Carlston
Everything posted by Carlston
  1. mytyres are listing an Alcar 6665 6Jx16 ET43 5/112 57.1 steel rim for the Karoq. https://www.mytyres.co.uk/rims/details?vehicleId=1273838646642300016&rimCode=ALCAR6665 However, the 215/60R16 tyre size isn't cheap. A cheaper option is a 205/70R15 tyre fitted to an Octavia MK3 or MK4 steel rim such as Alcar 4755 and Alcar 7755 6Jx15 ET43 5/112 57.1 which could be used as a space saver tyre fitted to the rear. The 15" rim is unlikely to clear the front brake calipers, so put the 15" spare on the rear only. Alcar 4755 6Jx15 ET43 5/112 57.1 Steel Rim (from VW Golf MK8/Skoda Octavia MK4) https://www.mytyres.co.uk/rims/details?vehicleId=1229371647597745264&rimCode=ALCAR4755 Vredestein Quatrac 5 205/70R15 96T https://www.mytyres.co.uk/rshop/tyre/Vredestein/Quatrac-5/205-70-R15-96T/R-281259 Karoq Spare Wheel Kit https://eshop.skoda-auto.cz/cs_CZ/sady-pro-vymenu-kol/c/setsToChangeWheels?q=%3AscoreDesc%3AcarType%3AKaroq%2B%282017%2B%29&text=# It looks like the 4x2 Karoq uses a skinny 125/70R18 space saver rather than a full size spare wheel.
  2. Because of the 8J wide rims stretching the sidewalls to the max, even the ET35 could rub. Even if they didn't rub straight away, would you want a tiny gap that could end up rubbing in the future...perhaps after bushings and bearings etc. start to wear and change the clearance. It could work out expensive if you find that you can't use your rims because of rubbing. Audi A1 rims might be more suitable. 7.5Jx17 ET34 and 7.5Jx17 ET36 are listed on the "vw online parts catalogue". http://www.oemepc.com/audi/part_single/catalog/au/markt/RDW/modell/A1/year/2016/drive_standart/792/hg_ug/601/subcategory/601070/part_id/254951/lang/e
  3. "skoda eshop cz" shows a 205/40R17 on a 7Jx17 ET41 as a standard option on the Fabia MK2. https://eshop.skoda-auto.cz/cs_CZ/hlinikove-disky/c/alloyWheels?q=%3AscoreDesc%3AcarType%3AFabia%2BII%2B%282010-2014%29&text=# So fitting 205/40R17 on 8Jx17 ET30 is similar to adding 10mm wheel spacers to the standard rims as far as the positioning of the centre of the tyre in relation to the bodywork goes. 8J is stretching the 205/40 tyres to the max, so won't give the rims much protection from kerbing damage, and the stretched sidewalls will give quite a hard ride. ET30 does seem a bit extreme, but maybe that's the point. ET35 would be less likely to rub and/or have the tyres stick out past the edge of the bodywork.
  4. VW Codes Decoder http://igorweb.org/equidec.aspx 1JB = Rear shock absorption for rough-road design rear axle | Skoda Superb 2010, suspension shock absorber (spring cyl.) for models with heavy duty suspension PR-1JB http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/SUP/year/2010/drive_standart/632/hg_ug/511/subcategory/511020/part_id/2561497/lang/e Rear Springs 1 1K0511115CL coil spring 1 paint mark 1 paint mark rear red orange Model data: PR-0YA (1) 1K0511115CM coil spring 1 paint mark 1 paint mark rear red orange Model data: PR-0YB (1) 1K0511115CN coil spring 1 paint mark 2 paint marks rear red orange Model data: PR-0YC (1) 1K0511115DJ coil spring 1 paint mark 3 paint marks 1 paint mark rear red orange brown Model data: PR-0YD (1) 1K0511115DK coil spring 1 paint mark 1 paint mark 1 paint mark rear red green brown Model data: PR-0YE (1) 1K0511115CR coil spring 1 paint mark 2 paint marks red green Model data: PR-0YF (1) 1K0511115CS coil spring 1 paint mark 3 paint marks red green Model data: PR-0YG (1) 1K0511115CT coil spring 1 paint mark 1 paint mark rear red brown Model data: PR-0YH (1) 1T0511115AB coil spring 2 paint marks 2 paint marks red yellow Model data: PR-0YJ (1) 1T0511115AC coil spring 2 paint marks 3 paint