Everything posted by rum4mo
Any tips for getting the handbrake cable back...
That's a good idea, ie using a pair of gloves with something hard inside them, when I had or had reason to work on rear drum brakes, I tended to find that I was mainly working on them in winter, so after pressing down hard on the first retainer ring and rotating it with a bare finger, that finger was numb! I did have more success with a pair of pliers but even using that sensible method quite often ended up with nipping fingers when pliers slipped or everything going well but limited access meant that if the pin ended up rotating slightly, I'd run out of "rotating space"! I never ever failed to quickly get these retainers back on, but usually a bit of unnecessary physical pain was included, so I bought one of the tools designed for doing that job - then suddenly there were no cars in our family that had rear drum brakes to use that tool on! This is the sort of tool that was being referred to earlier by @VWD Sealey VS036 Drum Brake Shoe SPRING WASHER TOOL - Remove Install - Large & Small | eBay plenty other cheaper ones, I even bought a "hook" for refitting the big springs and so avoid using "wire and pliers".
Automatic locking system override
I’ve had one fitted to both cars for many many years, I’d think that the OP’s not planning on starting to use that sort of thing AFTER the emergency services have turned up - so in this case your comment is irrelevant. They are intended, I’ve always assumed, to be used as a form of “self help” before outside help turns up.
Clutch pedal hits the floor
Anyone know what is so different about this "size" of SUV and its hatch etc cousins across the VW Group marques that makes this issue something that "will" happen eventually to most owners - at least for people that run the "mid engine powered" versions?
Strange, I've never ever had any problems getting the handbrake cable end "block" over the calliper handbrake lever, so always used a suitable screwdriver to ease it over the lever - which will start moving the lever in the right direction - and I keep the handbrake in good adjustment, ie making sure that there is the required clearance between the lever and the stop when the handbrake is "off". I'm writing this in the hope that it stops you needing to mess about with the cable adjustment, for no other reason. Or, did you write "brake calliper" in error if your car has rear drum brakes?
Front brakes Fabia Monte Carlo
If, and only if, the front brake callipers have a vertical spring (looks like a wire) running down the edge of the calliper body, then I'd think that they will be 288mm and so ATE FN3 (54mm pistons).
Corroded rear discs
This request to replace the rear discs and pads could have worked if you had it a condition on buying that car at the agreed price, now as you seem to have agreed the price, I would not expect that dealer to be willing to spend any of their money on it now. As said earlier, rear discs on these cars do or can end up in that condition easily, if/when you replace these discs(and get new pads), if you chose say Pagid discs, then I'd expect that they would not "blacken up" quite as quickly as the original Skoda discs. My oldest daughter's May 2019 SEAT Leon Cupra has horrible looking black rear discs, and I've already had to replace the rear brake pads as they wear down quickly probably due to the enhanced braking safety functions on that car, right now its mileage is only roughly 24,000 miles, my youngest daughter's May 2019 SEAT Arona 1.0TSI 115PS also has horrible black rear discs and well used rear pads at roughly 31,000 miles - if possible, I'd like to replace her car's rear discs and pads if/when they visit us, MOT testers have not yet made any comments on the state of these rear discs on either car as they probably know that they will still still function as intended - and there is a lot of it about due to the reasons given already. Good Luck with getting that dealer to replace them probably using aftermarket brands, like Pagid, before you collect it though! (if you don't ask you don't get)
Bushes lower arms Fabia Mk3 ADVICE
I'm guessing that you don't have the TSI engine versions then. I used to get my 2011 Audi S4 MOT'd at the local Audi garage, basically as they would be in a better position to immediately or quickly get and replace any failed parts. That only worked until its second MOT from new, ie 2015 then I got advisories on a few front suspension bushes, which when I examined them, all looked to be in very good condition! So maybe 9.5 years later, I'm considering replacing a couple of these bushes, but I'm now using a VW Group Indie for MOTs and they have yet to pass out any advisories. I agree with AG Falco, nothing to bother about yet and I'm surprised that an honest MOT tester has passed comments on these bushes in that condition. I do intend to replace them on both sides on my wife's 2015 VW Polo 1.2TSI before its next MOT in August.
