Pressure
Assuming you mean the indirect TPMS system, operating via signals from the ABS sensors, I believe it does - provided there is a mismatch in wheel rotation speeds from when the system is set, the system should flag the change. Typically, my Octavia flags when the difference exceeds approx. 0.4 bar.
Towing 700kg load
Before you ask - the trailer weights should also be on a plate attached to the trailer.
Stalling
Unless I'm misunderstanding your terminology, it's a little difficult to see how is is possible to physically 'stall' a vehicle that's already in motion (at probably more than 10MPH) - the kinetic energy alone should keep the engine running in gear.
Stalling
Does it exhibit the same behaviour when engine revved in neutral, then allowed to slow down?
No comms with any modules, non start
... But what is the vehicles history? - was the vehicle running, then just shut down? - or was it bought as non-runner, as a project? or was it involved in an accident?
Is the cause of the original failure known - why were modules replaced?
Visually etc. My car of the day -today
Very likely to be thought a Q car.
Towing 700kg load
According to a number of online resources - and also on this forum - the max. towing weight of a 2018 2.0TDI is 1600kg (braked) - providing your trailer tare weight is no more than 900kg, you will be safe and legal.
I'd think the first step is to plug a reader into the OBD port.
Not sure, but would it not be the case that the ECU shuts everything down if the immobiliser was activated?
Hello, welcome to the forum. Engine start then immediate stop sounds like the immobiliser cutting off.
Towing 700kg load
As mentioned a couple of replies ago, check the permissible towing weight on the B pillar plate.
- VRS or 1.5 TSI ?
Stalling
It will help if you supply engine size and code - all we know at the moment is diesel and manual gears. Does the engine idle smoothly and at correct speed in neutral?
Help Please, very rich running Citigo
What engine is fitted to the 2015 Citigo?
Skoda Kamiq stop/start fault and associated screen fault
It is always advisable to carry out an adaptation when the battery is replaced in these micro-hybrids - if for no other reason than to clear any recorded battery faults that may be limiting charge rate from alternator. Adaptation is definitely required if new battery is different chemistry type (AGM/EFB) or is a different capacity (AHrs)
The EML lighting up could very likely be something other than a failing battery, any DTC recorded needs to be read to determine what might be triggering it. Also suggest getting the battery tested.
EML lit will definitely inhibit auto stop-start. You will need to read any DTCs recorded. The fault description for stop-start inhibition when battery SOC is low is usually 'Load too high'
Can I disconnect the air con compressor to test the engine?
Do you suspect timing chain failure?
I'm not sure that's a 'pixel error' - I believe it's the display indicating the possible source of the error, similar to the wheels being highlighted (except in red) when the TPMS flags pressure loss.
New icon after installing tow bar at factory. What does it do?
Depending on the width of the base of the triangle, I'd guess it's a guide, like the normal reversing tramlines - keep the trailer within the triangle while reversing.
Heated windscreen - Can you see the wires?
I have seen posts on the forum where non-genuine replacement screens have been fitted - some with issues! I'd think that would need to be discussed with insurance/fitting companies. Check the small print of the policy. Any windscreen camera will definitely require recalibration.
Battery issue or something more serious?
Those figures don't look too bad but you could could consider giving the battery a bit of a treat with a full charge.
Hello Henry, have you confirmed function of new option on reversing camera yet?
Try switching it on late on a cool night, then feel if the screen changes temperature compared to side glass.
