fr1nklyn
Everything posted by fr1nklyn
  1. Ravenol VMP is pretty good oil - I also prefer it. It remains stable for long time and has high evaporation point. Unfortunately it became a little expensive in the last couple of years... 😕 I change it every 10-12k km/6-7k miles, but if you don't do so much start/stop traffic trips like I do, I believe it will even be good for 10k miles.
  2. I don’t know but you can hope for it, having in mind the DPF reaches 600-700 C during a regen. Keep in mind that regens always produce some slight burning smell, so don’t expect that to disappear completely.
  3. I did this twice for my 15 years experience with the diesel engines. Hopefully not, but… Just have it in mind
  4. Hey mate, wait a second, why do you try to drive with “hand brake is not fully disengaged”? Do you know what break pads brand was used by the mechanic - maybe the invoice could include it? There is usually rattling when some aftermarket brands are used on these cars, but not squeaking. It happens because some aftermarket pads are slightly smaller then the OEM ones. How many km have you driven since the pads change? Maybe they need to bed in a little more. A usually put a little copper grease on the “ears” of the pads and if there is rubber back sticker on the pad, I add some grease there as well(on the contacting points). This usually prevents squeaking. I see that you had changed the rear discs as well, try to bed them in on a safety place: Try to slow down from 30kmh to 10, then 50 to 10 and them 80 to 10. Something Ike that, without fully stopping in order to let the pads cool down. Repeat this several time. You may want to check for exact “break pads/rotors break in procedure”.
  5. Where did you sprayed the DPF cleaning foam because what you see behind the engine is the catalytic convertor? I haven’t tried such cleaning method but from the product name I suppose this needs to be sprayed in the DPF which is underneath the catalytic convertor. The problem with petrol is that it’s dry and the return fuel doesn’t lubricate the injectors and they get worn out, but hopefully for the few km you had driven, nothing happened. Next time add some 2T oil if you can’t remove the petrol immediately Try to force regen the DPF with the diagnostic software, ask the mechanic to try to do so.
  6. @captain uncertain I’m not sure are there irreplaceable bearings - I think there was a post in drive2.ru showing that each bearing has a part number. I will try to find that thread. @J.R. If I recall correctly dealer said that diff unit isn’t sold separately and needs to be bought together with the Haldex 😕 In either case, it’s most likely this bearing+new diff oil. And it’s not worth the price of a new unit. I just need to find who to replace it as the nearest place which does this is 500km from me..
  7. You don't want to see the price of it - sorry I don't have the part number, because I declined to pay 4000 euros. It's just a roller bearing which needs to be replaced and internal gaps to be adjusted according to specifications. A shop working on manual transmissions and differentials should be able to do the job for you. When they open the diff they will see the part number of the worn out bearing which in 90% of the cases is "LM 503349/QCL7C" according to my research in VW and Audi forums. It seems to be known issue... I'm trying to find a shop near me which can do the replacement for mine since I have the issue as well.
  8. Reviving this old thread, @Bushlake I know you haven’t been active in a while, but if you are still driving the car, can you share is everything alright with the diff since the rebuild? I am about to the the same on mine and am wondering should I rebuild it or look for a second hand one.
  9. Let them bed in. How often do you reverse? You’re overthinking it 😃
  10. EGR is rarely an issue on these cars, as it’s positioned after the DPF. I’m thinking about cleaning the DPF without dissembling, with Wurth or Presto’s foam sprays. And maybe to reset the DPF values to 20% after that.
  11. Mine also does this now on 150k km, but when I bought it on 100k, it used to regenerate every 400-500km.. I don’t think the DPF got clogged twice as fast for 50k km as it did for the first 100k. Have you visited the Skoda dealer since you bought the car? I suspect them for installing emission update as part of other work they did on the car. 🤨
  12. If it’s rattle due to the slightly lower size of the pads, it won’t go away regradless of the amount of grease you put. If it’s more like squeaking, let them bed in for some more time.
  13. My 2 cents are that @J.R.is right that many drain and fill the wrong hole as they are next to each other.. Second thing is, the noise and failure of these diffs is pretty common.. I’ve read a lot about them because mine does it as well and you will be surprised how unreliable component this is. Third bearings are also very common to fail and they don’t fail catastrophically, but just one of the layers wear out and that causes the noise. So traditional methods to determine is a noise caused by a bad bearing doesn’t always work, e.g. turning left or right to stop or significantly decrease the noise.
