ords
Everything posted by ords
  1. Probably too late now, but why didn't you get a charge test done first? Has the new battery been coded into the system so it knows there is a new battery i
  2. I don't know about any fault codes.
  3. This was covered a few days ago. With all the doors locked hold down the boot only button for a few seconds and the boot should "pop" If it does, then you know the fuse is ok and the switch in the lock is probably at fault.
  4. In first gear and clutch depressed, can you start the engine or does it jump forward?
  5. What engine and model do you have?
  6. What engine do you have?
  7. It can't re-lock itself. Needs manual downwards pressure to close it, then it will lock. Important not to leave the keys in it.
  8. I did this and it popped. After 10 yrs of ownership I didn't know it did that. Thanks for that.
  9. Any sludge in and around the oil filler cap?
  10. Ok. All this time i've just pressed the button and released it it at once.
  11. Yes. I haven't tried lifting the lid without pressing the button as it just comes to hand naturally to press the button and raise the lid. I will try it and see what happens.
  12. With the car locked the boot switch will unlock the boot only. Take care not to leave the key in the car as the boot will lock as soon as you close it, although I think the delay time can be extended with coding.
  13. On mine it only unlocks the boot, it doesn't "pop", I have to physically open it with the handle.
  14. See the last post in this link
  15. That would make sense as the digital display was working.
  16. On the 1st page of this forum, 4th topic down > owners + workshop manual. On the 1st page there is a link to download the manual. Lane assist starts on page 146.
  17. This from the manual. "The strength of the steering movement can be activated/deactivated in the Infotainment » operating instructions for Infotainment, chapter Setting vehicle systems (CAR button)."
  18. Why does it work with the front jets? Mine doesn't.
  19. Does the digital display work?
