Everything posted by bigjohn
Boot will only open from keybutton
- Humming noise at 60mph
My son's 2016 Octavia did this a few months ago when we moved tyres front to rear and vice versa. You could feel a slight sawtooth wear on the tyres moved to the front from the rear. However it's subsided after travelling a few further thousand miles or so. To detect the sawtooth issue - rub hand clockwise over tread - then anti clockwise to feel the difference. Usually inner or outer edges.- Octavia 3 1.2 TSI hesitation in 1st gear
"For a slight push on the pedal the engine quickly revs up, but falls back on the clucth release and revs up again, causing the hesitation." After clutch release it shouldn't rev up again without the car speeding up without the clutch slipping? or is it not fully released? I'm not sure you can check operation of throttle valve with ignition on/engine off as there is a complex startup algorithm that controls all sorts of things to minimise emissions (airwash, rapid catalyst light up etc). I've driven my sons 2016 1.2 Octavia a few times and have never noticed a problem with his. [EDIT] When driving at slow speeds + lower revs if you floor the throttle how does if feel - any hesitation or feeling of dropping a cylinder. These engines are very plugs/coils sensitive- 2011 1.8 TSI with a loose chain and oil pressure and cam codes
Or is it the other way round? - is the underlying issue oil pressure? The chain tensioner relies on oil pressure.- 18" wheels to 16" wheels
The other benefit of having higher profile tyres on 16" rims is tyre life. I'm getting well over 35k miles out of a set of tyres on my poverty spec which was fitted with 205/55 R16's from new. Now fitted with Crossclimates the road noise is even lower- Anyone know what this is?
Window cleaners visited?- Little milestone
Likewise, not quite 100k miles yet for me - 94k miles. No real issues, just front brakes and a couple of broken springs - oh and 1st lockdown upset the battery (never failed per say, but replaced anyway) . I extended to a five year warranty but having owned from 14months old but I never needed it for anything. Overall I'd agree - fantastic car. Reliable, refined, comfortable, economical AND I fit in it!- Dry Dipstick
By driving for a mile with no oil pressure you've probably damaged the engine - first part of self destruction usually the big end and main bearings. The red oil light means STOP - NOW! Patching a sump doesn't usually work as not much will adhere to it with oily surfaces etc. Don't keep running the engine until you know the state of play and what damage has been done to the sump, dipstick, oil strainer/pipe/pump. Probably first job is to drop the sump - you just might get lucky. If big end / mains are damaged then even when oil / feed restored you may loose oil pressure out of the side of the cream crackered bearings. Years ago I had this with a Ford 2.0 that had failed due to the oil pump hex drive shaft of doom(went round). Even when oil pump sorted it sort of ran OK cold but when the engine/oil warmed up you got the horrible bottom end death rattle.- Cruise Control or not?
Cruise control may not work for all sorts of reasons including clutch and/or brake pedal sensors- What would you change?
Sachs I think? [EDIT]- What would you change?
The concentric clutch slave cylinder is notorious on many makes of cars inc some Honda's. It's a bit like a set of bellows around the gearbox input shaft with a release bearing on the end of it. I actively pick versions where possible with a simple piston/seal externally mounted clutch slave cylinder. Much more reliable and if it does fail it's a simple cheap job. On that note it's reminded me of another mkII problem with some diesel engined manual cars - the dreaded clutch pressure plate failure that can machine it's way through the gearbox casing inside the bellhousing - another thing to change on some versions.- Hidden amplifier mounting location?
Edit is available for Freedom subscribers Re Passenger seat - you'll have to offer the amp up for size - it's a common mount position for amps etc in many cars. The other place to checkout for size is in the side compartment of the estate boot.- Another surprise message
Could be an indication of a faulty brake light switch! I mean why would you? Back in the day when driving stall prone carburettor cars setting off on steep hills I used to hold the car on the footbrake whilst giving it a bit of throttle when releasing the clutch. A benefit of having size 13/wide feet! No need on modern injection cars as the ECU compensates and as previously mentioned if brake pedal operation is detected then the ECU restricts throttle input.- Hidden amplifier mounting location?
Under the passenger seat seems a common location for such devices- 1.4 TSI engine , Experiences and problems... ?
