rum4mo
Everything posted by rum4mo
  1. Yes, as said flat face towards the hub bearing, these have been changed in design to make them a bit simpler - maybe, I found it impossible to fit a new one on one side of my wife's 2015 Polo due to corrosion on the drive shaft - even after trying to knock most of it off - kept breaking off some "teeth"! Edit:- handy picture of the end of the new driveshaft - so that is what they look like new, wrt the groove for that shield.
  2. Or, are some of the parts not correct equivalent parts to the VW Group factory originals, I was going to check the length of thread showing above the TRE ball pin on my wife's 2015 Polo as I thought that in that picture it was a bit excessive, which made me wonder if the taper was different to the original TRE. Really same thoughts about track rod lengths. Edit:- questions like this is probably why proper mechanics will only ever fit parts they have supplied.
  3. Maybe too late for you now, but I think that the general feeling is that some cheaper aftermarket lower arms might fit okay but the folded steel is thinner than better quality and VW Group offerings. In my case, I just changed the rear mounting bushes for Lemforder items which are what VW Group sell as spare parts, the lower swivels - are still waiting to get replaced, hopefully this Spring time, the original lower swivels are still "good", I was just doing a suspension "refresh" so planned to replace them as well to complete that task. It will be a bit annoying if I need to get the drive shafts out to do that job properly as that will add to the cost - obviously if I had done that while doing the rest of the suspension work, I would only have had to buy one extra drive shaft nut.
  4. New bolts cost quite a bit , but really are the correct way forward, I needed to replace a sheared off subframe bolt on my wife's 2015 Polo 1.2TSI, I just fitted a new bolt and torqued it to the initial torque level and handed that car in along with the rest of a set of new bolts, and requested a subframe alignment which must include swopping all the original bolts for the new VW Group ones I'd supplied. Edit:- up until now, I've always bought a digital copy of the official workshop manual from a 3rd party online source, okay it will not be "the latest" but for my cars that has worked out okay, the erwin route is probably the smarter way of getting that info in its latest form, but I considered that my broadband was not good enough to do that at the time, so bought the digital copies on USB sticks. When I initially bought my 2011 Audi S4, I had to make do with Haynes for a similar age/model TDI, but that helped a bit until I got round to buying the digital version from www.easymanuals.co.uk.
  5. I think that Hankook changed their compound a year or so back, to address this, though MOT test probably accepts this “minor cracking” on newish tyres. Certainly my younger daughter and her husband binned the original rear tyres on their 2019 SEAT Arona because of this, as I would probably have done. They replaced these Hankook tyres with a newer version - which matched the recently replaced front tyres (car bought used at 3 years old), tyre tests data suggested/stated that this new version had improved compound and other “good” changes.
  6. Ideally you should get the car’s controllers ready with a VW Group fully compliant scan tool, and use the logged faults as a starting point while also considering what you have also discovered.
  7. Sorry that might have been duff info as you can buy a "lock cylinder with keys" for that tow hitch under Skoda part number EEA 770 011, it seems, 5J0 804 968 for the actuating lever cylinder lock and keys, or also another number for the cylinder lock and keys 5JO 803 928 !
  8. This to me is a bit strange as in the past I've had SERIOUS trouble removing the "TRE "pin" self locking nut on a 4 or 5 years old 2002 VW Polo, next time that I had to remove that nut was on a 6 or 7 years old 2009 SEAT Ibiza and that nut "looked like new" and came off very easily, next time was my wife's 8 or 9 years old 2015 VW Polo - and again that nut looked like new and came off very easily. I've always just bought new nuts from VW Group outlets or ebay trader if the price looked okay and I was buying ahead. The steel used on these nuts that I have seen and/or bought over the past 17 or 18 years is never going to corrode like they used to - and thank goodness for that, so it begs the question, what sort of junk steel nuts was Skoda buying for use in their factory in 2018 ? Edit:- quote from my records from last year "TRE nut VW N 909 429 02 M12 X 1.5 £5.95 for a pair" from my local VW Van Centre in October 2024. Another Edit:- humm, maybe not the best time for buying that via ebay traders, as said they are usually a stocked item at your local VW Group dealership parts dept either Skoda/VW/SEAT oe even Audi which ever is easiest to reach. If the originals are really corroded a lot be prepared to need to use a hex or Torx key in the top of the pin to stop it rotating, torque should be 20Nm + 90deg, socket size 18mm. Sorry but I don't seem to have noted down what the size/type of key needed to hold the TRE pin from rotating, just make sure that you are really sure that you've got it right to avoid rounding off that hole. Yet another Edit:- TRE pin insert size to stop rotation is 6mm.
