- 1.2 tsi cracked vacuum lines causing engine to hesitate ?
- Hello
Depends on if its EFB or AGM and size/make of battery. Quick look and if its an 096 Tayna batteries are £100 aprox for varta 096 EFB and £125 aprox for varta 096 AGM. Try puting reg in at tayna and see what they come up with. You may be cheaper buying and fitting it yourself and paying to get it coded. Alasdair- 160k and new dpf required perhaps?
Is there a cat before the dpf. If its clogged it would explain continuous regen but lack of airflow can stop the soot being removed. Not sure how you check. I would assume a fault code but perhaps not. Alasdair- 160k and new dpf required perhaps?
Soot mass is high but not excessive. I reckon its not getting long enough to regen completely or regen is failing for some reason. My mk2 1.6tdi is the same. Fan on when engine turned off plus idle at 1100-1200rpm. I took it for a blast keeping revs up to 3k in 4th gear for about 1/2 hour and its back to normal. Not entirely sure with yours but differential pressure seems high as well.- Engine enters limp mode
Had another thought. Check the strip fuses in engine bay. On my sons fabia there in front of battery box. They can crack but look fine. His ABS one went and randomly car got ABS light especially when damp. It was a hairline crack that couldnt be seen but when removed it fell in two. The others were fine but a but of corosion around where they bolt down. Not sure if any are related to ignition but worth a quick look. Alasdair- Engine enters limp mode
How is the timing set on the engine. I believe LPG timing is a good bit more advanced with propane than petrol. On older systems (distributor) they set it somewhere in between for optimal combustion of both. My LPG forklift ran very rough at idle plus spluttered etc until I advanced the ignition slightly. Just wondering if the timing is off slightly. On the forklft there is a small oil port on distributor to lubricate the centrifugal advance. If I dont oil it regularly the timing is out. Alasdair- Fabia Mk2 1.9 TDI Slow cranking and flashing Glow plug Light
4mm cable for earth reckon is too small. Think main battery is 10mm or more and starter is at least 6mm. If a new battery doesn't cure it it may be the starter itself. Used to be able to get them checked at a local autosparky as he had a machine to simulate starting load and was an expert at rebuilding them but alas he has retired. Doubt anyone checks them anymore. Hope the new battery cures it. Alasdair- Fabia 07 MK1 VRS O/S door mirror.
Be wary if ordering one from europe etc. I got an aftermarket one for my sons MK1 and it was much smaller as it was for a LHD car. Alasdair- 2006 Fabia BKY 1.4 16V exhaust issue..
Not sure but came across a euroflo one with can and o2 sensor before cat. Might narrow it down but think its an autodoc type company. https://www.onlineautomotive.co.uk/Skoda/Fabia/1.4L/Exhausts/Catalytic-Converters/EuroFlo/SKO1014H?gad_source=1&gad_campaignid=22698198479&gbraid=0AAAAAD9ghT5Vx78C_2whCjuZY2pJFdKTz&gclid=Cj0KCQjw7IjOBhDyARIsAFzrWQyR7MTtIJT9AkqxmApe9KS09DftrCrUzu5agorJC54mKBW-y3fxiQIaAskBEALw_wcB Meant to add euroflo part number ECVW1186TA Parts in motion have them £127 Alasdair- Engine enters limp mode
As it doesnt have codes just wondering if it is in limp mode. Do you have petrol and lpg and does it do the same on both. On my mk2 EML light is on when in limp mode. May be a lack of fuel problem with lpg.- Are you sure it's a cylinder head? Please disprove it!
