Everything posted by ords
Rear mud guards
- Skoda all-in
The link worked for me.- Spare wheel tool kit/holder
Seems to be missing a few pieces- Part number??
There are a few for sale on eBay- Clip on passengers mat
If you're lucky, something may start to rattle or come loose and then you can see if that clip should be holding that piece.- Numpty causes mayhem with infotainment system.
Why do I bother?- Numpty causes mayhem with infotainment system.
Probably a long shot ,but have you told the car its got a new battery?- Morning engine warm for TDI
What will the actual coolant temperature be then if it's not 90c as indicated?- Morning engine warm for TDI
Of course it will. Just take a longer time depending on outside temperature- Octavia estate road noise
The car is very sensitive to road surfaces. There are many threads in this forum on soundproofing. Be thankful you don't have the "booming" problem as well.- 7 speed Automatic
Mines been faultless.- SD card for different part of the world.
Can you tell us what files are on the card?- Weird Combination of Errors 2014 1.6TDI - All appearing within days
Does it go work when you use the buttons on the key fob?- What is included in the spare wheel foam insert?
There's also a wire hook which is used to take off the cover on the rear lights to get to the torx screws securing the lights. It's mentioned in this post.- Octavia boiling
Much more info needed. Was the 50 mile run in slow moving traffic or open road? Is the fan running? What indication do you have that it's boiling? Are the hoses hot or cold? At what level is the water in the expansion tank? Is the heater working, if not, could be pump problem or as e-Roottoot says an airlock- Another surprise message
Someone will have an answer.- Octavia 1.5 tsi ‘20 plate manual
Many threads on this engine. This one is quite comprehensive.- Air Con - Never Getting Cold Issue
See if putting it on the strongest setting in the settings menu makes any difference.- SKODA OCTAVIA MK3 P023A CODE
- Location of fuel filter
Ecomatt came back to you with an answer that time & now xman has given you exactly the same answer.- Location of fuel filter
Seems you asked this question before.- This is probably an old topic. SD card for my vehicle
A picture of the unit in the glovebox may be useful- This is probably an old topic. SD card for my vehicle
If you think it has satnav then there will be a button marked "nav". I don't see one.- Weird Combination of Errors 2014 1.6TDI - All appearing within days
Sorry about that, I mis-read the post.- Weird Combination of Errors 2014 1.6TDI - All appearing within days
The a/c is not like the old system whereby the fan would always run when the compressor was working. - Skoda all-in
