, so they used old chips. only octaves from November 2023 use new chips and a stronger processor. that with old models is a lottery.
  27. Does it mostly happen when it's wet outside?
  28. Thanks for the help chaps. But wow why on earth is getting the right fuel filter so blooming complicated Trouble is the previous owner old boy said he replaced the fuel filter a couple of years back but didn’t log the service or the part used hence yes I could see what filter is currently fitted by removing it but I don’t really know if he’s fitted the correct filter anyway as there’s so many choices even some only 1mm different on height etc.
  29. Good afternoon Gent's, Need a bit of advice. I have a Octavia iV 2021. I have installed the My Skoda app, i activate the 3 months free subscription for Care Connect and Infotainment Online, but i can't find all the options from those sections. For example the auxiliary heater, or charging location, not showing at all on the home page. Any advice helps. Thank you in advance
  30. https://www.facebook.com/reel/2854277254907176 Here you can see a short video showing the condition of the transmission fluid in a Peugeot—a vehicle for which the manufacturer claims the fluid never needs changing. Lol, they’re just waiting for you to have to replace the mechatronics unit—and a repair like that costs between €1,800 and €6,000 here in Croatia. Bon appétit!
  31. lol..By all means, stick to what the dealers tell you. Any competent automatic transmission specialist will tell you when the fluid and filter need changing. You could change the fluid at 80,000 miles for the DQ381, but you can't see the actual condition of the fluid inside the transmission. It is madness to change the fluid without changing the filter; such fluid will likely damage the mechatronics unit, causing the transmission to jerk and making gear shifts unsmooth. The transmission normally shifts up after 1,800 RPM; if it is shifting at 1,900 or 2,000 RPM, you have likely already reached the 60,000-mile mark. This device changes the oil in 40 minutes; the housing allows you to see the oil change process and the condition of the oil being replaced. You buy a £30,000 car, yet you can't change the oil after four years.😇
