Kenny R
Everything posted by Kenny R
  1. You’d be better comparing the 5 seat/ 7 seat boot space before choosing a spec you don’t really want. Depending on what options you want to add an SE could easily become more expensive than an SEL, and for the slight increase in boot space starting with 7 seats, even though you don’t need them, might be the better option. I ordered a new facelift Kodiaq Sportline last week and delivery is not expected till December.
  2. If you have just purchased and the oil needs topped up, take it back to the dealer and get them to correct.
  3. My diagram as said is an example from a Kodiaq manual, your proper locations will be in your manual.
  4. Power steering is electric, there is no reservoir. All check items should be covered and their locations identified at the end of your owners manual. Similar to this from the Kodiaq manual…..
  5. The figure I had gotten from the Arnold Clark online value my car, was exactly what my local dealer offered last week for my Kodiaq against a new Kodiaq. Its also easy to get a settlement figure for your PCP from Skoda/ VW finance
  6. Best I’ve achieved lately. For a 2.0 Tsi, can’t complain
  7. Stop/ start defaults to on every time you get in and start the car, no matter what drive mode is selected.
  8. Probably due to the fact that it’s not recommended to run recirc mode for long periods.
  9. Is the other key well out of range when you are setting a key.
  10. The manual states otherwise
  11. When you have adjusted seat and mirrors and pressed set and then memory button 1, 2 or 3 do you get the bleep to confirm setting has been stored.
  12. How? As above you don’t need to use the bank transfer method. Use your bank debit or credit card an no surcharges are added you pay the price advertised.
  13. When I paid mine, I used my bank debit card, although the renewal portal said credit card or bank transfer.
  14. Have you tried pushing button D on the bottom of the stalk?
  15. You do know it’s not legal to fill a knowingly leaky ac system. You really need to have a vacuum test done to see if system holds vacuum before filling with the correct weight of gas.
  16. What annual mileage you chose for your PCP has no relevance to what extended warranty you chose.
  17. This might help.. https://youtu.be/y5PuC9TeHfA
  18. 17” wheels fit over the 340mm brake discs fine.
  19. I’ve got 17” Borbet wheels that were supplied from Mr Winter Wheels with my winter tyres. I can honestly say I can’t notice much if any difference in comfort or handling between them and the standard 19” s. I find the standard 19” tyres very comfortable at the correct pressure 2.3-2.4 bar, and I do run the 17” winters at 2.6-2.7 bar.
  20. DSG models do not normally have the steering wheel paddles as standard. According to the latest brochure you need to spec heated steering wheel, which comes as part of a winter pack @ £590 to get the paddles.
  21. I’m not surprised you find it uncomfortable driving that way. Try setting your seat and steering wheel properly and see if it helps. https://www.physiomed.co.uk/uploads/guide/file/21/Physiomed_Sitting_Guide_-_Driving_Digital.pdf
  22. Kenny R replied to vrskeith's topic in Skoda Enyaq
    Only if you have the family package plus, which includes sleep package, folding tables and window blinds
  23. You did drain the diff and not the Haldex. Even so called Skoda technicians get it wrong.
  24. That’s not standard Skoda/Vag as they use the pin type, which are readily available on tinternet.
  25. Could be as simple as a failing battery.
