Radiatorcooling sensor.
Hi Stewart, check if the operating relief pressure is marked on the coolant system cap, system operating pressure should be a little lower than that - I'd take a guess at around 1.5-2.0 bar.
Fabia MK1 MOT Advisory - Exhaust Minor Leak
Hi Tui, welcome to the forum.That looks like a flexible coupling failing - personally I'd give that a closer look as carbon monoxide is very toxic but odorless, although you can often smell other combustion-products if exhaust gasses are leaking into the cabin.
Timing belt snapped
Probably worth giving the engine a head-off inspection - you may have been very lucky that the belt failed while idling in neutral - low kinetic energy and engine not being driven by wheels after failure.
Oil and Coolant advice
Hi Erroll, I can suggest Fuchs Titan Pro C3, 5W30. Meets VW 504/507 spec, less than £28 for 5 litres, free delivery from supplier on a large online site.
G12, G13 and G12++/evo coolants are all compatible. Check for silicate bag in coolant expansion tank, advisable to remove if possible - or replace tank.
Paddle shifter extension
As the MK3 is effectively a Golf 7, I'd suspect that those will fit your Octavia. Golf Mk7, I believe.
Cronulla Australia, hello world…
Hi Tas, a warm welcome to the forum. Do you reckon the new car could 'eat' the old Holden?
Who or what is the biggest threat to SKODA?
By far the easiest way is to simply replace the coolant expansion tank before there's any chance of the silica bag breaking down - quick, clean and easy job to do yourself. Tools required - new OEM expansion tank (make sure 'without silicat'), turkey baster to empty tank, suitable hose clip pliers (available online) approx. 500mls G13 or G12++ coolant to refill tank.
Help! 69 plate 1.0 TSI SE manual clutch gone after 2721 miles!!!!
Hi BC, when is your engineer due to inspect the damaged clutch components?
Hi BC, welcome to the forum. Sorry to hear of your problem, certainly not something you would expect so early on. From your detailed description of the start of the problem, it rather sounds to me as if it started with failure of the clutch-release cylinder - with the clutch plate possibly 'burning out' from resultant damage to clutch diaphragm and slippage afterwards.
Spare wheel?
I agree with Carston, adding a valve extension could just end up adding another possible source of leakage. Give the spare a pressure-check when you have a chuck-out / clean-up of the load bay.
Saying goodbye
The grey one with the extreme negative camber on the rears.
This is probably an old topic. SD card for my vehicle
Hi Tamsin, welcome to the forum. Are you referring to the navigation system card?
Expansion bottle replacement
I did a random search on that part number without success so far.
Add to that list - MY16 Octavia 1.4TSI - no silica bag from factory.
What is this part called
Well, at a guess I'd call that "Rear bumper, lower support bracket, left-side" Try that description as a start for a part # search.
A little difficult to see how casting sand has been left in cooling channels, as some posters have posited, but seemingly no evidence of it in oil ways. I have not seen actual engine-block production, but I'd guess the bare block goes through thorough cleansing process involving all passages. On another note, the appearance of the residue that has been the cause of heating matrix's may possibly be a little misleading - I once had a diesel contamination (diesel bug) issue in my boats fuel system - the stuff clogging the primary and secondary filters was black and gritty, and looked (and felt) for all the world like sand! It was actually dead and dying bacteria.
Possibly so, I just changed the expansion bottle on my MY16 Octavia as a precaution - late 2015 model, same part number as yours - I can't see any bag in mine either but a easy job for ease of mind in avoiding an expensive problem.
1.4 tsi autonomy
I think this is mainly to do with the shape of the fuel tank, also you tend to get a few litres up into the filler tube if brimming the tank, which will account for a few extra miles.
Roof rail replacement (is $1850 reasonable?)
#4 really easy job - Iv'e just done my Mk111, less than £15 (prob <A$30) for the tank, 15mins to replace - no need to de-pressurise coolant system if done when cold. A cheap turkey-baster is useful for emptying the bottle, and having a hose clamp-release tool helps.
Skoda Octavia estate, 1.8l, 2011 4x4. Oil problems.
Could it be that the oil is being blown out via the crankcase breather? Normally, gasses from this should be routed back through the engine - but has someone modded it so that it just blows out onto the road under the car as you drive? This quantity should still be visible behind you though, plus I'd expect to see obvious signs of this under the vehicle.
It might eventually work!
At the very least, once you have one of their cars, it will concentrate their minds to sorting yours ASAP.
Campaign 23AX
A Dealer not telling the truth? Surely not!
Hi James, wow, 5 litres in a thousand! are there any signs of oil leaks? If it's burning it, that car should be laying a smokescreen like a T74!
