pab567
FREEDOMTech
Everything posted by pab567
  1. You have integrated unit (Swing) and what you linked as just a display unit for Bolero main unit. It wil lnot work with your current unit. Pls share your VIN to check what is the model number of your unit.
  2. You old unit (6V0035871B) is a combination of main unit and display unit. What you bought (6V0919604B) is just a display unit. To have it working, you also need main unit and special harness to extend current one and connect new units. What is the reason for changing?
  3. It depends on the BT module type you install.
  4. The question is what do you mean by MIB2 and MIB2.5. My definition of MIB2.5 - Columbus 5650350xx units, with 9.2" display (touch buttons, no knobs). Yours in MIB2 Amundsen so you will need to chnage both glove box and display units.
  5. 385 EUR + shipping for Bolero + 6.5" screen + USB 500 EUR + shipping for Amundsen + 6.5" screen + USB 670 EUR + shipping for Amundsen + 9" pre-lift screen 5E0919606 + USB In MIB2 units you can have Performance Monitor / Sport menu unlocked, depending on your ECU it can display water temperature, oil temperature, boost and some other gauges (3 gauges per screen).
  6. If you woul dlike to have CD playback then you either have to switch to Columbus (MIB2 or MIB2.5) or VW / SEAT unit, equivalent to Bolero, as they are equipped with CD drive. What is the information you want to display on OBG gauge?
  7. Confirmed - you have Amundsen MIB1 unit 5E0035864m display unit 5E0919605D, USB port 5Q0035726B and fortunately no CANTON sound system. You can install one of four different glove box units: - MIB2 Bolero - MIB2 Amundsen - MIB2 Columbus - MIB2.5 Columbus You also need to replace display unit: - for MIB2 Bolero you can use either 6.5" model number 5E0919605H or 8" model number 5E0919605N - for MIB2 Amundsen and MIB2 Columbus you can use listed above display as well as 6.5" model number 5E0919605J, 8" model number 5E0919606, 8" model number 5E0919605M - for MIB2.5 Columbus the only display unit that works is 5E0919606D The price range is from 385 EUR (Bolero + 6.5" screen + USB) up to 1050 EUR (Columbus MIB2.5 + 9.2" screen + USB ). Shipping not included (approx 25 EUR). The question is what is your budget and which of listed below features are "must have": 1. Video playback from DVD, USB, SD 2. CD playback 3. OEM navigation 4. displaying OEM maps na Virtual Cluster (Active Info Display).
  8. @Nile6661 possible, requires exchange of glove box unit, display unit, USB and, if you have CANTON sound system, also power amplifier. Pls share your VIN for details.
  9. @varooom no need to be sorry, it only proves who are the ones following this forum
  10. 1078804 - Left Rear Parking Aid Sensor
  11. Nope, as bluetooth is protected with FEC/SWaP code and unfortunately I don't know amyoe who can patch MIB1 Bolero. The solution is to replace with MIB2 as they can be patched. If you are interested pls contact me on PM.
  12. There is no update for your unit, you already have the latest firmware.
  13. @Gman1978 easy job - you have simplified Bolero model number 5Q0035820. The easiest way is to have it replaced with full version of Bolero, model number 5Q0035842x or 565035842, or, if you want OEM navigation as well, with Amundsen 5Q0035874x or 565035874 (x - any letter A, B or C). I can deliver any of mentioned above units in P&P version, if you are interested pls contact me on PM.
  14. Unfortunately, I do confirm, I don't know anybody who can rework this unit and indeed, official activation is NOT possible. The only solution I know is to replace with MIB2 Bolero, Amundsen or Columbus.
  15. Nothing is impossible. Pls share your VIN.
  16. It's determined by glove box unit coding, not by the screen itself, so you can go on
  17. Pls post model number of your BT module and your phone.
  18. Wiring - you miss a pair of cable for left channel between BT module and radio.
  19. Have you burn new firmware onto CD or DVD?
  20. Same HW, same SW (04xx), same features...