marks red yellow Model data: PR-0YK Rear Shock Absorbers 7 3C0513049BN gas shock absorber for models with heavy duty suspension rear Model data: PR-0YB,0YC, 0YD,0YE,0YF (7) 3C0513049BP gas shock absorber for models with heavy duty suspension rear Model data: PR-0YK,0YH, 0YJ Three rear springs that you might want to select from are the weight range 6, 7, and 8 rear springs. Weight Range 6 Rear Spring 1K0511115CR Wire Diameter 12.5mm, Length 380mm, Weight 2.4kg https://web.tecalliance.net/gkn/en/parts/1/86359/detail?query=1K0511115CR&numberType=1&oe=1K0511115CR#@brc/search:Search%20by%20any%20number%201K0511115CR;query:1K0511115CR;page:0/detail:86359;brandId:1;articleNo:86359;query:1K0511115CR;numberType:1;oe:1K0511115CR Weight Range 7 Rear Spring 1K0511115CS Wire Diameter 12.75mm, Length 382mm, Weight 2.6kg https://web.tecalliance.net/gkn/en/parts/1/86501/detail?query=1K0511115CS&numberType=1&oe=1K0511115CS#@brc/search:Search%20by%20any%20number%201K0511115CS;query:1K0511115CS;page:0/detail:86501;brandId:1;articleNo:86501;query:1K0511115CS;numberType:1;oe:1K0511115CS Weight Range 8 Rear Spring 1K0511115CT Wire Diameter 13mm, Length 383mm, Weight 2.8kg https://web.tecalliance.net/gkn/en/parts/1/87414/detail?query=1K0511115CT&numberType=1&oe=1K0511115CT#@brc/search:Search%20by%20any%20number%201K0511115CT;query:1K0511115CT;page:0/detail:87414;brandId:1;articleNo:87414;query:1K0511115CT;numberType:1;oe:1K0511115CT KYB RH6426 matches 1K0511115CT https://www.autodoc.co.uk/kyb/825745 https://www.ebay.co.uk/itm/223591301666?hash=item340f148222:g:MdAAAOSwpc5dMCXZ
  5. Here are three 16" steel rims listed on mytyres that would fit the Fabia. Alcar 6664 6Jx16 ET35 5/100 57.1 Steel Rim https://www.mytyres.co.uk/rims/details?vehicleId=1087670437300671588&rimCode=ALCAR6664 Alcar 6977 6Jx16 ET40 5/100 57.1 Steel Rim https://www.mytyres.co.uk/rims/details?vehicleId=1087670437300671588&rimCode=ALCAR6977 Alcar 9680 6.5Jx16 ET42 5/100 57.1 Steel Rim https://www.mytyres.co.uk/rims/details?vehicleId=180340247920546916&rimCode=ALCAR9680
  6. The Fabia MK3 uses 215/45R16 not 205/45R16. It's easy enough to fit 205/55R15 instead of 185/60R15 to the 6Jx15 ET38 rims. Uniroyal Rainsport 5 205/55R15 88V https://www.camskill.co.uk/m53b0s289p188338/Uniroyal_Tyres_Car_Uniroyal_RainSport_5_-_205_55_R15_88V_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_A_NoiseClass%3A_2_Noise%3A_71dB However, 195/60R15 might be preferable to 205/55R15 as it's a more common and cheaper tyre size. There's a lack of choice in the 205/55R15 size, especially good all-season tyres. Vredestein Quatrac 195/60R15 88H https://www.camskill.co.uk/m138b0s7993p202144/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac_6_-_195_60_R15_88H_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_2_Noise%3A_70dB
  7. At 12kg, these heavy alloy rims are somewhat heavier than the 10.5kg 6.5Jx17 ET38 steel rims from the Kodiaq. 7Jx17 ET45 https://eshop.skoda-auto.cz/cs_CZ/kolo-z-lehke-slitiny-erebus-17-pro-yeti/p/5L0071497J+8Z8
  8. Spare wheel replacement kit (1025CZK about £34.37) Intended for: OCTAVIA IV OEM part number: 5E3093860 Not intended for vehicles with ŠKODA Sound system equipment (subwoofer in spare wheel). https://eshop.skoda-auto.cz/cs_CZ/sada-pro-vymenu-rezervniho-kola/p/5E3093860 Complete spare wheel 18" (3586CZK about £120.22) Intended for: OCTAVIA IV OEM part number: 5E3601011B Not intended for cars with hybrid drive (OCTAVIA iV) and CNG (G-TEC). https://eshop.skoda-auto.cz/cs_CZ/kompletni-rezervni-kolo-18/p/5E3601011B The above spare wheel is a space saver and has specification 3.5Jx18 ET25.5 fitted with a 125/70R18 99M tyre. Speed limited to 50mph when using a space saver.
