Past hour
Cairus's Leon FR
This isn’t just a simple coding change. In short, the firmware is being expanded—for example, to allow for image extraction. Additionally, a different firmware needs to be flashed onto control unit 65. The sensors themselves are already capable of this from the factory.
- Fabia 2024 SE comfort mpi fault
ABS fault codes in VCDS but no warning light.
Could be that some rust has been dislodged as you said and created code. Think the ABS light comes on if there are multiple faults during driving and doesnt automaticly come on if its just a random fault. Alasdair
Alasdair1 started following ABS fault codes in VCDS but no warning light.
Coolant level warning mystery
Not sure re shorting out but from memory I think you should have 5-6v on one wire and the other is earth. You could check if theres voltage using multimeter on +ve wire and use chassis as earth then check continuity of other wire to chassis. Could be as said broken wire or dry solder joint somewhere. Also check the temp guage isnt fluctuating as I think its the same warning for engine overheating. Could be a bad G62 coolant temp sensor. Alasdair
Apple CarPlay adapter recommendations
Give the cheapest a go and see how it goes. That was my logic. Bought the cheapest one I could find on AliExpress that looked like it would be functional and never had cause to try anything else! It’s also small enough that the cover closes over the top of it so it’s hidden away.
Thank you. I’m going to do a bit more research before I jump on another dongle I think. Be lucky knowing me, if I’ve decided on one by next summer. If I start research on the different versions of each device and their pros and cons it will go on until I decide they’re all horrendous and keep using my cable. Hate my brain sometimes. 😩
A 2024 Fabia SE Comfort in its most 'basic' form had a naturally-aspirated (ie. non-turbocharged) 1.0litre 80PS MPI (Multi Point Injection) motor with 5-speed manual gearbox (DSG automatic transmission was NOT an option). All SE Comfort motors were 3-cylinder with 1.0litre capacity and there were four motor/transmission options: 80PS MPI - naturally-aspirated, 5-speed manual gearbox only 95PS TSI - turbocharged, 5-speed manual gearbox only 110PS TSI - turbo-charged, 6-speed manual gearbox OR 7-speed DSG automatic transmission The SE Comfort model was subsequently renamed SE Edition but the motor/transmission 'choice structure' remains the same, with the only obvious difference being that the SE Edition's most powerful motor has 116PS instead of 110PS. There's a contemporary review here The Mud Life MagazineReview: 2024 Škoda Fabia Hatch SE ComfortNow in its fourth generation the Fabia has sharper styling, modern onboard tech and more safety kit…
DGW started following Bixenon Headlights auto-adjustment problem
Serhii87 joined the community
namok joined the community
JD52 started following Advise on wheels
Today
Advise on wheels
Does anyone know if Octavia Mk3 alloy 17" wheels fit a 2012 Scout? Cheers., Jeff.
jazzyjeff started following Advise on wheels
Cairus's Leon FR
And is this entirely new code or unlocking a feature used on other VAG somewhere?
- Cairus's Leon FR
My (very) extensive - and costly I may add - experience with multiple very modded "project cars" - a word that now I hate - is that, after you make that very long list, besides rating them my cost, you also try to frame them by sections and consider priority to things which cane be stand alone changes. See, usually you plan a series of things which are together, so you work on one section of the car only (say engine, or interior, and such). Then you start "while I am at it ..." and this is the absolute killer. For example, I had to stop the Defender (which I've own for little time) for a simple coolant replacement, which extended into a check/replacement of most hoses, which opened up option for removal of the EGR cooling, which translated into the EGR removal, which .... the list continues! At the end something that was supposed to take a couple of days, took weeks, adding frustration as I am tired of having a thing and not use it. I cut it short - some things will remain for the future, but they are not essential as the basic maintenance/repair. So my advice is to look critically at each thing you want to make, and try to keep it as stand-alone as possible, to is a start it-do it-finish it matter. Whenever possible, of course!
CZR07 joined the community
Cairus's Leon FR
This is seriously cool ... where does the temp info comes from? Sensors themselves?
Front wiper blades on 2026 SEL
Thanks Derek, my wife said they were getting noisy so I said I need to change them to Bosch as I've done on the TT.
Yesterday
scottymcstig joined the community
- Boot latch
Warrior193 started following Boot latch
Bet
Not sure for the Mk4 - but the drains should be visible at either side of the scuttle. NB. you may have to remove a layer of dirt to reveal the drain openings, they are fairly small.
Xurde started following Constant app updates
Don’t worry. More AliExpress items en route!
Bet
That could be the problem if it's anything like the stupid design of my Audi TT. With that, if the scuttle drain gets blocked the water overflows the scuttle and has run into the car. With you having the car facing uphill then this is more likely to happen as there is less of a barrier to stop the water running in. If the drains are clear you should see water running out under the car if you run a hose into the scuttle area.
oooooooohhhhhhh im telling...... you're cheating on Aliexpress 🤪
Amundsen MIB2 Firmware Update
Thanks , but links in this doesn't works.
I found this tutorial on YouTube really helped me uplift mine.
Belky joined the community
johnche joined the community
good evening everybody . I am looking for software to my octavia mk3 2018 . below is soft already on unit and i assume MST2_EU_SK_ZR_P0480T is next one . thanks
edwdom started following Amundsen MIB2 Firmware Update
- Coolant level warning mystery
Passenger side mirror won’t unfold
Replacement mirror unit installed and now all working again with no error codes.
1.4 TDi Spluttering and Loss of Power When Up to Temp
Fix thermostat and sender and see. At least the car should run at right temp. If the symptoms happen after I would, get it scanned to see if there are any stored codes that could point you in a rough direction. Had a quick google and wiring loom for injectors I think goes under rocker cover/cylinderhead area and due to the heat and oil is prone to failing over time and usually when engine hot. Alasdair
