ords
Everything posted by ords
  1. Be careful what you wish for.
  2. Posted in the wrong section then.
  3. I thought the bonnet release was on the same side regardless of RHD orLHD. If so why two different part no's?
  4. I do seem to remember seeing that warning, but as mine always reminds me not to forget my mobile, maybe it can't display two messages at a time.
  5. Mine is set to auto lock, which as @Warrior193says can be disabled in the settings menu. I do not get any message when it locks. Are you saying that the windows cannot be operated when the doors lock? My handbrake is not tight.
  6. What engine do you have?
  7. Are the fans running when you're sensing the engine is hotter than normal? That would probably indicate it's doing a regeneration. Are you checking with engine on or off? If fitted does the heating work?
  8. The a/c may just need re-charging with gas. How long have you had the car?
  9. I've only got one hook, so I assume it works for both ends as I've never used it.
  10. Does the door(s) open display on the MFD work?
  11. @smecscan you make a recording of the sound?
  12. Be careful if they're one directional tyres.
  13. There is a breather pipe somewhere. Maybe that's got blocked.
  14. Auto is for ease of driving. Why would you want to keep shifting from D to N and back to D all the time? I use stop start all the time, so at least I'm doing a little bit to help pollution levels.
  15. Were both oils changed?
  16. The Octavia setup is exaxctly the same. If only all maintenance jobs were this easy. I soaked mine in vinegar for a few days and then blew and sucked a few times and it cleared the nozzle.
  17. What engine do you have?
  18. Get the battery and alternator checked out first. What engine do you have?
  19. You may find a solution above.
