AGFalco
Everything posted by AGFalco
  1. Check / charge the battery first. 2 - Put the key in the ignition switch and turn on. Thanks. AG Falco
  2. https://www.google.com/search?q=VAG+code+30162+O2+sensor+1+bank+1&rlz=1C1CHBF_en-GBGB917GB917&sourceid=chrome&ie=UTF-8#fpstate=ive&vld=cid:548c014d,vid:eSx5Y6qJwSc Thanks. AG Falco
  3. If it is wheel bearing, try this:- Jack the wheels up, Spin one wheel at a time, Put your hand on the corresponding wheel's road spring and feel for any vibration. Check and compare the fronts to each other, then try the rears. Sometimes you can hear it as well. Thanks. AG Falco
  4. With my Skoda:- To change the call volume you do it while you are having a call. To change the ring volume you do it while someone is calling you. And so on. Thanks. AG Falco
  5. There are two water pumps with this engine. The water pump in the first post is the mechanically driven one on the gearbox side of the engine at the top, not the electrically driven pump in front of the block. What is the problem with yours? Thanks. AG Falco
  6. Yes. So long as their user name and password works. Thanks. AG Falco
  7. I spray paint mine with black no nonsense spray paint:- https://www.screwfix.com/p/no-nonsense-spray-paint-gloss-black-400ml/8591R?tc=MA4&ds_rl=1243321&ds_rl=1241687&ds_rl=1245250&ds_rl=1245250&gclid=Cj0KCQjw9deiBhC1ARIsAHLjR2D5adp-MvmRtc9HwU74D4B65M9ScXKQ2MysuLM_hS9rbsJ5jm47IHAaAk8VEALw_wcB&gclsrc=aw.ds I also have a 2009 Fiat Panda 134K miles with a non rusty rear axle:- https://www.google.com/search?q=fiat+panda+rear+axle+corrosion&rlz=1C1CHBF_en-GBGB917GB917&oq=fiat+panda+rear+axle&aqs=chrome.2.69i57j0i512l2j0i22i30l2j0i15i22i30j0i22i30l4.9561j0j7&sourceid=chrome&ie=UTF-8 Wash all the dirt off, let it dry and spray once a year in the autumn. Cheap and easy. Thanks, AG Falco
  8. What did you do? If anything. Thanks. AG Falco
  9. Super is Standard then. 😒 Standard grade (95 octane) petrol became E10 in Great Britain in September 2021 and in Northern Ireland in November 2022. So 95 RON in the UK is standard petrol. Thanks. AG Falco
  10. I strip / clean and relubricate my brakes every autumn. Did this on my Fabia III the first time at 6 months old. The noise will quieten down, but not disappear. The upside of this yearly maintenance is that my brakes are now just over half worn at 7 years old and 71 K miles. Thanks. AG Falco
  11. Some original Brake pads have a sticky layer on the metal back of the rear brake pads. Removing the pads and cleaning / lubricating them or replacing them and lubricating them / or having a set of brake pads with no stick layer can have this effect:- Only noticeable when you go from forwards to backwards and brake, and / or vice versa. Thanks. AG Falco
  12. Some details PM'd Just the ones that Skoda have. Thanks. AG Falco
  13. Can you PM me the VIN Number. I can check what I can see, won't be very detailed though. Thanks. AG Falco
  14. Yes there are two radiators. Probably need to take the bumper off at least. Thanks. AG Falco
  15. Gelieve in het Engels te posten. Bedankt. AG Falco
  16. No, see my post above about what you need to do. Spark plugs are under coil packs that are under the ( removed ) air filter housing. One electrical clip per coil pack to pop off and then one 10 mm bolt that holds the coil pack down, then pull up gently to remove. Use a small 10mm spark plug / 16 mm Hex socket with a long extension bar to remove spark plugs. I buy my parts from a good local motor factors. Or:- https://www.amazon.co.uk/NGK-96596-96596-Spark-Plug/dp/B00U0ER8A6 Thanks AG Falco
  17. Bolero. Could be an option only on the Amundsen system then? Thanks. AG Falco
  18. Every 4 years. See here for details, posted 26th March 2022:- NGK 96596 were for my 2018 Citigo. Thanks. AG Falco
  19. My 2016 Fabia only has one SD slot. Thanks. AG Falco
  20. So this car hasn't got the SLCS option then. Self Lubricating Chassis System. 😁 I spray paint the subframe/exhaust and other bits every year in the autumn on all my cars. Thanks. AG Falco
  21. In the video it look like the fan is running, ( and knocking against something ). Try looking at the fan with the engine running and the watch what happen when some one else turns the engine off. It could be the fan slowing down. So the car thinks it is too hot an is running the fan to cool it. Can you do a plug in and find live data of what the actual coolant temperature is? Thanks. AG Falco
  22. If it is like mine, you don't have a temperature gauge. Is the engine running too hot? Thanks. AG Falco
  23. No. It can come on if you have the AC running? Yes. Not if it is a mechanically driven pump. Thanks AG Falco
  24. With my Skoda and Android Auto if you connect the phone to the car via a cable the phone will turn the Bluetooth on automatically. Thanks. AG Falco
