Warrior193
  1. Odd that you are unable to find the load plate! The tow weights should also be shown on the Irish version of the V5C document.
  2. There is a fairly common issue with the park selector microswitch going faulty on some models - I believe there is even a repair kit for it.
  3. @andrewclark55 Have you resolved this problem with battery discharge?
  4. Does your mirror move in the correct direction when the manual switch is operated? If not, it is possible that some of the wiring connections have been reversed.
  5. AGM Smart charger should be running above 14VDC on a discharged battery, as should the alternator - even though the new battery has not yet been adapted into the vehicles BCM. Because you are seeing low charging voltages for both the charger and the alternator, I suspect your new battery may have a high internal resistance fault - or possibly a bad chassis earth connection. For the coolant loss, check the EGR valve and have the coolant tested for combustion products.
  6. Welcome to the forum. Check that the lamps are the correct, matching wattage and double-check that all contacts for the lamp still indicating a fault are absolutely clean. To clarify, lamp monitoring systems normally use fairly tight current parameters - even a slightly increased resistance in the circuit may cause the monitoring system to flag a lamp failure - even though the affected lamp appears to be operating correctly.
  7. Odd that there weren't codes for the failing ABS sensor, thanks for the fix notice.
  8. Warrior193 replied to bruce's topic in Škoda Scala
    Aaaah, that makes sense now - I confess, Ops failure to use a single punctuation mark did throw me!
  9. Warrior193 replied to bruce's topic in Škoda Scala
    Welcome to the forum. A rather confused post - but if your battery standing voltage has fallen to around 3 VDC, it is probable that it will be beyond recovery.
  10. ^^^ because the locating pins on the side of the lamp base are offset - it should not be possible to fit in incorrect orientation without forcing (and damaging) the lampholder.
  11. Not sure for 2013 Mk3 TDI, but the shift on a 2015 MY16 TSI is visible from above - between engine and battery.
  12. I would suggest that your problem is not with the key fob, but with the alarm system itself - if the fob is disengaging the immobiliser to allow the engine to start, this suggests to me that the fob is working correctly. Disconnecting the vehicle battery should not stop the alarm, as it has a self-contained, internal battery.
  13. While attempting to select reverse, does the stick move fully through the gate when pressed down - or does it just stop at the gate?
  14. If your profile is correct, you have probably posted this in the wrong section. Have you tried moving the vehicle slightly in first gear before trying to select reverse?
  15. Quote 'Skoda mechanic says he doesn't hear compressor starting' is a little concerning - the A/C compressor does not 'start' because it is permanently driven unless the drive shear plate has failed. I'd take a close look at what was done during the changes to the climatronic panel.
  16. Clean diesel fuel on its own should be sufficient to keep the pump lubricated.
  17. AFAIK, you're probably as well off using good quality fuel and ensuring as far as possible that DPF regens aren't interrupted.
  18. So the only way the vehicle can move on the motor by simply touching the brake pedal is by NOT setting the EPB - AND leaving the gear selector in D or R, then touching the throttle pedal - is that correct?
  19. Keep all of the correspondence regarding this insurance snafu! - Consider changing insurer next renewal. Heaven alone knows what they will manage to do in the event of a claim!
  20. Thanks for that - but are you saying that there are still three separate actions required for vehicle to move - touch brake pedal (releases auto-hold); move gear selector; then touch throttle pedal?
  21. The only EV I've driven recently was an Outlander PHEV - to get that to move required the EPB to be released, the shift to be moved out of park and the throttle to be pressed - unless the Enyaq controls are completely different, it's difficult to see how all three conditions can be operated accidentally.
  22. Welcome to the forum. Sorry to hear of your mishap. Can you clarify, was the vehicle driving forward on the electric motor - or was it rolling forward down a slope?
  23. Welcome to the forum. I believe that a refusal of warranty for items completely unrelated to the servicing work you had done at an independent garage may be not legal under UK consumer law. See EU block exemption law.
  24. Ok for short-term emergencies - but better to keep the correct concentration to maintain corrosion protection.
  25. G13 should be ok for a top-up, and it may well be what's already in the engine - I believe the latest spec for coolant is G12evo.