  9. The outside diameter of 225/35R17 is the same as 225/40R18 and 225/35R19, so they all fill the wheel arch the same amount. Because of the 340mm diameter front brake discs on the vRS 245HP, 17" rims are the smallest diameter that will clear the front brake calipers. Changing to 225/45R17 will make a big improvement to ride comfort, especially if fitted to relatively narrow 7J rims and carefully choose tyres that have soft, flexible sidewalls. 205/50R17 would ride even better than the wider 225/45R17, and could be fitted to 6.5Jx17 ET38 rims. The Goodyear EfficientGrip Performance 2 in size 205/50R17 93W doesn't have thick rubber rim protection moulded into the sidewalls, which should make the sidewalls flex more easily. The Goodyear EfficientGrip Performance 2 should also ride more comfortably than the Goodyear Eagle F1 Asymmetric 5 as it's not trying to be the ultimate performance tyre. Goodyear EfficientGrip Performance 2 205/50R17 93W https://www.camskill.co.uk/m54b0s304p188360/Goodyear_Tyres_Car_Goodyear_EfficientGrip_Performance_2_-_205_50_R17_93W_XL_TL_Fuel_Eff_%3A_B_Wet_Grip%3A_A_NoiseClass%3A_1_Noise%3A_69dB Another option, could be 6Jx17 ET48 rims fitted with either 205/50R17 or oversize 205/55R17. https://eshop.skoda-auto.cz/cs_CZ/kolo-z-lehke-slitiny-crystal-17-pro-octavia-iii/p/5E0071496A+8Z8 https://eshop.skoda-auto.cz/cs_CZ/kolo-z-lehke-slitiny-crystal-17-pro-octavia-iii/p/5E0071497E+FL8 Skoda Octavia 2020 2.0TDI 150PS – Generation: Mk3 A7 (5E) Facelift [2017 .. 2020] – Market: EUDM – Power: 148 hp | 110 kW | 150 PS – Engine: 2.0L, CKFC, I4, Diesel – Options: SE L, Ambition, Executive, Style, L&K – Center Bore: 57.1 mm – PCD: 5x112 – Wheel Fasteners: Lug bolts – Wheel Tightening Torque: 120 Nm – Thread Size: M14 x 1.5 – Trim Production: [2017 .. 2020] Tire Rim 205/55R16 91V 6Jx16 ET48 2.2 205/55R16 91V 6.5Jx16 ET46 2.2 205/50R17 93V 6Jx17 ET48 2.2 225/45ZR17 91Y 7Jx17 ET49 2.2 225/40ZR18 92Y 7.5Jx18 ET51 2.2 225/35ZR19 88Y 7.5Jx19 ET51 2.2 https://www.wheel-size.com/size/skoda/octavia/2020/#trim-20tsi-eudm-241
  10. Light alloy wheel SHELL 14 "for ROOMSTER, FABIA II 6.0Jx14 ET37 https://eshop.skoda-auto.cz/cs_CZ/kolo-z-lehke-slitiny-shell-14-pro-roomster-fabia-ii/p/5J0071494C+7ZS Sheet metal disc 14 " 6Jx14 ET37 https://eshop.skoda-auto.cz/cs_CZ/plechovy-disk-14-/p/6Q7601027C+03C Skoda Fabia 2005 1.9TDI – Generation: Mk1 (6Y) [1999 .. 2007] – Power: 99 hp | 74 kW | 101 PS – Engine: 1.9L, ATD/AXR, I4, Diesel Tire Rim 165/70R14 82T 6Jx14 ET37 2.4 185/60R14 82H 6Jx14 ET37 2.3 / 2.4 195/50R15 82H 6Jx15 ET43 2.2 / 2.3 195/45R16 82V 6.5Jx16 ET43 2.2 / 2.3 205/45R16 82V 6.5Jx16 ET45 2.1 / 2.2 205/40R17 82V 7Jx17 ET45 2.1 / 2.2 Skoda Fabia 2005 vRS 1.9TDI – Generation: Mk1 (6Y) [1999 .. 