Danoid
Everything posted by Danoid
  1. What xenon bulbs do you have?
  2. I took brembo discs along with me for my local Skoda dealer to fit along with genuine pads. They’ll just say it’s a wear and tear item so not worth the hassle imo
  3. Ah I read small print as well so cheaper for you as it’s near expiration. To answer your question the all in package is one up from listed component and DSG is listed there. It says it’ll repair or replace, so DSG should be fine, however I’d do the quiet service at 40k miles for DSG then I can’t see how they could argue
  4. £188 is a bargain, I just done a quote for mine 2016 40k miles with £250 excess and comes out as £481 I suppose yours is cheaper as it’s still under manufacturers warranty isn’t it?
  5. Could have been me They’re still looking great
  6. There is no coating on the OE ones and will look worse soon enough. As your car is new I’d paint them. When my rears got replaced I went for Brembo disks as they’re coated and look nice For painting I’d say use hammerite smooth silver or black and do a good few coats, probably be easier with brush on rather than aerosol
  7. That’s why they’re so expensive it’s magic
  8. It’s been fine since the plus gas to be honest. As lubricating it sorted it if it does it again I’ll get the Wurth product
  9. I wouldn’t fancy spending that much to only have to butcher it for a Skoda logo, be better to buy the OE one of they ever did. Not something I’m desperate for but would be nice
  10. Exactly that https://youtu.be/3aqkxNqiugU https://youtu.be/RzMVGMKlnyg
  11. Does anyone know if Skoda will ever do a dynamic wheel cap like VW and Audi? My wheel caps are pretty minging and would go nicely on a superb, expensive though
  12. Finally used the boot things after 5 years
  13. Found it today, never noticed it before
  14. So they plugged it in and found a fault then want you to pay £102 for them to plug it on and see if there’s a fault? Is your car a diesel? I googled VW P171900 (p1719) and could be as simple as low ish battery or it was doing a regen
  15. Doh. 1 more thing I can think of is try pushing the inside panel on the actual boot everywhere and see if you get a rattle. Or if you think it’s actually the boot, can you push down on different areas from the outside and have someone from the inside push just after you push, if it rattles then bingo found the issue
  16. Have you removed spare wheel, tools and opened and emptied the side storage units? I had something similar on my Passat and turned out it was a wheel bolt in the storage unit wedged right down but not wedged enough for it not to rattle
  17. There’s a button on the b pillar?
  18. Do you need a superb for the space? If you’re concerned about MPG you’d be better with a smaller car especially if space isn’t required
  19. I’m sure mine has this but not as much or as visible. I think taking them out is the only way then you’ll be able to get to the back or be able to use a thin pipe cleaner
  20. When I first got my car I had the seat in the perfect position, a year later I took it for its service but I stupidly forgot to save my seat position. 4 years later I still can’t find the same position I had and get a numb bum after around 2 hours. From my experience the seat can be comfortable but I feel like the electric seat has too many variations. I think I may do baby steps with my seat adjustment and set it completely wrong then adjust 1 setting per day until I can find the sweet spot again, I know it’s there somewhere
  21. So much cheaper but unfortunately my insurance won’t have it that it’s bigger than original spec 😞
  22. Oh wise one what would you recommend then? You don’t have to be a tyre expert to recommend tyres, if you knew anything about tyres you’d know pros and cons and when tyres for our cars can be as much as £230 per tyre I’d rather not take a punt Regardless I’m waiting for the Eagle F1 Asymmetric 6 released in about 3 weeks
  23. If it’s on a 4 post lift then lifting on the sills is correct. That looks like a trolley jack has gone there with no protection 😞