  9. Some of these sill/cill level damaged rubbers will be due to "user misuse" from anything like forcing large sharp edged items through the door openings to high heeled shoes that have compressed/worn metal end caps on them.
  10. Yup, I've just checked the spares, you can only buy the cover + 2 clips, a spares item common across the VW Group marques for this size/age of car.
  11. I think that you can buy the 2 “slider” locking parts as a spares kit, I’ll check later.
  12. Maybe the windscreen has been replaced in it's past and broken glass is still air box?
  13. I used small chisels and smallish screwdriver bits, chisels kept slipping, I broke the screwdriver bit, but worked round that issue on the RHS, which had a broken spring on the first car I did this job on, sort of dreaded doing the other side, but by that time having the hub splitter tool and no need to remove the drive shaft, and being able to chose the time of year to do that other side - first side was 2nd January!, made the LHS a lot easier and quicker.
  14. Have you tried fitting the blade of your ignition key into that lock, probably after spraying some lock lub or release oil into it? I would expect any factory fitted towing hitch fitted with a lock barrel to have the same lock as the car - or am I wrong, no doubt someone out there with a factory fitted removable towing hitch will know the answer to that - and to where to find the lock barrel "number" if you now need a key because it was not factory fitted. Getting hold of a copy of "CAR DATA" for this car, would let you know if that towing hitch was factory fitted.
  15. Exactly, I'd always be very aware that I'd end up paying for labour to replace, no "ifs" or "buts".
  16. I don't know why it is the LHS that, at least in UK, seem to fail the most, possibly due to how these parts get integrated into the suspension system on VW Group cars - or a RHD only issue - and so it could be RHS mainly in LHD markets. On the question of supplying your own parts, in my case, I think that my honest garage owner did end up maybe charging more time than that job warranted due to them "operating to my instruction" - but I'll take that. I'm sure that there is plenty scope of that if you as a customer request/require working doing that is not being done from a menu or "book times". I had said that I had carried out the diagnostics side of the job so all I wanted was for his workshop to deal with the issue of removing a seized in failed ABS sensor. The final bill did outline that work was carried out to as requested - which is correct and fair enough to both parties. Maybe I need to look further afield if I really do get lazy/worried about replacing all my front suspension arms - as I've already bought all of them and all associated fixings, a shame really as I want to put work his way, ie support my local small independent workshop. My last job that was carried out on my car was done by a localish VW Group Indie, first they "poo poo'd" me when I suggested that the only source for the correct parts was Audi, after a few days they got back to me to confirm that was correct and needed me to collect my car until parts could be procured. Then it turned out that one part was out of stock at Audi - that was true and very unfortunate for us, after that I offered to take on the task of ordering in the parts which they were happy enough as one part was back order with no firm suggestion on when it would become available - but, in general, I'd suspect that they would decline any requests from me to fit supplied parts to cars, and I can understand that as there are as you said, the issue of any items failing early, plus any items supplied being wrong for that model of car - and so lead to "car in bits stuck on a lift with someone needing to pay for lost time/revenue" and also low grade parts being supplied, ie lower grade than their workshop is willing to work with - really potentially lots of issues that could only work against their business.
  17. There seems to be a method used in USA by the VW Golf owners, called the "2 X4" method, that seems to involve jacking the strut up using the ARB drop link bolt and its bracket to "secure" a length of 2" X 4" with a bottle jack or trolley jack under it, that obviously allows "you" to compress the spring and so the hub carrier socket can be separated from the bottom of the strut - I'm certainly not recommending using method as it seems to be quite risky! One other tool that I'd suggest is a "must" when doing this job, is a "hub splitter" bit, again Laser Tools sell their version of this official VW Group tool, but I've noticed some others selling the exact same item a lot cheaper. It is used to slightly open up the pinch point after removing the pinch bolt and nut. Laser Tools 3396
  18. The part about the customer buying their own parts, really from any source seems have become a big "NO NO" for many garages, a bit annoying for some of us, but I've had that response when I wanted a new ABS sensor fitting and then the car being MOT'd, initially that hurt a bit, but I had to accept it, really not too good as I grabbed a new ABS to carry out diagnostics - and ECP was the easiest place to buy a Bosch one from - £67.99 PIM price was under £15, but that would have taken maybe 3 or 4 days to land on my doormat! Leaking DCC dampers, especially the LHS front ones, hum, yes, a common problem it seems like, SEAT at least, fit Monroe at factory, and the difference in price from a Monroe branded DCC front damper and a Monroe VW Group branded DCC front damper - at least for a 2019 SEAT Leon Cupra is huge - horrible.
