Everything posted by fr1nklyn
Servicing
@MABRO I also like DIY jobs like you do, that’s why I registered in this forum actually I don’t use anything specific as a guide, but when I want to do something myself, I check more than one source then collect and filter the best of all of them. I use google, youtube, this forum, golf mk7 forum and audi forums as well. Our engines are from EA288 family used by A3 and Golf 7 as well, so don’t limit your search by skoda only. drive2.com is also a great place DIY stuff, you can you Chrome browser translate option. If you want good quality instructions on paper, you can pay 7 euros for an hour in Erwin system and download everything you need. Then I think you have to print it, because there is some kind of protection, but better check this thread about it
Servicing
You don’t need VCDS for the fuel filter, just top off with diesel when you replace the filter. I actually, top off with Liqui Moly Diesel Purge, because I rarely change the filter and want some fuel system cleaning. Not sure does it help or everything is in my head.. Lubricate the gasket with diesel as well. I used to purge my old 1.9TDI by turning on and off the ignition. Not sure is this applicable for the EA288 engines.
Scout Diff Oil
Rear diff requires about 1,5 liters 75w90 GL-5 oil. The front one about 900-1000ml again 75w90 GL-5. @fj1200a It’s possible that you didn’t drain the full amount or you didn’t fill the right amount. In both cases you have to double check it. You fill until the oil starts to drain from the fill plug. Be sure that you lifted not only the rear of the car, but also the front one in order to get the right amount of oil in the diff. If the noise hasn’t been observed after the Haldex oil change, but after diff oil change, so the issue is with dif. But since you’re there check both levels - the plugs are very close to each other. Check this post and the video link few comments after:
Strange engine sound
@BATI2TAThank you very much for the feedback! This will save money to many of us wondering would the oil pump change fix the issue. Much appreciated!
2015, 1.6 diesel glow plugs - how to change.
More than 130 pounds for a glow plug... What's wrong with the VW guys?! https://www.darksidedevelopments.co.uk/products/1-4-1-6-2-0-tdi-common-rail-glow-plugs-with-pressure-sensor.html
Octavia vRS Diesel oil consumption
Is there place where you can do some italian tune up? If yes, I would do the following: 1. Add a bottle of Archoil 6400-D and top up till the tank is full 2. Drive on higher revs, lower gear for 30min - 2000-2500 at least 3. Then don’t refill until the tank is 1/4 4. Do the next oil change as soon as possible - e.g. 2-3k miles. 5. Do a 15 min flush(idling!) before changing the oil. Use something high detergent and harmless for the seals, they all say so, but I would go with Lubegard’s or Amsoil’s flush. I’ve tried the first and it’s great. 6. Forget about the **** oil sold by the dealer, Shell, Castrol, etc.. Add some good high synthetic oil - Ravenol VMP is a great 507.00 oil. Amsoil European Series 5w30 as well, Redline 5w30 507.00 which is a bit expensive but very good too.. I only heard that Millers have good oils, but I haven’t tried any because it’s pretty hard to find it outside UK. I think Opie Oil have filter by PAO and Ester based oils, do search for one of these which meets VW 507.00 and find a reputable place where you can buy it( you don’t have to buy from them). 7. Them try to change the oil no more than 10-12k/year whatever comes first. I guarantee for the Archoil 6400 and Ravenol VMP, these two are really good. I hope that you’ll forget about this soon! Good Luck
tyre noise or wheel bearing problem?
Both front bearings were changed on mine too. It was done under warranty on around 110000 km, but I think they failed at around 90000…
Skoda Octavia VRS 2.0TDI (CUPA EA288) high oil consumption
@Srkigtd 5w30 oils meeting 504/507 spec are low SAPS oils, but the 5w40 are usually mid- or full-SAPS oils. Meaning that with the same oil consumption the DPF will regenerate more often and accumulate more ash with 5w40. Stick to the 5w30 if you want to keep that DPF for a bit longer. Try some full synthetic oil with PAOs and/or esters like Millers, Ravenol, Amsoil, Rowe or something like. At least you'll know that the engine is better protected. The oil consumption won't decrease.. IMO with your oil consumption you can change your oil every 20k km if you use a good oil brand. You add enough additives with the fresh oil which you're topping every 1000km. If the oil filter wasn't at the bottom of the engine, I would I would still change it every 10k km. That's what I do with my thirsty 1.9 tdi.. But the filter there is on top.
Reversing Camera Retrofit
Cut that trunk @Vahids and get a good looking handle and well known reverse camera
Calling all silica bag coolant experts!
Some people report casting sand in their coolant. As the rest already said, go the dealer and let them fix it.
Welcome/leaving lights without bi-xenon
I think I left my DRL strips only for CH/LH with the following VCDS changes: (8)-Leuchte6ABL LC5-Lichtfunktion C 6 - left as active (8)-Leuchte7ABL RB1-Lichtfunktion C 7 - left as active (10)-Leuchte6ABL LC5-Dimmwert CD 6 - value change from 127 to 0 (10)-Leuchte7ABL RB1-Dimmwert CD 7 - value change from 127 to 0 (11)-Leuchte6ABL LC5-Dimming Direction CD 6 - change to minimise (11)-Leuchte7ABL RB1-Dimming Direction CD 7 - change to minimise
COOLANT CHANGE
I think the dealer is following the ridiculous VW flush recommendations when that happens.. In another thread someone had this “service” under warranty and it was including 6 or 8 flushes following some extra steps, plus the new G12Evo coolant on double price because it’s ‘ready for use’ mix.
