Clutch Question
Well, there's your answer (sort of); you have a different car, and it would be more of a surprise if the clutch felt the same as on your old smoker.
Clutch Question
I've not driven your car, but my experience is that a high clutch is quite normal on hydraulic clutch VAG cars.
Fabia mk4 launch 6pm today (4th May) with launch details
Never in my case. If I'm wandering it's a warning that I need a break.
OFF!
Is Dacia the new Skoda?
Octavia has a higher residual?
First impressions
10% optimistic on the consumption. That's not unusual, although the available range mode is usually pretty accurate.
lowering Scala - Eibach Pro-Kit springs
Well, I don't know what spec your car is, because you're not told us. But changing the ride height will need the suspension adjusting.
Starting problem when car is warm
Load test on the battery; most places will do that for free if they get the business should you need a replacement. Or maybe the CTS.
Back to factory ecu map?
It's got cop springs, cop shocks, cop motor...
What is thi ssensor for, and normal resistance of others?
He's maybe right; at least some VAG diesels do have a MAF. I don't know about the SDi though.
Creaking rear suspension, loud bang.
It's common on anything with a disc handbrake.
Ok, this is further than usual, but had the car been lying in the wet overnight? If so, it may just be that the handbrake had stuck on. As to the creaking, that may be dry rear suspension bushes. You could try putting a few drops of brake fluid on them if that's better in wet conditions.
Off side rear door won’t open nor will window
Almost certainly the door wiring, given that neither the window nor the lock solenoid works.
Instrument panel
Trip computer in mode [1] maybe?
- Fabia PAS fault
- Skoda/VAG independents in the Glasgow area ... recommendations.
Oil pressure light
KenONeill replied to mikefelicia's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanSo we're clear, checking the oil level is quick, cheap and might work. @Wino identifies one switch failure mode: there's another one where a carbon particle gets into the the switch, and the fix for both is a new oil pressure switch.
help - Caliper Parts.
I'm not aware of Lucas calipers being standard on the front of a VAG of this period. The standard calipers with have either FSIII or DS3 cast into the outer face.
Felicia 1.3i lower hose
Also @mikefelicia - I agree you need to fix the oil leak first, because that's what's scrapped your hose, but you will need to replace this hose before it bursts.
Oil pressure light
KenONeill replied to mikefelicia's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanFirst check the oil level.
Water in box section
Well, there is this stuff called "silica gel" that will help...
Think my plate has been cloned?
For instance, ask CalMac when they last carried a vehicle with that registration on any of the outer Isles services that require booking.
Replacement Front Springs for Combi Sportline
Well, from this screen I clicked Body "Vehicle Front" and got suspension springs, not gas struts for the tailgate.
Wiper relay clicking.
As a general observation, relays do click when they operate.
Black smoke, poor acceleration in my SDI
More likely one or more worn injectors. But I don't know that, I only think it's possible.