2007] – Power: 129 hp | 96 kW | 131 PS – Engine: 1.9L, ASZ/BLT, I4, Diesel Tire Rim 195/50R15 82V 6Jx15 ET43 2.2 / 2.3 195/45R16 82V 6.5Jx16 ET43 2.1 / 2.2 205/45R16 82V 6.5Jx16 ET45 2.1 / 2.2 205/40ZR17 82W 7Jx17 ET45 2.1 / 2.2 185/60R14 on 6Jx14 ET37 rims is a Skoda approved size for the Fabia 1.9TDI 101PS. However, 185/65R14 would also work well and is a Skoda Roomster approved size. Dunlop Sport All-Season 185/65R14 86H https://www.mytyres.co.uk/rshop/tyre/Dunlop/Sport-All-Season/185-65-R14-86H/R-435489 The Dunlop Sport all-season tyre is non-directional, so the spare wheel can be fitted in any position. If your car came with 165/70R14, then you will notice a lot more grip from either 185/60R14 or 185/65R14.
  11. As you can see from the chart below, 205/40R17 fitted to 7Jx17 ET45 5/100 57.1 rims should fit. Skoda Fabia 2005 1.9TDI – Generation: Mk1 (6Y) [1999 .. 2007] – Power: 129 hp | 96 kW | 131 PS – Engine: 1.9L, ASZ/BLT, I4, Diesel – Options: vRS – Center Bore: 57.1 mm – PCD: 5x100 – Wheel Fasteners: Lug bolts – Wheel Tightening Torque: unknown – Thread Size: M14 x 1.5 – Trim Production: [2003 .. 2007] Tire Rim 195/50R15 82V 6Jx15 ET43 2.2 / 2.3 195/45R16 82V 6.5Jx16 ET43 2.1 / 2.2 205/45R16 82V 6.5Jx16 ET45 2.1 / 2.2 205/40ZR17 82W 7Jx17 ET45 2.1 / 2.2 https://www.wheel-size.com/size/skoda/fabia/2005/#trim-19tdi-eudm-129
  12. Bilstein B8 24-229937 is for multilink rear suspension. I doubt the 150HP has multilink rear suspension. https://www.autodoc.co.uk/bilstein/7522727 Bilstein B8 is for lowered/sports suspension. Bilstein B6 is for standard ride height suspension. Both Bilstein B6 and B8 are high performance dampers, ie. expensive. The more regular Bilstein B4 shock absorbers are about half the price of Bilstein B6 and B8 shock absorbers, and adequate for most people.
  13. 205/65R16 is not the correct one for the Superb MK3. The outside diameter of 205/65R16 is about 1.3% bigger than the standard 215/60R16. The actual widths of the above two tyre sizes varies depending on the widths of the rims that they are fitted to. Shown below is a 205/65R16 fitted to a 6J rim. Notice that the Overall Width is 209mm. PROXES CF2 New Proxes CF2 has been created to take advantage of the latest materials, structures and tread pattern design in order to guarantee a high level of safety, durability, savings, and comfort. Tire Size Tread Depth (mm) Overall Diameter (mm) Overall Width (mm) Approved Rim Width Range (inch) 205/65 R16 95V 8.6 672 209 5.5-6-7.5 https://www.toyo.co.uk/tirefinder/index/width/205/aspect/65/rim/16 However, when a 205/65R16 is fitted to a wider 6.5J rim the actual width of the inflated tyre becomes not surprisingly wider too (about 215mm wide). In comparison, a 215/60R16 fitted to a 6J rim is also about 215mm wide. So both a 205/65R16 fitted to a 6.5J rim and a 215/60R16 fitted to a 6J rim are both about 215mm wide, ie. about the same width. If you were to fit a 215/60R16 to a much wider 7J rim, it would become about 225mm wide, ie. a 215/60R16 fitted to a 7J rim is about 10mm wider than a 205/65R16 fitted to a 6.5J rim.