  19. Just one thing, if it was the RHS front spring you were replacing, then it's always better to remove that nut to get the drive shaft out so that you can get the hub down low enough to get the hub carrier out of the strut "socket", so, if it is now the LHS spring that you are now planning to replace, you don't need to get that hub nut off as you can get the hub down low enough with the drive shaft in in place. It was a Laser Tools 36mm Bi Hex 1/2" drv deep socket that I bought back in maybe 2008/2009 - and that one had slim enough walls Laser 0954 there will probably be other cheaper ones that might fit. Edit:- checking for wall thickness is a very valid point, I might have struck lucky, found one being sold in damaged packaging at a market stand at what I thought at the time was a good price, so bought it. My other worry was "do I need a deep socket seeing as that nut is quite "high" ?" so I just played safe and bought a deep impact socket, and in time, that worked out well for me. Maybe the nut is not "high" but the drive shaft projects out of it quite a bit.
  20. This is typical of the problems that can "evolve" when being collected by AA or RAC during warranty period. I had an issue with a 1984 Ford Orion 1.6 Ghia Injection, the engine cut out as I drove over a rough roundabout that had been skimmed during road resurfacing, I knew it was an ignition problem as I noticed the rev counter dropping like a stone. So, as I was an RAC member, and maybe going by my description of the problem, they sent out a contracted garage recovery truck - to transport my car either to my Ford dealership or my hone address, I chose "my home address", it was made clear to me that the RAC were being "very careful" about working on cars still under new car warranty. In that case, I had caused this problem to probably occur, it turned out, I discovered once at home, to be a badly "potted" ignition coil lead, ie the primary lead to the coil, had too much potting/moulding material in its socket and so it was making poor contact, especially after driving over a rough patch of road - I'd noticed that for some reason, someone had jammed that lead under the HT lead at the coil, and it looked wrong - obviously at the Ford factory or at my supplying Ford dealership, car was only a couple of months old, I was just on my way to visit my wife a day after she delivered our first child! Anyway, in the OP's case, surely the AA is working as VW Group's "roadside support" during the car's first year or two from new - so they should always be working hand in hand with what is acceptable to VW Group dealership workshops. This is where the RAC and AA's mindset of "getting you moving again" gets slightly blurred and misses the mark when they are operating as a car marque's "new car roadside support during warranty" agent. As always, customer takes the hit!
  21. I tried to make use of the Autoglass warranty on an Ibiza, failed completely as they had replaced their "office management system" so all old records had been binned/dumped or just lost, it didn't matter that I still had the original paper copy from when they first repaired a small not very well a couple of years earlier - in my case there was no MOT issue, just blinking annoying to stare at while driving. I thought that that was a pretty lousy excuse for rejecting a warranty claim, maybe typical for modern UK businesses.
  22. Obviously my daughter's SEAT Leon Cupra is also auto (DSG) so maybe this is as good as it gets with modern DSG cars with Hill Hold / Hill Assist etc when used mainly in stop/go town traffic a lot.
  23. I had that on my 2000 VW Passat 4Motion when it was maybe 10 years old, 70,000 miles, VW main dealer tech said "if it was me I'd replace both sides" after confirming that it was front wheel bearing issue, I'm not sure that I could work out which end the noise was coming from, so that sorted out my problem and was exactly what I had asked the service desk to get done if it was a wheel bearing - ie do both sides. My wife's 2015 VW Polo 1.2TSI 110PS started doing that when it was maybe 7.5 years old, 40,000 miles(maybe), I bought a tool to do that job and once again played safe and bought and replaced both front wheel bearings. I know that you have thought that you had definitely worked out which side it was coming from, but maybe a better plan would have been to get both sides from the heavy end replaced first, in the case of my wife's 2015 VW Polo, it looked like there had been water ingress into the front RHS wheel bearing, though I couldn't detect any roughness from either of the removed bearings.
  24. Maybe depending on the engine power output - or maybe not, that car could have Mando front callipers, Mando seem to have been licensed to manufacture "same as" versions of established European brake parts, so maybe an issue with tolerances in there somewhere. It seems to be aftermarket Brembo brake pads that get bad press for causing knocking noises and that is put down to the type of steel backing plates that they make/sure, ie punched out using cheap and cheery presses. That info comes from someone that works in brake testing industry and is not made up by me. I'm not sure how aftermarket Pagid pads are made, so can't comment there, but I've used them in the past and would use them again on our cars as and when they need new brake pads, but Pagid from ECP, hummm, maybe a lesser or lower quality product in Pagid boxes - by mutual agreement.