The 1.4tsi EA111 engine was also fitted to my 2014 1.4 Superb II. I've had from 14 months old 14k miles and thus far it's been fabulous and is over 93k miles now:- It tugs my big bus along surprisingly well Low revved at speed - 60mph = about 2000rpm in sixth gear Has been averaging about 46mpg - I've seen over 50 mpg on some long runs. This may change a bit going forward as I no longer do my long commute (yay!) Oil consumption very low indeed It's very quiet The manual is fitted with an external clutch slave cylinder (reliable as well as easy to change - not that I've needed to) Water pump is separately driven Single Mass Flywheel No EGR valve - this function performed by control of the variable valve timing Since I've owned it, if left for a couple of days it's always had a very brief rattle on first start-up which has never got worse. Checked at the dealer at the time and deemed "normal". Note as it's a 2014 car this will have about the last version of the 1.4 EA111, by then the 1.4 Octavia was the mkIII which had the totally different EA211 NB - important the EA111 engine has regular oil changes and the correct oil filter must be fitted (mentioned elsewhere)- vacuum pressures for turbo Octavia 110 mk1 hatch ASV
Lots of low voltage messages - is the battery ok? Might be relevant re N75 solenoid control etc. Vacuum pipes can cause issues as well - rigid pipes rub through with vibration, flexible pipes rot. It's sometimes not obvious.- What would you change?
The issue I will have in the future is not what would I change but what would I miss wen I get something else. Unlike some I love the twin door. I usually open as a hatch but use the boot opening when in restricted height areas such as ferry, Chunnel, multi-storey car parks etc. The passenger and boot space is something else and I find it amazingly comfortable. It suits my tall and ample frame (many cars don't) It's sooo refined - it's hard to even tell if stop/start has kicked in with the 1.4 Theoretically we should be downsizing to one car and a smaller one that Mrs BJ likes driving - I'm dreading it.- What would you change?
I don't know whether it's the angle of the glass on the twin door but water sort of "bobbles" and kind of rolls off as soon as you are in motion. Twindoor rear window has never seemed to get dirty with road muck in motion.- What would you change?
Good point - although I use "Rain X" on mine. Makes a huge difference.- What would you change?
I might revert to hand signals again At least it's easy to change the H7 headlight bulbs and on the facelift there is a little lever to flatten the beam for continental driving (remember that!!)- What would you change?
Bumper off/ headlights out job and a very strange bulb - where not LED. Fortunately I've not needed to do this yet!- What would you change?
The view out of the back window of the twindoor - oh and the design of the front indicator bulb fitment.- Chest and muscle pain
I'm 6ft 4" and had some issues with my Superb II when I first bought it (2015)- turned out there was too much adjustment for once. For the first time in my driving career I actually pulled the seat forward 1 notch and adjusted the steering wheel so it was further away. Now perfik. Re seats/driving position - everyone is different.- 130PD engine in 110tdi?
If sold from a dealer they are not allowed to say this so the law is on your side. You'd probably win in a small claims court. - as to whether you get any money back though is another matter. Before you consider replacing subframes / suspension etc check the condition of the rest of the body. Not much point fitting new subframes etc if what it attaches to is rotten. The good news is some can be great due to the original body tub galvanizing - subframes and suspension parts are not galvanised so they rot eventually. Check around rear suspension, sills, radiator as well. The other issue is when that rusty you'll probably encounter loads of bolts/nuts/fitments you can't easily undue. Any captive nuts/fitments can be a real show stopper if they shear off.- Alternator appears not to be charging, but no warning light
Is it the original battery on a 2015 stop/start car? If so it's probably near end of life - especially if it has been lightly used in lockdown etc. The original on my facelift 2014 Superb had to be replaced a few months ago - funnily enough after I left the sidelights on for a whilst diagnosing a troublesome rear number plate light. When the battery is near the end it has much less storage capacity. Replacement will have to be a EFB or AGM battery. NB I find running my car with the headlights on provokes it to charge. I can tell as I have a split charge relay to sometimes run a coolbox from the boot 12v socket.- and I can tell when it's not charging as it turns the coolbox off. - Humming noise at 60mph