Could be ECU but maybe the connector is loose or needing cleaned. As said seems odd there are no fault codes. Maybe see if anyone has VCDS to see if there are any codes that the scanner didnt pick up. Wet passenger side is quite often leaking heater matrix but if theres no coolant loss maybe coming in at door seal or at passenger side window and through door itself. Alasdair- Engine enters limp mode
What scanner was used. If the car goes into limp mode I would be 99% certain a code is stored somewhere. You say Gas/Lpg engine. Is it running on LPG. Not sure how the system works but on my old LPG forklift if the antifreeze is poor the unit that supplies LPG tends to freeze up. Alasdair- Droning noise above 50 MPH in cabin
Meant to add if they check the wheels get them to check undertray is secure. Have had one vibrate at certain speeds due to lack of fixings. Alasdair- Droning noise above 50 MPH in cabin
If its a bearing it will get progressively worse although I had one that lasted for months until I got round to replacing it. Slight droning noise so I checked and there was no noticeable movement or play. Eventually became loud enough to pin point which one. Maybe the garage that did the tyres would pop it on a ramp for you and give each wheel a quick check. Alasdair- Droning noise above 50 MPH in cabin
Difficult to tell but may be a wheel bearing on its way out. My sons sounded a bit like that His was the front and it change pitch/got louder/quieter if you steered left and right. Could also be a bad CV joint. Did the noise move from rear to front or vice versa when you swapped wheels/tyres. His bearing made noise but no noticeable play and felt fairly smooth. It was only when I compared it to new one noticed it was a lot stiffer. Alasdair- Boost position sensor/actuator issue
Check any vaccum lines to turbo and also if the actuator is moving freely. My old 1.9tdi actuator was sticking and used to over boost then limp mode. P0299 is underboost so wonder if its sticking open randomly. I lubricated mine and moved manually for a good while till it became smooth again. I think theres a sensor on yours that may be failing or perhaps wiring to it. The turbo may be a variable vein type and they can get carboned up and stick causing the same symptoms. Also check your air filter. Alasdair- internal heating problem - no control, hot hot
- Wet drivers footwell
Mine leaked at door card as seals for window were shot and plastic liner had become detached. Alasdair- Hello
- First time poster - MOT Fail and could do with some advice...
If its in really good condition with not much/no rust someone will buy it and fix it or use as a donor car for parts. Folks had the 1.9tdi estate version that I then inherited when they gave up driving and was one of the best cars I've had. Loads of space in rear and mpg was 60plus plus power when you needed it. Alas a slight arguement with our postie van and it was written off. If he had been 1sec slower or faster he would have missed the door pillar. Daughter has the V40 D2 R design which is newer and she is very happy with. Been in it once and feels very solid and safe plus supposed to be very reliable although visability not as good as the fabia. Wasnt too expensive at around 3k. Only problem with modern diesel is the DPF so she has to take it for a decent run from time to time. I used to drive volvo petrol 940 estates which I reckon have the most space in rear. I loved them but £400 road tax plus 30mpg became too expensive. I would have another tomorrow if I could afford to run it or ideally a 240 saloon as I used to have one. A 23 year old volvo v40 1.6 with only 70k and a full service history may be a very good buy as long as its clean and free of rust. Thats only done 3k a year. Maybe factor in a timing belt if it hasn't already been done. Used to be 70k or 7 years from memory and perhaps a clutch if someone older has been driving it and slipping it a bit. Cant be many v40 of that age with such a low mileage. Really hope you get something sorted soon. Alasdair- First time poster - MOT Fail and could do with some advice...
Son has the hatchback and its 20 year old and generally rust free. Best thing about car is its simple so if it goes wrong then generally repairable by me fairly easily. The MOT fails seem to be fairly straight forward repairs by any garage. Power steering hose may be problematic sourcing a new one otherwise parts are relatively cheap if going for aftermarket ones. Problem these days is labour cost. Still think it would be an idea to try around some of the smaller garages if you have any left near you as they are dying out near me and being taken over by Arnold clark etc. and cost a fortune in parts and labour. The only thing that would worry me is that engine has a timing chain and at 120k could probably be needing changed unless its been done previously, Same with the clutch. It may be noted in any service history that came with car. Last thing you want is to spend money and then have to spend a lot more if its needing done. If the chain fails it will wreck engine. There may be someone on here that could reccomend a friendly cheaper garage near you or possibly a mobile mechanic. Have a look at Volvo as well. Had older ones years ago and they never gave me any bother at all. Alasdair- First time poster - MOT Fail and could do with some advice...
Re exhaust pete is right. Flexi bolts onto cat. Sons is the same. I bought a flexi repair but wasnt enough left to clamp it to so bought a new front section including flexi only £60 from partsinmotion (BM catlyst BM50199K). Winscreen pump may have failed but there not expensive. Rear shocks are fairly cheap as well. As for the front suspension bush they are fairly cheap as well but need a puller/press to remove an install old one. Is it the same garage that did the MOT thats quoted over 1k. I use MOT only garages. Found in the past some garages seem to be a bit hard on you for an MOT if they think they may get the repair job. Might be worth phoning a few independant ones to get a quote for the fail points. Alasdair
