Everything posted by AGFalco
Noise from Offside Front Wheel
Brake disk inner shield rusted through where the bolts hold it on to the hub? Thanks, AG Falco
Clunk when changing gears
It would be useful to know which engine and gearbox you have? Thanks AG Falco
Rear reflector replacement
Have you tried to polish the scruffy mark out. A detailing company might have something that will work. Thanks, AG Falco
AC Control Button Repair Skoda Fabia Combi 1.0 TSI Edition
What about using a small permanent black marker like a `sharpie' to cover up the mark. https://www.amazon.co.uk/Sharpie-Permanent-Markers-Fine-Black/dp/B01N9ZIRZY/ref=sr_1_6?crid=FFYVZW8OR8HR&keywords=sharpie+pens&qid=1667331110&qu=eyJxc2MiOiI1LjE1IiwicXNhIjoiNC43MCIsInFzcCI6IjQuNDcifQ%3D%3D&sprefix=sharpie%2Caps%2C78&sr=8-6 Thanks, AG Falco
MKIII Fabia battery type: only EFB?
When charging a Stop / Start EFB / AGM battery you need to:- Use a smart charger and, Connect the Positive to the battery terminal, Connect the Negative to the earthing point on the inner wing. Note that the nut is painted so you need to attach it to the clip at the end of the earthing cable under the nut. See your manual for detail / diagram. Thanks, AG Falco
- Mk3 bushings
- Mk3 bushings
Rhythmic Rumbling
Lots of high speed motorway driving can wear the centre of the tyres quicker. Where as lots of hard cornering can wear the edges of the tyres quicker. Low pressure, alignment out, tyres not rotated would be three reasons. Thanks, AG Falco
Inspection/service question
You can do the first MOT up to a month early, minus 1 day of it's 3rd birthday, if you provide the V5 log book and it will run out on its 4 birthday. So the expiry of the first MOT can depend on when you had it done and if you provided the V5 log book. Thanks AG Falco
Mud flaps ( essential or not necessary?)
^ Also agree with above. ^ North Dorset here, where B roads are the norm. I fitted Skoda mud flaps to both my Fabia and Citigo as soon as I bought them. lt also helps to cut the water spray on faster roads as well, not that there any fast roads around here. Thanks, AG Falco
Fabia 3 2017 1.2 TSI 4 cyl cambelt question
See this post:- Thanks, AG Falco
Citigo added to the family garage.
See this post above. I bought the bits from TPS. ( Trade Part Sales which is a VW owned parts company ) They don't all sell to the general public, try this one:- https://tps.trade/info/centre-finder/tps-chester?postcode=CH1&location=53.2142574,-2.9372378&location_search=0 Thanks, AG Falco
Rhythmic Rumbling
The over inflation does NOT cause the rumbling noise, that comes from the saw tooth inner edge of the ( rear ) tyres. Thanks, AG Falco
Rhythmic Rumbling
Not always. If you don't want this to happen again then use these guidelines. Swap tyres from left to right every 6 months. ( as long as they are not directional tyres). Fit new tyres in pairs to the rear. If the fronts were the worn out ones then swap the older rears to the front also swapping diagonally at the same time. Do you do a lot of longer high speed journeys? Thanks, AG Falco
Automatic Overheat Warning Sign Problem
Please up date us when fixed / solved. Thanks, AG Falco
Try on a VW UP forum for more info:- https://www.google.com/search?q=vw+up+asg+overheating&rlz=1C1CHBF_en-GBGB917GB917&oq=vw+up+asg+overheating&aqs=chrome..69i57j0i546l5.9212j0j7&sourceid=chrome&ie=UTF-8 This won't have charged your battery enough. No. My Citigo recently went on a 500 mile round trip including stints on a motorway with no problem. Thanks, AG Falco
2021 fabia infotainment volume won't go higher then half way
On mine, surround and subwoofer only work with the source being from a phone or an SD card. Thanks, AG Falco
Rhythmic Rumbling
Unless you have directional tyres fitted. Especially on the inside edge of the tyres. Thanks, AG Falco
Updating Swing radio software
😂 Thanks, AG Falco
Washer Not Working
Has the fuse blown again. If so this can be a sign that the pump has blown. Not normally hard. Behind the o-s-f wheel arch inner liner. The one pump does both front and rear washers. It has two water pipes, one for the front and other for the rear. I would try and run power straight to the pump when you can see it, before you take it out. Connecting the power one way should / will make it pump one way. Reversing the wire should / will make it pump the other way. If the pump is working then check the windscreen wash wipe stalk. Thanks, AG Falco
Mine came with an EFB Moll as well and has stop/start. Yes you can fit an AGM but you will want to code the new battery type to the car to change it from EFB to AGM. As above. Thanks, AG Falco
Mk4 Estate electric boot
Just some talcum powder / french chalk is worth a try. Thanks, AG Falco
Rust around fuel filler door
Look here:- And here:- Some part numbers have been superceded. For my 2018 Citigo:- 1S08109879B9 Adaptor lower rear left. The adaptors don't appear on the TPS diagram but is listed. 1S08109889B9 Adaptor lower rear right. The adaptors don't appear on the TPS diagram but is listed. Thanks AG Falco
Tyre Wear - Karoq Sportline 1.5 tsi 2020
FYI. SRI ( Sumitomo Rubber Indistries ) make Falken Tyres. Thanks, AG Falco
Want a Citigo GO
Never made / sold in the UK. Only in the VW UP but with the insurance group higher than my Fabia III TSI with a 1.2 Lt engine not the 1.0 in the UP. Thanks, AG Falco
