  2. It's possibly the so-called safety system warning you of some danger it imagined.
  3. I was driving peacefully along when a loud chiming started, along with a flashing white image of the car body which seems to be highlighting the rear window. This was 5 minutes into a journey. My fuel range was showing 210 km. I stopped and turned off and checked that all the doors and boot were closed. They were. I started up again, same thing. Any suggestions? Thank you.
  4. Just scanned for fault codes and got a few come up. It feels like it tried to move a bit but is stuck. Will try to take cap off tomorrow and see if I can see why it’s stuck or anything obvious.
  5. They would only be used on snow, have had chains before so no difference . Car and hence tyres are new and don’t intend to buy a new set of tyres yet hence looking at socks in case they are needed. Last street we lived on had speed humps on a hill and when the snow froze they were e impassible unless you were going so fast that it was dangerous.
  6. LongDitton joined the community
  7. The Toyota and Hyundai will have had closed pressurised coolant loops with a separate system. one for the petrol system and the other for the power control unit, inverter / converter. The hybrid battery with Toyota and Hyundai uses cabin air cooling.
  8. VCP
    Tom1214u replied to andyvee's topic in Diagnostics & VCDS
    Apologies, but please someone contact me or here in regards VCP Already posted about it. Apologies if twice still learning website etc. It will be much appreciated for any help Thank you
  9. Tom1214u started following VCP
  10. Today
  11. You cannot do it by long coding. It has to be done with datasets. Soft and hard reset restarts the modules. It says bad elm obd module when it can’t read or write data. Doesn’t mean your device is bad. Have a look at this post. If it doesn’t work it cannot be done.
  12. Please anyone can get me in touch with vcp locally to Hereford ( happy to travel 1hr or so) Seen Ludlow but can’t message Thank you
  13. Hi Everyone I've not a clue when it comes to mechanics, including how long a job should take, so may I ask for your help please. In a nutshell my Fabia Combi failed the MOT test on the following 2 defects: 1)Repair Immediately (major defect) Offside Front Outer CV boot - split or insecure, no longer prevents the ingress of dirt. 2)Repair as soon as possible (minor defect) Nearside Front CV boot - leaking not split. I had the required work to replace both CV boots carried out on the day of the MOT by the garage (an independent business) who then re-tested the car which it passed with no advisories. I paid the bill at the time, however after studying it, I'm currently querying the invoice with the garage and it would be useful if anyone can advise me how long, time wise, it should have taken a trained mechanic, in a fully kitted out workshop to replace both the CV boots. I wasn't advised at the time that any difficulties had been encountered, nor have I since, so I presume it was a straightforward replacement of both CV boots. Asking the question on AI it suggests 1 to 2 hours total (roughly 30-60 minutes per side). Is that about right or should I take those times with a pinch of salt? Thanks in advance for any help.
  14. Also meaning of soft/hard reset and what will it change please
  15. @Binx1310 do you know what that means? If I change as on this photo you reckon will I be able to do successful coding of closing via button inside?
  16. Yes able do other coding but not all if that make sesne. Wonder why sayings faulty etc especially both of them genuine too. Very frustrating…
  17. Hi. My car’s steering box was replaced by the service. I know that if steering box is replaced calibration should be done. But the tech said that there is no need to claibrate. Can you tell me whether calibration should be done or not. If needed which procedure should be applied that is to say static calibration or dynamic calibration?
  18. I've had toyota and hyundai hybrids in the past and don't remember a sealed system before, but then again I may not have need to have looked,I wouldn't attempt to completely refill the system but a simple top up was easy
  19. Welcome to the forum. I fail to understand VAGs logic in sealing the engine coolant expansion vessel - I can (sort of) understand it if it was for the sealed battery cooling system on a full EV, where there could be a significant fire or explosion risk from an overheating traction battery. Does the much smaller traction battery of a Hybrid use the IC engine cooling circuit for cooling ?