Loud Vibrations after DMF and engine mount replacement - MK3 Octavia Scout
Here is a video showing the DMF movement in both directions. In most cases the vertical movement does the rattling sound. Even if it’s new, the DMF should be checked for such vertical clearance before putting it into the car. https://youtu.be/3N4_pvjzgaw and another one from a TDI https://youtu.be/4sgzrNIl-r4
+1 I’m almost 99% sure that the noise comes from the DMF. Most likely it was fitted correctly as mechanic is Auto gearbox is specialist. The issue IMO is the actual DMF which is defective. I’m saying this because I had changed 3 DMFs on my wife’s A3 1.9 TDI manual until I find a working one with no vertical play and almost no horizontal play of the upper plate. By horizontal play I mean the moving of the plate in left and right when you try to move it with your hands. Do have severe rattling sound when you start the car cold and it’s idle on neutral? Like something in the gearbox is hitting its walls. Then is it changing when moving to Direct and still holding the brake? Do you hear shuddering/rattling when you turn the engine off? The acceleration between 1 and 2k rpm is also one of the symptoms of a bad DMF because this is the range where the torque increases( reaches max at around 1800 rpm ) and the load over the gearbox is changing.
Cambelt and waterpump
@Intercityuk I would go for the OEM cambelt kit for another 7 years and 80 to 100k miles till the next change.
Cannot remove infotainment display - one of the removal keys doesn’t click
I was able to release the clip by pushing the metal clamp with the removal key from the bottom of the radio. I am sure that this happened because of the bad quality removal keys. So for god sake, don’t be lazy like me and use VW genuine removal tools.
Hi Guys, I want to swap my 6.5” screen on the pre-FL with the 8” one from the facelift. But all except one of the metal keys click. The bottom left doesn’t click when it’s pushed into the hole and therefore doesn’t release the bottom left corner… The rest corners are released and I can pull them out except this one. The display hasn’t been removed before, as far as I know. Any ideas how to remove the display unit in this case? EDIT: I tried different angles and to push the key harder, but without success, unfortunately. Many Thanks! F
BTW I also use Ravenol VMP 5w30 for mine and IMO it’s one of the best 504/507 oils out there. This and Ravenol VSW 0w30 for a bit colder climates or city driving with start/stop system enabled. As I wrote earlier, I also have no noticeable oil consumption with it. I’m about to try Amsoil AEL 5w30 for my next oil change, which is also very stable oil. I will post update with it as well.
Cambelt due for changing, but low mileage
@PetrolDave True - the climate in UK isn’t that different from the rest of the EU countries. I think that cambelt service is more like an option to extend your warranty(of the engine only) with 2 years.
Replace timing belt at 210000 kms for non dust rich countries. This is what my service manual says. No time interval is mentioned. My local Skoda dealer said the timing belt can last 10 years with no issues and that they never had snapped/broken belt. But the water pumps start to leak pretty often... They said that even the *fixed* water pumps start to leak after 4-5 years.
Drone when shifting
@brimarma Do you know, was the haldex filter cleaned as part of the haldex service or only the oil was changed? Hint: Skoda and rest of the VW dealers don’t do it. But many independent vw garages know for the haldex pump issues due to the accumulated deposits from the haldex clutch and clean the filter as part of the service. Try to launch the car on a wet road few times and see do you also observe shaking like the guy in the beginning of this video The noise could also be from the rear diff? I hope that the noise hasn’t appeared after the diff service. Has it? DSG+TDI in the city are **** combination, I can confirm.. Some say that driving it manually for some days adapts the DSG to owners driving style, but that didn’t work for me, so can’t tell you for sure. The Sport mode is kind of useless, it keeps revs too high for longer than I want why accelerating, but at least doesn’t torment the car at really low revs for the sake of a half liter diesel
Octavia 3 4x4 2.0TDI 150hp 2016 Brake Disc Size
Yes, the ceramic pads last a bit longer but it all depends on your driving style. Coast few kilometers after being on a track to cool them.
BTW you can also try the ceramic pads. I observed a big difference when swapped OEM ones with set of these on my previous Audi A4. They aren't fully ceramic, but have ceramic fibers in them. Everything cleaned and re-greased - slider pins and brake pad beds. That should give you a good brake performance. Don't forget about the brake fluid - I plan to change mine with ATE SL.6 which has pretty good characteristics.
My Android head unit upgrade.
Looks good! IMO if you change the theme and software buttons on the left side to green, it would be a little better because it will match the rest of the interior lights color.
Bag in coolant.
For those who are wondering - the old cap can be reused. I switched my tank with silica bag with the latest model without such. It was like 25 euro. The old cap and its seal were perfectly fine.