  14. You don’t have drive hard for passive regens to happen. Car needs a steady speed at 1800+ rpm or something like that, fuel above 1/4 tank, coolant above 75 C and driving for longer time in order to allow the exhaust to reach the required temperature(can’t remember how much exactly). Those conditions which are usually met on highway driving. Mine does it at around 45-60 minutes of highway driving. But most of the time car does active regens due to city driving and like @MarkyG82 I’ve never seen the DPF lamp on even though it does regen on every 100-150 miles. Just leave DPF to finish the active regen when possible and change the oil frequently. Don’t think about it much
  15. I don't think your DPF is clogged by your type of journeys, but on 200k km it certainly does regenerate more often which increases the fuel consumption with ~0,5-1L/100km. Again this isn't what you're experience as this isn't 20% consumption increase. I believe you know what "Italian tune up" means, you can try doing it
  16. Unfortunately different documentation is distributed in different countries.. And there the confusion comes from in the international forums (my Skoda is in my wife otherwise I would give you a picture of my book 😛 )
  17. It’s good that the belt has been replaced. If the pump was changed as well, that would be great! The interval in Bulgaria is 210k kms according to the manual of the car. Honestly speaking, last year the dealer said they have never seen snapped belt on this engines. (I think they said they had several 1.9 TDIs, but can’t recall) But the water pumps do fail every now and then. Sadly even the latest revisions still fail very often.. 😕 Local garage I really trust said the same.
  18. It's 5 years or 120/130 or even 140k miles for UK; there is no specific time interval and 210k kms for rest of the European countries.. And less mileage intervals for dust-rich countries but I don't recall exact numbers. Anyway, I bet that cambelt is due on this car based on UK recommendations, but it's worth checking its service history.
  19. I don't know exactly why, but if it requires rotation, there will most likely be a thread. If you force push it, you may damage that thread - that's my explanation. But I don't claim it's right
  20. Don't risk not turning rear pistons while pushing.. If it's hard at the beginning, try the following: 1. Open the brake fluid reservoir 2. Connect a hose to the brake bleeder with the other end in a bottle with brake fluid - like on this image, I used mineral water bottle and drilled its cap 3. Now pushing back the piston should be easy 4. Keep an eye on the brake fluid reservoir while pushing back the piston because it may require topping up! Sometimes only opening the brake fluid reservoir is enough. But in this case, you may need to remove some fluid from it while pushing the piston.
  21. Did you mean pushing it without turning it counterclockwise? This works for fronts, but rear ones need to be turned as well. The tool I shared and I have is very popular. The end which pushes the piston is two-sided - with smaller pins gap and with wider. If it doesn’t fit the piston, you turn it the opposite side. That’s it.
  22. I use the same rewind tool from years which originally was bought for Audi A3 8L('01), then used on Octavia Mk1, Audi A4 8E and two weeks ago used on my Octavia Mk3. Looks similar if not the same to this one https://www.screwfix.com/p/hilka-pro-craft-brake-caliper-rewind-tool/4119r . But honestly I don't remember where I bought it from.
  23. If you are talking about this one, it doesn’t meet any of the VW TL 774 G/J/L standards https://mannol-gcc.com/products_cat/operating-and-service-fluids/ Even if there is a yellow coolant meeting any of these standards, I would doubt that it’s exactly such coolant in the car. Saying this reminds me that sometimes coolant looks different color due to oldish plastic of the reservoir. So get so coolant in a cup if you can, and you will be sure. It’s never safe to mix yellow/green coolant with pink/purple one. Even though the color doesn’t mean anything these days, it’s still very common for the yellow coolants to be OAT where the pink ones are usually HOAT and these aren’t compatible.. Don’t try your luck. Get some coolant out and see is it yellow, if it is you decide to change it or to top up with some other yellow coolant.
  24. VW coolant colors are either pink or purple. Your car is running with incorrect coolant. Do not mix yellow/green coolant with pink/purple one! You have 3 options: 1/ Recommended: Find a reputable place to flush your system and remove the silica bag from the coolant reservoir. Or replace the reservoir if its model doesn’t allow easy removal. Them top up with with G12Evo coolant. The garage which does it should understand what it’s doing because the coolant system of EA288 engines is complicated and cannot be fully flushed that easily. 2/ Good: Same as above but without removing the silica bag. This hides a risk the bag to tear/split in the system and block your heater matrix. Then top up with G13 coolant. 3/ Ignore recommendations and top up with whatever yellow coolant you find.
  25. I also buy young second hand cars because of the price and life standard. One thing I would be concerned is the oil service intervals. The MK3 2.0 tdi has relatively weak oil rings and may have oil consumption due long service intervals. The second thing is the DPF which will be for cleaning/replacing - if not already, then soon. Not sure is it stick or auto: if stick, as mentioned already, have in mind that the DMF may need replacement; the DSG should be serviced 3x times for that mileage.
