MartiniB
FREEDOMTech
Everything posted by MartiniB
  1. @Danoid if you can show to dealer some problem with head unit then firmware will be updated free of charge in other case this will be paid procedure try to use this bug https://www.drive2.ru/l/554452378879787927/
  2. front/rear 340/310 both vented for 272/280ps 4x4 310/300 front vented for all rest replaced to Otto Zimmermann -> https://www.briskoda.net/forums/topic/407627-rear-disc-brake-wear/?do=findComment&comment=5306861
  3. @Woodside99 board search -> https://www.briskoda.net/forums/search/?q=rattles orchestra&type=forums_topic&nodes=299
  4. @REMELad a lot of info in post i linked above -> https://www.briskoda.net/forums/topic/426372-rear-passenger-air-vent-part-number/?do=findComment&comment=5332587 @Wino it's developed that way, too many cases
  5. painted rear skirt looks much better -> https://www.briskoda.net/forums/topic/367311-the-superb-iii-picture-thread/page/141/?tab=comments#comment-5570909
  6. @Flashik07 guessing, this picture can be from Amundsen 2.5 not Columbus, Columbus with this 8" screen is Mib2H, Columbus Mib2.5 has 10"
  7. is not necessary to upload both, just latest if You have problems with extract Škoda's zip, then download 7z from VW's server, content is equal -> https://www.briskoda.net/forums/topic/498563-columbus-map-update-2022-mib12-high/?do=findComment&comment=5593575
  8. Smartphone + Waze are tons better than any built in Navigation system
  9. some files now available on VW's servers
  10. my choice too! +1.5% in diameter, 10mm wider and 5mm higher if compare to 215/55r17 https://tiresize.com/comparison/
  11. @Vasariah content of files is identical = cross compatible between VW, Škoda, Seat and MAN check dates which i posted in previous 2022 tread some extractors can't unpack this zips, try another
  12. just seen them installed, can't comment details -> https://www.drive2.ru/l/603139303513546962/
  13. i don't think this is VW's group hierarchy's case, more likely, that is nowadays working style - operation is done, but without going into details 😞
  14. not true, option [Closure] is present, but it's little bit tricky to use while driving
  15. just two: 340/310 both vented for 272/280ps 310/300 front vented for all rest replaced to Otto Zimmermann -> https://www.briskoda.net/forums/topic/407627-rear-disc-brake-wear/?do=findComment&comment=5306861
  16. @NJRJ Sorry, lost in translation 😞 English isn't my tongue
  17. how how does Waze can know about issue, have you sent a report? https://support.google.com/waze/answer/6262574?hl=en#zippy=%2Cmap-issue
  18. Regular updates, loaded them, but i prefer Waze -> https://www.drive2.ru/r/volkswagen/passat_variant/525875521918075305/
  19. online updates for Mib3 head units >= ~2019~
  20. guessing, Swing and Amundsen use Google Translate for this site -> https://www.drive2.com/o/b/540399795643089654/
  21. yes, as @Tellsuggested show us title of your current maps you aren't first who confused what device -> https://www.briskoda.net/forums/topic/469569-what-amundsen-unit-do-i-have/
  22. watch some instruction on Youtube and order new body from Aliexpress
