Everything posted by ords
Great difficulty to do a simple job of checking a fuse.
There are also youtube videos
The rear 12v socket is on the same circuit. Check that has power or not.
Škoda Octavia MK III TDI - Overheating after coolant flush
Look inside and see if you can see the silicate bag.
Rear window heating
Mine stays on constantly when in use. Doesn't seem normal. Why would you want a distracting flashing light?
DPFs for Dummies
You're right, I've never had that happen.
Coil Light Flashing… possible causes?
How many miles?
DPFs for Dummies
This is of interest to me, why are you asking if it's DSG?
Cold heater
There are quite a few threads on this subject.
Low battery warning Key fob
I'd be asking how they knew about the other keys which weren't with the car.
Advice on DSG 7 speed gear box
Mines done 60,000 with no problems at all. Had the software and oil recall done, that's all.
No ignition lights on dashboard display.
You could try disconnecting the battery for a while and see if anything resets its self when reconnected.
Why are you worried?
Wading depth
You beat me to it. I've been watching a lot of those videos lately.
No power steering - Potential new rack??
You need vcd's. Start/stop maybe working because the battery has enough charge in it at the moment.
Without re-coding, the system will assume it still has the old battery and keep the same charging characteristics. It should learn over time that there is a new battery, but in the meantime who knows what faults that could throw up. It's just one thing less to worry about.
Make sure they haven't forgotten to re-code the new battery.
Get it scanned for fault codes. Could be something as simple as a fuse or relay.
Maintenance list to keep car long time
If it ain't broke don't fix it. You don't usually get a sudden, total failure of the pump. You'll probably start to notice a slight water loss or the heating not working properly. Then's the time to investigate. No guarantee that if you replace the pump it won't fail in a short time. One think you should check is if the water expansion tank has the wording "mit silikat" stamped on it. If it has, the silica bag inside the tank is prone to rupture and the contents will block your heater matrix which would need repacing. Many people have removed the bag and then change the water every 4 or 5 years. Quite a few threads on this subject.
2016 - VRS, Drivers side seat belt replacement?
https://vwts.ru/skoda/octavia3/skoda-octavia-3-body-repairs-interior-eng.pdf
Radiator fans @ start - normal?
My light never comes on.
Infotainment screen - Touch has gone awry - replacement cost / advice?
Which unit do you have & software version?
Infotainment stopped
Would the screens have component protection?
Octavia 2017 front indicator light replacement?
- Seized Glow Plug - Cylinder 4
Running fine or not, it will fail the MOT if the light is on.- Road noise solutions?
Many threads such as this one. - Seized Glow Plug - Cylinder 4