- Kamiq MY2024 airbag problem
Does the 1.5 TSI Have Rear Disc Brakes?
I agree with the above and I similarly have been making sure that I avoid buying VW Group cars that don't have rear disc brakes. since 2000, and yes I do all my own brake servicing.
- Left hand indicator being odd.
Antifreeze (Coolant)
With a car this new, why take risks, just buy a 1 litre container of pre-mixed (50/50) G12evo from any VW Group dealership. I'd doubt if Halfords etc are up to date with truly 100% compatible coolant for this age of VW Group car.
Rear caliper mounting bolts
Are the bolts for fixing the calliper fist to the calliper carrier not just item "3" in the first parts diagram, and the bolts fixing the calliper carrier to the hub bracket not item "13" again in the first parts diagram?
Windscreen washers not working
The control stalks on this model of Polo/Ibiza/Fabia and even maybe A1 tend to be "not very good" - I've yet to discover that personally but it sounds like maybe you have! Maybe attempt to take the relevant section of the stalk apart and see if it looks like it has failed/burnt contacts, then see if a good clean up gets it back working.
- 29 replies
- fuses
- mk3
- screenwash
- washers
Tagged with:
Rear shock heads up
The answer that I got when I queried the movement of an item being sent via Evri was, "a very short time is given for an item passing through a main handling hub", so after "its clock" has run out, that package tends to get either returned to sender, binned as waste or added to an auction list of packages, which, for their business model, probably makes good sense. For us waiting at the other end, not so good, to be fair though, I was very surprised that Evri was interested in talking to me as I was not the original sender - so not their customer, but I felt that I had to do that as my supplier was just taking the line "oh it will turn up soon" and even got grumpy when I advised them that Evri had accepted that that package was officially listed as "lost in transit" . That package laid low for maybe 6 weeks, then started moving out of the first hub and stuttered around the country, showing up on my door step maybe 2 months later, by that time the tracking number been deleted and then re-appeared again, very strange, my trader had quickly handed me back my money after I demanded to know what their next planned move was though, maybe 3 weeks after I paid for that item. That also happened to something that I bought in from China - I was only doing that as UK suppliers don't want to sell small volumes of some stuff to UK residents without charging an absolute fortune, that time it was Hermes that were handing the UK side of the couriering, package came in on time, passed through customs okay, got to Hermes main hub for incoming goods from abroad, then did not move for 2 days, then the tracking record was removed, turned out that it had been returned to my supplier in China who was no longer interested in that sort of nonsense, so I needed to find another supplier in China again - well ebay found another seller, and it worked out okay that time.
Mystery Symbol on Dash
Ah, so you’ve organised a new bit, I must have started writing that post while you were posting!
I was wrong there, it is not LED on Fabia, a WY5W 12V 5W yellow/orange bulb. p/n for RHS is 6V0 949 102. LHS is 6V0 949 101 that is for the clear plastic part. Edit:- if you are into looking at VW Group parts listings it can be found in the “body” section, so 941 - 040 items 30 and 31(for the bulb).
In case you didn’t know, these mirror assemblies are made up from a few individual parts that can be bought separately. From memory there is a plate/frame and the LED inductor lump/strip of clear plastic. I needed to buy the above parts and a cap when someone smashed one on my wife’s 2015 VW Polo. The old guy was driving a VX Corsa and his mirror also got wrecked and swung round and through his side window - that would have wakened up and caused him to move back across to his side of the road!
Rear seats
"typically", you just lift the front edge of the rear seat bases, and I seem to remember, pull it forwards slightly, then grab the rear of the base and fold it forward - that is the way it is done in a 2015 VW Polo anyway. Seat bases can easily get removed if that improves the space for carrying stuff - doing that doesn't allow the the seat back to drop any lower at the pivot though - obviously.
