Alasdair1
  1. best bet would be to contact vosa direct as its outwith the time period. Have had to contact them and dvla a couple of times and they were really helpful. You may have to supply evidence like a photo of mileage,vin etc. Thin these days you can report on line at https://www.gov.uk/getting-an-mot/correcting-mot-certificate-mistakes Alasdair
  2. Is it the glass or maybe internal mechanism thats making that noise. On my sons mk1 the window slides on what looks more like felt rather than rubber. That sounds like glass on rubber or a bad pulley in door. From memory it has to be dry silcone spray. Think WD40 do a specialist dry lube. If you have used standard silcone spray it may have to be cleaned off first. Alasdair
  3. You will get part numbers from LLL parts from there original manufacturer parts diagrams https://www.lllparts.co.uk/catalogs/skoda/CZ/FAB/797/2/260/260042 I think the above link is your car but better search in original parts diagrams with vin number to be sure. Number 13 , 6 or 21 Then you should be able to google part number and get a replacement. Have a look at the PR code sticker normally in boot near spare wheel or inside car book as there are quite a few slightly different ones depending I assume on engine etc. Also make sure the part number is exactly the same if ordering from Autodoc as I reckon there will be some for RHD and LHD cars. Alasdair
  4. Sons Mk1 did the same. Cable wrapped itself around motor etc. I removed motor and then rivets/door card and managed to get the tangle of cables out. I got an aftermarket window regualtor off ebay and fitted it. You need special rivets for attaching metal door card plus a heavy duty rivet gun. Careful not to snap the door release cable plastic clip etc when removing door card. I also found that by undoing bracket that stops door from opening too much you can get to the electrics in door pillar easier. Rivets part number N91078801 I got a rivet gun lie this.
  5. If the oil hasnt been in for long and is really clean its possible to reuse although new oil would be advised if its older Alasdair
  6. Does the battery charging warning light come on when ignition is on but not started. It could be a broken exciter wire if its not illuminated or you may have dislodged wiring when removin Gbox Alasdair
  7. If the original fob works fine I agree its most likely the new fob. Wonder if theres a way to compare signal strength beteen them. Maybe an auto locksmith could check. Also check that the new fob is operating on the same frequency as the original? Had a quick google and Ai says its 433.92Mhz for Skoda but it came from Ai??? Think it should be written inside fob somewhere. Alasdair
  8. I would check that the garage used a full kit and what make and not just the clutch disc. If as Warrior pointed out if it was a diaphram/spring failure on the original and it wasnt changed the new clutch isnt going to last very long. Have heard of a few clutches being replaced at around 15k which I reckon would point to a manufacturer defect somewhere along the line. Sons MK1 fabia had 60k on the clock and clutch totalled itself. No warning or prior slipping just suddenly no drive in any gear. All that was left was a bell housing full of clutch fibres. His was older so I put it down to the age of the clutch. Alasdair
  9. Was it a genuine skoda fob or an aftermarket one. Have read that some aftermarket ones have lower signal strength/poorer antenna. Daughters got one for her volvo and sometimes isnt found but the original is fine. Battery in hers is new and voltage is good. Alasdair
  10. Had a failed MAF sensor on an old volvo that stopped engine from revving above 1100rpm. Anymore rpm it stalled. Was a long journey home in 1st and 2nd gear. Alasdair
  11. Think there is a gasket/rubber seal behind oil filter housing. May well be coming from there or perhaps rocker cover. Alasdair
  12. Maybe an aftermarket one. Think from memory it has a rubber thin seal not a crush washer. Looked from memory as above. Not on a skoda but my Seat was weeping oil and the seal had failed. I got a proper VW/Skoda one with crush washer and used a smear of hylomar blue just to make sure and it cured it.
  13. Not sure but reckon you could pick one up fairly cheap on ebay. If its the one near the wing mirror have seen them for around £15-£20. Chances are there is a part number on the one in your car. Alasdair
  14. If EML light is on there will be a fault code or codes stored. I would get it scanned. It could be as simple as a bad o2/lamda sensor or maf sensor. Either one or both can cause excess soot and quickly block DPF causing multiple regens. Alasdair
  15. Had it on on my Octavia with no blown bulbs. Had a bit of corosion on number plate lights and when cleaned up light went off. Alasdair
  16. Mine regenerates DPF without light on and is around 1000rpm at idle. If the DPF and EML light are on it could be clogged dpf but it may be a sensor thats failing and car has gone into limp mode. I would perhaps get it scanned for fault codes to see if it narrows it down. Alasdair
  17. Try https://www.lllparts.co.uk/ Go to original manufacturers diagrams and put in your vin. It should give you the oem part numbers for your car. You may have to look up PR codes on sticker in boot to confirm correct ones. Alasdair
  18. bought my son mk1 55 plate 1.2htp to learn to drive in. Had only 60k on clock and had been well looked after with minimal rust etc. He still has it and apart from a clutch exhaust flexi and a couple of ball joints been very good. Cost £1600 which was above book price but low mileage and no rust thought it was worth it. Had 1 owner for years and then the previous owner before him. The one your looking at £2700 I agree its a bit overpriced but MOT history seems fair with no major problems. Check that what it failed on have actually been repaired properly and not just covered up etc. It may need new suspension bushes etc due to its age and historical tyre wear. Alasdair
  19. Reckon as the filter is high up in engine you could replace without draining new oil. As for the sensor not sure but if your quick you shouldnt loose to much if its leaking when removed. Alasdair
  20. My old 1.9tdi the filter and top came out no bother. My newer 12 plate 1.6tdi is a pain in the a?? you have to remove wiring and a stainless pipe to get the filter out. Thats progress for you Alasdair
  21. Oil filter on my 1.6tdi octavia CAYC is a cartridge type and location is at front of engine. There should be a round plastic domed housing with a large plastic moulded nut on top.
  22. Sorry I have asked this before but can't find post. Need to know the torque/angle tightening for the front hub bolt to drive shaft. Remember there being a difference depending on 6 sided or 12 point but cant remember. Will be using new 12 point bolts and also tighten with wheel of ground. Was thinking of reusing original 12 point but it was so tight had to use a 3/4 inch breaker bar with a 5 foot pipe on it to get it to move so reckon its been stretched a fair bit. Alasdair
  23. Many thanks. Mine have only the three colours on one which match the info you posted and nothing on the broken one plus broken one seems slightly thinner coils so replacing both plus new shocks and top mounts as they look original and pretty past it cars at 130k. Had to get them from local motorfactors at slightly more cost but car failed MOT and need it back on road asap. Reckon the offfside one is a cheaper aftermarket one thats been fitted at some time. Had same with rear. Broke one a few months ago and when replacing both one on the rear was slightly shorter than the other. I always replace in pairs. Many thanks again Alasdair
  24. If that doesn't help it may be possible to disable alarm. Folks had a mk1 fabia 1.9tdi estate that the alarm kept going off. Local garage disabled it as the car was about the same age as yours and we thought no one would bother stealing it. Not sure what they did exactly but it worked. Alasdair
  25. Key fob battery has had it should be 3.2 - 3.3 volts. At 2.9 it is needing changed. Worth trying as they arent that expensive. Alasdair