  14. Swap the front and rear wheels over. If the steering wheel vibration goes away, the problem is one or both of the front wheels (which are now on the back).
  15. The actual width of a 205/55R16 tyre fitted to a 6.5J rim is about 215mm, not 205mm. The actual width of a 215/60R16 tyre fitted to a 6J rim is about 215mm, and the actual width of a 215/60R16 tyre fitted to a 6.5J rim is about 221mm. So try a 215/60R16 tyre fitted to a 6J rim, it should fit. The width of an inflated tyre is measured from sidewall to sidewall. The width of the tyre is not the tread width, which is less than the sidewall to sidewall width. PROXES T1 SPORT The reference sports tyre. Aspect Ratio: 30/35/40/45/50/55 Tire Size Tread Depth (mm) Overall Diameter (mm) Overall Width (mm) Approved Rim Width Range (inch) 205/55ZR16 94W XL 8.3 629 215 5.50-6.5-7.50 https://www.toyo.co.uk/tirefinder/index/width/205/aspect/55/rim/16 Superb MK3 16" Spare Wheel Kit (not including spare wheel) https://www.skoda-parts.com/spare-part/3v0093860-spare-wheel-replacement-kit-skoda-33940.html Alcar 9490 Steel Rim 6Jx16 ET40 5/112 57.1 https://www.mytyres.co.uk/rims/details?vehicleId=180505174664549488&rimCode=ALCAR9490 https://www.oponeo.pl/felga-stalowa/alcar-kfz-9490#20242538 The Superb MK3 220HP might have 340mm diameter front brake discs. If so, then 16" rims won't clear the front brake calipers. You can use a 16" spare on the rear and swap a 17" or bigger rear wheel to the front (as a get you home measure).
  16. I would avoid using wheel spacers that aren't hub centric, and you can't get hub centric wheel spacers that are less than 10mm. So the 5mm wheel spacers aren't hub centric. Hub centric wheel spacers have a spigot to centre the wheels exactly on the hubs. By using wheel spacers that aren't hub centric you risk the wheel not being exactly centred on the hub, which will cause vibration. Maybe consider 10mm hub centric wheel spacers front and rear. This will have the effect of changing the rim offset from the current ET48 to ET38. I would want my wheel bolts to have between 6 and 10 turns. If it's more or less than this, look at buying longer or shorter wheel bolts. They are usually available in 5mm increments, such as lengths of 25mm, 30mm, 35mm, etc. Eibach Pair of 10mm Pro-Spacer Wheel Spacers https://www.demon-tweeks.com/eibach-pair-of-10mm-pro-spacer-wheel-spacers-kit-eibes90-2-10-027/?istCompanyId=a2904180-3a7d-4e56-b876-cf81c9512180&istFeedId=0f6db192-3a9a-4369-b1f8-79615c622f96&istItemId=wptpwmmll&istBid=t&awaid=6538&utm_source=redbrain&utm_medium=shopping&utm_campaign=css&gclid=EAIaIQobChMIsNnCndOB8QIVsuHmCh1TGwcYEAYYBCABEgK2pPD_BwE
  17. Skoda Octavia MK1 Estate 1.9 TDI 66kW 4x4 https://web.tecalliance.net/gkn/en/parts/cars/assigned?assemblyGroupId=100113&targetId=12243&typeNumber=12243&groups=188&brands=1&page=0#@brc/brands:Car;targetType:cars/assem:SKODA%20OCTAVIA%20I%20Combi%20(1U5)%201.9%20TDI%204x4;targetType:cars;targetId:12243;typeNumber:12243/lnkparts:Coil%20Springs;targetType:cars;assemblyGroupId:100113;targetId:12243;typeNumber:12243;groups:188;brands:1;page:0 Front Springs 1J0411105AF Spring Design Coil spring with constant wire diameter Fitting Position Front Axle Colour Coding Violet, Yellow Wire Diameter 12.5 mm Length 354 mm Outer diameter 142 mm Weight 2.15 kg (1) 1J0411105AF coil spring for models with heavy duty suspension 1 paint mark 1 paint mark violet yellow Model data: PR-G07/L06 PR-G40/L06 http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2001/drive_standart/252/hg_ug/411/subcategory/411005/part_id/2561497/lang/e Sachs 