Replacement NSR caliper issue
I my world, with these Lucas rear callipers, you do need to remove these 2 bolts to service the rear brakes, unless "servicing" is just spraying some brake cleaner in. I was going to suggest that the copper sealing washers on the banjo bolt look to be too thick, but seeing the difference in the same measurement side to side in the pictures, what I was considering to be thicker washers, just pales into insignificance. So far the worst thing that I have had when buying a re-manufactured rear Lucas calliper was what looked like a "garden shed" job of repairing a stripped bleed valve hole - I just handed that otherwise okay calliper back. Edit:- this makes me think that I should take a look at the one I fitted a couple of months ago, seeing as the fluid line was the bit I did last - I had filled up the calliper with fresh fluid before putting the fluid line back on - just to displace as much air as possible, as I just bleed it using a Mityvac hand pump after removing my sealed cap from the reservoir. Maybe it has a different size of piston, ie meant for another car, if so another reason to return it. I think that there were 34mm and 38mm versions of that model, and just maybe 41mm pistons. The pistons on my wife's 2015 VW Polo 1.2TSI were 38mm, I wasn't that trusting, I measured both piston sizes of the original calliper and the re-manufactured one. Plus I went over the new calliper with a digi calliper to check what I considered to be all relevant measurements.
Just done car Service.
I spotted some chunky bits of rust on the garage floor on Saturday when I opened the garage door to drive my wife's August 2015 VW Polo 1.2TSI 110PS with 49,000 miles, back in! It didn't take much guessing to consider that it was (finally) time to replace the clamps on the mid point exhaust joining piece - which I had bought almost 2 years ago as NOS VW Group part. So, yesterday, I picked off the broken/rusted through clamp and unbolted the almost broken/rusted through other clamp, and opened up the new clamps harvested from that new joining piece and fitted them over the old original stainless steel split joining part. All done BEFORE the exhaust had worked itself loose from the joining piece - result! I was a bit surprised that I had managed to remove the clamping bolt from the "just still intact" clamp, but the "special release juice" seemed to work well. Edit:- PlusGas!
Rear brakes get stuck over night
I'd hope that if you have had a look at one side with the drum of, then you will know where to expect to find the wedge on the other side - if the one you have already got the drum off is closer to the rear of the car, the one on the other side will once again be closer to the rear of the car - obviously if I'm wrong and the one that you got the drum off was nearer the front of the car, then so will the wedge on the other side. I'm guessing that you have got the drum free from being gripped by rust on the hub? If you fight this too much without backing off the adjustment via the wedge, then you might just be tilting over a shoe or shoes - and that will just make things trickier to get that drum off.
Spare Wheel (again)
At least if you fit the spare wheel down into the wheel well and secure with the correct bolt thing, and same for the tools kit, it will not be free to "come and get you" if you are unfortunate enough to be involved in an event where the car gets rolled over.
Power steering fluid location
I’d think that your car has an electric steering rack, but that is just a guess as the Ibiza and Polo had changed to that by the time period covering this model of Fabia.
Replacing the alternator (Generator?) in a Fabia
Tapping the alternator might be freeing up the small carbon brushes that are either sticking in their holders due to a build up of carbon dust, or the same issue and they have worn down so are now too short to be useful. I due to the huge cost difference, when the alternator on my older daughter’s 2009 SEAT Ibiza 1.4 went badly faulty - stopped charging, I gambled on buying a reconditioned Bosch one same O/P but with a slightly small pulley diameter - that worked out okay for that car. On your alternator the brushes are probably part of the regulator pack which can easily be replaced, you could hope that the slip rings that they connect with when in use are still serviceable. Normally it is shaft bearings that out an alternator out of use, but maybe your ones are still okay.
