Everything posted by pab567
New USB connection
Nope, I don't have any PM from you
New USB connection
PM me VIN and I will check details
Columbus constantly lagging / resetting itself / other odd issues
probably your NAND becomes overloaded and requires re-formatting. Yes, you burn it as an image on CD-R.
- Update MST2 / caplay
As you can see, part number of your unit is 3T0035680E with which I can agree I will send you link to download firmware 5238 so you can have your unit upgraded just pls note after the upgrade you will need to load maps too.
Because in 2012 suffix should be definitely higher that "B"
Upgrading Infotainment System To Get Android Auto
Link to MEN2_EU_SKGPx_P0080L_8755 sent in PM. Unfortunately I don;yt know any CarPlay and Android Auto activator for it.
PM sent
Firmware 6276 source
Sent in PM
Is there an update to Infotainment System (5Q0035842A / H24) newer than 0241?
Link to download MST2_EU_SK_ZR_P0253T sent in PM
- Bolero MIB1 Update Help Please!
Download link sent in PM. You will need to re-install maps after upgrade.
Amundsen MIB STD2 infotainment system with Android in Superb II
As you have unit without navigation then unfortunately unit must be open and soldered to install MIB STD2 Toolbox, it can NOT be done via SD.
Firmware update
@moldaguus there is no SD card solution for your unit - it works ONLY for OEM sat nav units (Amundsen) and you have non-nav unit (Bolero) which requires soldering. If you are interested pls let me know - although I must have it on my bench in Poland. @Gleni69 I sent a download link to 0253 in PM. 1. format SD (best max 32GB) under FAT32 2. unpack to root (metainfo2.txt and all the folders must be placed directly on SD, not in any folder) 3. insert SD card into the slot 4. enter Service Menu (long press MENU button)
Car Not Activated
Unfortunately I am not able to help in this case
Part number and current SW version of your infortainment unit?
Skoda Octavia MK3 Smartlink Issue
Link to MST2_EU_SK_ZR_P0253T sent in PM
Pls share VIN (in PM) so I can check details of your Columbus as in 2012 it should definitely not be 3T0035680B.
- Playing audiobook CDs
- MIB2/Apple CarPlay upgrade
Software upgrade message on Columbus screen and a flat battery.
Need part mumber of your Columbus first - remove it and check on thr label, something like 3TO O45 680 C