  20. Thanks @skomaz but it's not that, as the numbers appear even when there are no unread messages. Sometimes it shows the Bluetooth symbol but the most common is the digit 1. The digit 2 is the one that's seen the least. Baffling. FP
  21. As Petrol Dave says you can swap the ign/live feed even on OK cars, but a dash cam will not drain a car battery if it is fully charged, either put a charger on it or have a 50 mile or so drive to charge it
  22. Adjutant joined the community
  23. I had to google 'axial bearing', which appears to be the crankshaft thrust washers. Have they established how much play there is and if there is any damage to the crankshaft?
  24. There’s two different fuses depending on side of car, but yeah it’s not that unfortunately
  25. I have seen this before. It seems to be very hit and miss for coding this. I tried exactly the same as I did on @AL2772 's car using my module and app and it just kept saying bad OBD2 module. I think it is very dependent on your OEM dataset version. Does carscanner and your module work for other coding ok?
  26. use solution posted one post above, v1.31.70 loads with it
  27. JStyles joined the community
  28. I installed Bevinsee LED headlight bulbs to replace the bixenons and they are great. Passed MOT no issue too. Highly recommend them. https://www.ebay.co.uk/itm/298188805629 £28 a set with the coupon code currently. But both sides you have to jack up car, take wheel off and arch liner out to get to them. I managed to get one bulb out from above but couldnt get the new one back in.
  29. Hello @Gizmo Will it be the only one able to sort coding? Any links recommendation please? My 2 obd2 not able to do and showing faulty wondering cos car not able to do no matter what as showings my diagnostic tool faulty Please read my new respond in here Are you able if so change dataset and what with?
  30. Yep I would concur with that. The new fog bulbs are looking much more like the main beams now, if not a bit brighter / whiter. Close up inspection of the original Bi-Xenon main headlight inner lenses shows that they do look a bit cloudy. Need a clean perhaps? I'm wondering whether I should consider changing the Bi-Xenon's for LED's or, leave well alone? Looks like changing the drivers side is fairly straight forward but the passenger side involves removing front wheel & wheel arch liner to get to the back of the headlamp unit as under bonnet access is very tight😒. I think I will leave alone until the weather gets a bit warmer. Not the time of year to be messing about in the cold on my drive.🥶 For reference below is a Ali Express link for the replacement Fog LED bulbs I used. Fairly cheap at £9 but so far so good. The car is in for it's 8th MOT today @71.5k🤞 https://www.aliexpress.com/item/1005006840794986.html?spm=a2g0o.tm1000027143.appPushSupportRecommend.3.71cc6a77QFScA6&gps-id=appPushSupportRecommend&scm=1007.67346.516855.0&scm_id=1007.67346.516855.0&scm-url=1007.67346.516855.0&pvid=0fd4b796-753d-4d2d-8e4d-cf5800ec5718&_t=gps-id%3AappPushSupportRecommend%2Cscm-url%3A1007.67346.516855.0%2Cpvid%3A0fd4b796-753d-4d2d-8e4d-cf5800ec5718%2Ctpp_buckets%3A668%232846%238110%231995&pdp_ext_f=%7B%22order%22%3A%2271%22%2C%22eval%22%3A%221%22%2C%22sceneId%22%3A%2257346%22%2C%22fromPage%22%3A%22recommend%22%7D&pdp_npi=6%40dis%21GBP%218.13%218.13%21%21%2110.37%2110.37%21%402103849717951015968395942e0ef6%2112000038479188887%21rec%21UK%213413154159%21XZ%211%210%21n_tag%3A-29919%3Bd%3Addd822d5%3Bm03_new_user%3A-29895&utparam-url=scene%3AappPushSupportRecommend%7Cquery_from%3A%7Cx_object_id%3A1005006840794986%7C_p_origin_prod%3A
  31. Doesn't dim as its been replaced with standard glass when I broke it but will give the heating a go. The puddle light that side still works. Will try the adjustment too. I would have thought if it was fuse would both mirrors be affected?
