Everything posted by AGFalco
Tyre dilemma
I run Vredestein Quatrac 5's as my winter tyres down south here. Why not buy the Vredestein ready for the winter. But still use / fit the Pirelli's during the summer. Also rotate your summer Pirelli's every time you have them refitted to wear them out as a set. They can get noisy from a sawtooth pattern appearing on the inside of the rear tyres. I rotate them diagonally to cut the noise down that this causes. Thanks AG Falco
Reverse gear gets stuck in Skoda Fabia Combi 1.2 TSI Manual, 90hp, 2017
When it sticks in reverse gear it is as if you are trying to pull it in neutral but without putting the clutch in first. As if the clutch is dragging and not disengaging properly. Thanks, AG Falco
- Front right electric window regulator
I don't think it is the oil in the gearbox or the engine. For me it is more noticeable when the weather is cold. Thanks, AG Falco
It tends to happen more often the colder it is and the shorter the journey is. Thanks, AG Falco
Android Auto / Pixel 3XL Not Working
Yes mine has the 4 buttons each side. But in my defence I suggested you select Android Auto. ( the other choice you have is Mirrorlink. ) So for others with the same problem you:- Turn phone on. Turn Bluetooth and Location on. Open Android Auto on phone. Turn Car on. Turn infotainment system on. Turn Bluetooth on in car. Then connect Phone to car via Cable. Select:- App/( head talking symbol) button Android Auto logo on touch screen Select ( your ) phone. Thanks, AG Falco
Rattling noise from rear driver side
Sounds like the brake pads touching the ( rusty ) disks to me. Look on the inside face of the disk for a build up of rust from the outer and inner edges. In the video you can see the outer face has some rust on the brake pad contact points. The inside face is normally worse than the outside face. Thanks, AG Falco
How do you reset the air intake valve without a scan tool please?
Herramientas Eurotools S.A is the Spanish connection. Now all part of Snap on. Thanks, AG Falco
Weird metalic noises from the chassis
Or the exhaust knocking against something. Get them to remove to undertrays to find it on Monday. Back of the engine where the exhaust comes down would be where I would look. Thanks, AG Falco
A stone between the exhaust and heat shield would be my guess. Does it disappear if you raise the engine revs. Thanks, AG Falco
Error message: Telephone system switched off.
Turn the Car Bluetooth off and remove the passengers phone from the car's list of paired phones. Both via the phone button on the infotainment system. Thanks, AG Falco
Maintenance Advice - engine, catalyst converter and electric problems
Fully charge the car battery with smart charger, connecting it up the correct way. Clear all the fault codes then drive the car and see what happens. Thanks, AG Falco
The air filter is listed to change at 60K miles. You have to remove the air filter housing to get to the spark plugs. I changed my air filter when I did my spark plugs at 37.5K miles / 4 years old. The old air filter and spark plugs both looked good. If the air filter was not changed then I doubt the spark plugs will have been changed. Thanks, AG Falco
TB is common to all cylinders. The long life spark plugs are meant to be changed every 40K miles. What mileage are you at and have they be done? Is the car on Q16 variable or Q14 Fixed servicing? Thanks, AG Falco
- Android Auto / Pixel 3XL Not Working
Lumpy running after engine start on warm days
Mine has always done that in hot weather. Just be gentle with the throttle or let it idle for 30's and it goes. I think it is NOT adding fuel unlike on cold starts. Thanks, AG Falco
Try this in this order. Turn phone on. Turn Bluetooth and Location on. Open Android Auto on phone. Turn Car on. Turn infotainment system on. Turn Bluetooth on in car. Then connect Phone to car via Cable. Then select:- Menu, Smartlink, Android Auto Select ( Your ) Phone. You also need to do this without the car moving and with the handbrake on. Thanks, AG Falco
FIXED - Problems with Michelin Crossclimate + tyres on Octavia VRS TDI184 4x4
Are owned by Michelin. Note. Thanks, AG Falco
- Space Saver Rim and Tyre + Tools
If a normal wheel / tyre fits in the boot then you could just get one to match. I have an alloy spare which is exactly the same as the rest of the wheels in my boot. It has a 185 60 15 tyre. The 16'' alloy wheel and tyre is no bigger in diameter, just a bit wider which will raise the boot floor a little. Or:- This one? https://www.ebay.co.uk/itm/254959028934?epid=1034622053&hash=item3b5cbe0ac6:g:XUsAAOSwYW9giQ0i Thanks, AG Falco
On board computer (MPG) survey
Front right window regulator
Thanks, AG Falco