997616 https://www.ebay.co.uk/itm/223670056870?hash=item3413c637a6:g:dRwAAOSwiQxdgd64 Rear Springs 1J9511115D Spring Design Mini Block Fitting Position Rear Axle Colour Coding Orange (5x) Wire Diameter 10.3 mm Wire Diameter 1 16.7 mm Wire diameter 2 10.3 mm Length 233 mm Outer diameter 148 mm Weight 2.5 kg 1 1J9511115D coil spring 5 paint marks orange Model data: KOMBI http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2001/drive_standart/252/hg_ug/511/subcategory/511015/part_id/2561497/lang/e Sachs 994196 https://www.ebay.co.uk/itm/224174529422?hash=item3431d7db8e:g:ig8AAOSwa4xde0fw
  18. That kit looks like this one from the Octavia MK3 Scout. 1050CZK is about £35 https://eshop.skoda-auto.cz/cs_CZ/sada-pro-rezervni-kolo-octavia-scout/p/5E0093860D It's being sold for an Octavia MK3 Scout so maybe you need at least a 17" rim. I would try something like this from the standard Octavia MK3. However, I don't know if it will fit the Superb MK3. https://eshop.skoda-auto.cz/cs_CZ/sada-pro-vymenu-rezervniho-kola-pro-octavia-iii/p/5E0093860B Then maybe you could use a 195/65R15 6.5Jx15 ET43 spare wheel from the Octavia MK3 (or Vredestein Quatrac 5 205/70R15 6.5Jx15 ET43) https://eshop.skoda-auto.cz/cs_CZ/kompletni-rezervni-kolo-16/p/5E0601011J You wouldn't be able to use a 15" spare wheel on the front of a Superb MK3 as it won't clear the brake calipers, so use a 15" spare on the rear only. Some of the more powerful Superb MK3's have rear brakes discs with a diameter bigger than 288mm. If the rear brake discs have a diameter bigger than 288mm, at least a 16" spare wheel would be needed.
  19. One easy test if you have digital calipers, is to measure the wire diameter of the front and rear springs. In addition to the four standard ride height rear springs that I posted above, there are another six listed on the "vw online parts catalogue". 1 3Q0511115M coil spring Model data: PR-1JA+0YE 1 3Q0511115N coil spring Model data: PR-1JA+0YF 1 3Q0511115P coil spring Model data: PR-1JA+0YG 1 3Q0511115Q coil spring Model data: PR-1JA+0YH 1 3Q0511115R coil spring Model data: PR-1JA+0YJ 1 3Q0511115BC coil spring Model data: PR-1JA+0YK The last three aren't listed on autodoc. This isn't unusual as aftermarket springs aren't available to match all OEM part numbers. However, the three standard ride height rear springs from the list above do have their specifications listed on autodoc, as detailed below. 3Q0511115M (Diameter 12.50mm, Length 366mm) https://www.autodoc.co.uk/spares-search?keyword=3Q0511115M&supplier[0]=85 3Q0511115N (Diameter 13.25mm, Length 361mm) https://www.autodoc.co.uk/car-parts/oem/3q0511115n?search=OEN+3Q0511115N&supplier[0]=85&supplier[1]=1 3Q0511115P (Diameter 13.50mm, Length 361mm) https://www.autodoc.co.uk/car-parts/oem/3q0511115p?search=OEN 3Q0511115P It looks like 3Q0511115Q, 3Q0511115R, and 3Q0511115BC are incrementally stiffer than 3Q0511115P as you can see from decoding 0YG, 0YH, 0YJ, 0YK Decoding 0YG, 0YH, 0YJ, 0YK Build Codes 0YG = Weight range 7 0YH = Weight range 8 0YJ = Weight range 9 0YK = Weight range 10 You might have trouble finding the OEM part numbers from the coloured dots, as the "vw online parts catalogue" doesn't appear to list the above rear springs against the coloured dots. In addition to the front and rear springs, you might want to look to see if there are different thicknesses of anti-roll bars. However, if you have 13.5mm diameter rear springs you might already have the thicked anti-roll bars. But I'm just guessing about this as I haven't done any research on anti-roll bars for the Passat.
