Alasdair1
  1. As said it will have stored a code/codes. It sounds like its gone into limp mode and by stopping and starting again has reset itself. My old 1.9tdi used to do similar due to sticking turbo actuator and overboosting. Worse when going up hills like you were. Turned off and on again and back to normal. Alasdair
  2. That was on my mind to ask next. Glad you got it sorted. Its amazing how a radio can affect them. Last one I read was no OBD2 connection/communication Alasdair
  3. Came accross similar in my folks old MK1. Service kept coming on at 6 month intervals. Garage said it may have changed as it was only used for very very short runs and as never got up to temp properly may need oil etc checked more frequently. They reset it to annual service. Alasdair.
  4. I agree with ABS sensors including wiring to them . Theres something not right. It would perhaps explain tire pressure code, power steering and transmision code as well as the ABS errors. I would check all earths especially ABS and ECU and inspect wiring loom and connectors to ABS/ECU etc as well as relevant fuses and check if theres a relay involved. Alasdair
  5. The braking faults 0668 could be caused by a low power connection to ABS or bad earth but you seem to have a fair range of faults mainly electrical What is the condition and age of battery. Might be worth checking voltage with engine off. A low battery can cause all manner of problems. Also check the fuses in engine bay near battery for corrosion or looseness as well as earth points etc. Alasdair
  6. Check that the alternator connections etc is making good contact as well plus maybe check fuses near battery for corrosion or looseness. Alasdair
  7. That's odd I thought they all had anti theft alarm unless someone has removed it. I had a quick google and 2001 I think uses Immo2 which is simpler. 2003 I think uses Immo3 which is more complicated. At this point I am now lost as its above my learning curve. I would assume by swapping all relevant modules etc it would work. It must be an imobiliser problem or incompatabilty somewhere. Alasdair
  8. Think they worked with both. Some systems can-bus and rest K line. The symptoms are definitly imobilser linked. Wonder if the newer uses more Can-bus or perhaps something else that requires coding to ECU. Not sure but maybe BCM although don.t think its imobilser linked but may be linked to cluster. Alasdair
  9. Maybe a full tank of supreme diesel would help clean things up although at todays prices would double the value of my old 1.9tdi. Hope a good going over with VCDS will pinpoint something. It may be the throttle position sensor that is out so perhaps a throttle body alignment with vcds is required. Alasdair
  10. Its been years since I needed a child seat but we drove Volvo 940 estates then and getting a seat to fit properly wasn't easy. We went to halfords and they tried a few before we got one that fitted well. Might be an idea to pop in and ask them if you have one local. You obviously don't have to buy from them but they were very helpful. Alasdair
  11. If its happening when accelerating and also when foot is lifted your probably right in it not being a drive train issue but worth getting garage to go out with you and show a mechanic not the salesman. It may be a bad tyre even though its brand new. Had one go slightly out of round that was fairly new. Couldn't notice at low speeds but at 50/60 mph felt like someone was shaking seat base. Not felt through steering wheel. Turned out to be one of the rears. The tyre service said they see it fairly often and have had random new tyres the same. Alasdair
  12. Have a look in the vehicle hand book or beside spare wheel. You are looking for a sticker I use https://www.oemvwshop.com/pr-code-decoder/ to decode them. As said not sure if reverse lights are mentioned specificly. You may have to get a full list from Skoda. Alasdair
  13. Not sure on the Yeti. Fabia is under rear seat so yeti may be the same. May be under a plastic cover. If the guage is working and then showing full randomly I would suspect a wiring short or broken wire. On some skodas fuel sender feeds direct to cluster and others via BCM. Think it depends on age. Alasdair
  14. Another thing to check is the build code/Pr codes. Not sure if reversing lights are mentioned but if it states that two reversing lights are fitted then there should be two. 8TA is tail light with reversing light
  15. Think it depends on trim level and if its UK or EU. It may be that there is only one as UK law states one is adequate. I assume its LED so if there is no LED light there it would require a new unit plus probably VCDS to tell car its fitted. If there is an LED unit there then it may be possible to tell car to operate it. Alasdair
  16. If its going to floor and not returning I wouldnt be driving it until I found the fault. It could be a return spring on pedal thats broken or come off but it could also be the master cylinder seals letting fluid passed them. It may not be leaking yet but at some point if it is the master you will have no Brakes!! Check the brake reservoir level and any brake pipes/flexi for leaks. Similar symptoms can happen if its a major leak of fluid. Alasdair
  17. If its the rear it could be the handbrake cable operating lever that's seized. Pistons don't release properly when handbrake is let off. I removed the lever etc and lubricated mechanism plus operated it until pistons were out a good bit and then wound them in again and kept repeating until it worked smoothly. As for identification have a look at https://brakesint.co.uk/ They have description of caliper like smooth/ribbed etc with all sizes and pictures. Alasdair
  18. Neighbour just had the same problem on his Mitsubishi 4x4. Just back from garage for service and MOT then dash lights like a Xmas tree with numerous warnings re ABS,Steering,4x4 and a lot more. I got called to look and told him to get garage to scan/check sensors etc. Bad clip that holds sensor in bearing plus new bearing as the old one was totaled trying to remove. Back to new again. Alasdair
  19. Hopefully a glitch. I would monitor it and maybe keep an eye on trip mileage in case the guage/wiring is faulty and showing more fuel than you have. If it happens again I would check wiring from sender backwards. Alasdair
  20. Many thanks Pete. doesn't seem to be any play or signs of any weights missing. No clunks either so wonder if one is slightly bent. Have tried everything else to cure wobble and thought I would try a couple of cheaper versions (febi/Apec around £120 for both to check if it makes any improvement. Only thing I havent changed is front shocks but they have no signs of leaking plus car seems level and feels fine over bumps etc so I assume ok. Have an old 58 plate and checked and they are the same part numbers so have a spare set of genuine if I need them. Alasdair
  21. Hi I have had an odd wobble when accelerating for a long time. Stops when foot is lifted or clutch engageg and the only thing I haven't replaced is front drive shafts. Not sure if its the inner or outer CV that is the problem or the shaft itself. Doesnt seem to be any wear/movement so assume one is out of balance. Cars done 110k so going to replace both completely. Have found via lllpaarts the following part numbers via VIN number Front left is 1k0407271CP or 1k0407451FX both superseded by 1k0407271LB Front right is 1k0407272CC or 1k0407452DX both superseded by 5q0407272FF Can anyone confirm these part numbers are correct before I order them. Going aftermarket to keep cost down so probably Febi or Apec Thanks in advance Alasdair
  22. It looks like multilink. On my MK2 it is. For adjustment you need 4 excentric bolts. Two for the top swing arms and there are another two but cant remember where. Have a look at https://www.lllparts.co.uk/skoda-parts manufacturer diagrams. They show the complete rear in exploded diagram with part numbers etc. Alasdair
  23. Only problem I had with gunsons that the brake fluid seems to turn the tubing opaque unless washed out afterwards so difficult to see any air bubbles. Apart from that worked well. Just remember to reduce pressure on wheel your using for air. Alasdair
  24. On my sons mk1 1.2htp Gunsons easy bleed kit worked when I did the clutch. Alasdair