  20. Have you got the OEM part numbers of the front and rear springs? Here are 4 of the standard ride height rear springs shown on the "vw online parts catalogue" for the 2016 VW Passat. The build code 1JA means that these springs are standard ride height. Build code 1JC would mean that they are sports springs. The "vw codes decoder" can be used to find out what the build codes mean. "vw codes decoder" http://igorweb.org/equidec.aspx Four Standard Ride Height Rear Springs for the VW Passat 2016 1 3Q0511115AH coil spring Model data: PR-1JA+0YA 1 3Q0511115AJ coil spring Model data: PR-1JA+0YB 1 3Q0511115AK coil spring Model data: PR-1JA+0YC 1 3Q0511115AL coil spring Model data: PR-1JA+0YD http://www.oemepc.com/vw/part_single/catalog/vw/markt/RDW/modell/PA/year/2016/drive_standart/793/hg_ug/511/subcategory/511000/part_id/0/lang/e You can find the specification of each of these springs on autodoc. 3Q0511115AH (Wire Diameter 11.25mm, Length 363mm) https://www.autodoc.co.uk/car-parts/oem/3q0511115ah?search=OEN+3Q0511115AH&supplier[0]=1&supplier[1]=32&supplier[2]=85&supplier[3]=1&supplier[4]=32 3Q0511115AJ (Diameter 11.75mm, Length 361mm) https://www.autodoc.co.uk/car-parts/oem/3q0511115aj?search=OEN+3Q0511115AJ&supplier[0]=1&supplier[1]=32&supplier[2]=85&supplier[3]=1&supplier[4]=32 3Q0511115AK (Diameter 12.25mm, Length 364mm) https://www.autodoc.co.uk/car-parts/oem/3q0511115ak?search=OEN+3Q0511115AK&supplier[0]=32&supplier[1]=1&supplier[2]=85&supplier[3]=32&supplier[4]=1 3Q0511115AL (Diameter 12.50mm, Length 359mm) https://www.autodoc.co.uk/car-parts/oem/3q0511115al?search=OEN+3Q0511115AL&supplier[0]=85&supplier[1]=32&supplier[2]=1 So if you had 3Q0511115AK rear springs and wanted to go about 5% stiffer but with about the same ride height, then a change to 3Q0511115AL would do that.
  21. The Monte Carlo uses the same standard suspension as the other trim options. If in doubt, check the build codes. 1JA means standard suspension. 1JC means sports suspension. Skoda Fabia MK3 2016 Online Parts Catalogue http://www.oemepc.com/skoda/main_group/markt/CZ/modell/FAB/year/2016/hauptgruppen/1234567890/drive_standart/797/lang/e
  22. What is the tyre size? For example, 225/45R17 94V. What is the make and model. For example, Bridgestone Turanza T005. All these details are moulded into the sidewalls of the tyres.
  23. What tyre size are you using? Try fitting narrower tyres. This will force you to go round corners slower, resulting in less body roll. You might even have 280mm/288mm diameter front brake discs, in which case 205/70R15 could be used instead of 215/60R16. 15" wheels have never been fitted as standard to the Yeti, but many owners fit non-standard tyres/wheels to their cars. Vredestein Quatrac 5 205/70R15 96T (currently listed for £58.65 on camskill...so much cheaper than many of the other Yeti tyre sizes) https://www.camskill.co.uk/m138b0s7998p144823/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac5_Vredestein_Quatrac_5_-_205_70_R15_96T_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_C_NoiseClass%3A_2_Noise%3A_70dB 6Jx15 ET37 5/112 57.1 Alcar 8955 Steel Rim https://www.oponeo.pl/felga-stalowa/alcar-kfz-8955#19714600 6Jx15 ET43 5/112 57.1 Alcar 7755 Steel Rim https://www.oponeo.pl/felga-stalowa/alcar-kfz-7755#21964779
  24. The load index of 225/35R19 isn't high enough for the Superb MK2, as even the XL version is only 88 (560kg). The XL version of 235/35R19 has a load index of 91 (615kg), so should be ok.
  25. Search "4F0601025DE" on the "VW online parts catalogue" for the cars that this OEM part number is linked to. Catalog Model code Model Name Years Audi A6 Audi A6/Avant 2009 2010 2011 Audi A6Q Audi A6/S6/Avant quattro 2009 2010 2011 http://www.oemepc.com/tvn_result/search/tvn/4F0601025DE 4 4F0601025DE aluminium rim colour code: 8,5JX19H2 ET48 5/112 1H7 Model data: PR-F43
