Danoid
Everything posted by Danoid
  1. Can’t see why there would be a button to operate a manual boot like you have, sounds like a printing mistake
  2. Car at the dealers having rear disc and pads changed, so I asked for a longish test drive in an enyaq which I’ve got at home now. Biggest complaint is this stupid design flaw. The dash is far too low so my knee keeps hitting it. If it was a little bit higher it would be great as I won’t be attacked and I can open my legs more. I tried putting my feet just to the left of the brake pedal which was more comfortable but then left foot is almost under the brake pedal
  3. Tbh I use luke warm water and is fine in seconds
  4. I would take them to a small claims court for everything you’ve paid for so far plus any additional work. Keep all your receipts for the case, I very much doubt they’ll turn up. Look forward to seeing your case on Can’t Pay We’ll Take It Away
  5. So I’ve gone for Brembo discs (08.C501.11 made in Italy) and genuine pads. The more I read about pads from other manufacturers the more I got put off from various posts here and elsewhere. I would have gone ATE rear pads but ECP don’t sell them (they sell fronts) for some reason nor does many other places where I can pick up locally. My local dealer will be fitting my supplied discs and genuine pads on Thursday as I really needed it done this end of the year. Whilst they’re fitting them I’m doing a long test drive in an enyaq. Last time I done one of these longer test drives I went home and picked the dog up for a spin in a Karoq which he and I gave a “Nul Points”, so I’m intrigued on his thoughts on the enyaq.
  6. Nothing worse than someone with a problem then never getting back with an update, so kudos to you 🍻
  7. I’ll check that out, only problem I have is the when playing music via Bluetooth. Majority of the time it works fine, but sometimes when the song changes it still displays the same song playing, other times it gets in a right hissy fit and only plays 1 song on repeat. I’ve had it a few times where I have to completely reconnect my phone as well So I was thinking that’s got to be some kind of bug. I was looking at Skoda servicing and doesn’t specifically mention “software updates” like other manufacturers do during servicing.
  8. What’s the official method of upgrading software? I have Columbus, is this something the dealer should do during a service?
  9. Email notification is in English but your message here isn’t, weird. Never heard of them, I’m very much a person who believes in buy cheap pay twice. So personally I wouldn’t touch them as changing the bulbs involves taking the wheel arch liner off and not something I’d want to often, so if those very cheap bulbs end up being rubbish you’ll have to buy other ones and repeat the process. I’d stick with Osram or Philips, but as you’ll see the prices are high compared to those cheap ones. Have a look at this guys channel as he tests bulbs in his octavia. Here’s a video of arguably the best two xenons His reviews seem very informative even though it’s in German and subs don’t work, but later in the video he has side by side videos
  10. Just a heads up for people who want genuine wheels, always buy the accessory wheel rather than the “normal” one example Skoda stratos 3V0 601 025 C (8Z8) is rocking £438.07 each But if you look at the accessory list Skoda Stratos 3V0 071 495 C (8Z8) is a £191.00 each.
  11. Just found this One of the comments he says they’re fine in the rain, but that’s hardly torrential rain, so I’m not sure if his comment is based on that result. might be worth commenting on that video to see if he can answer your question If they’re not legal that’s the risk you’ll have to take should anything happen and insurance tries to wriggle their way out of paying
  12. I’m not sure on the legalities in Spain but UK it is illegal. Why do you want to change to LED? If it’s purely for light colour then see if Osram Cool Blue Boost is legal in Spain, if it’s not legal then Osram Cool Blue Intense most likely will be. As lights are to see where you’re going you really want lower Kelvin rating but then I admit it looks dated these days.
  13. Surely if you drive the 280 it should be SPG (smiles per gallon) measured?
  14. Which ones did you go for out of interest?
  15. Is it possible you can take a picture of the rear disc hub? As these are coated I’m hoping it still looks new. Friend of mine has these on his car which is a totally different male and still fine
  16. It very much depends on your model as to which brakes you need. I might be wrong but on the 220/280hp the rears are vented and 310mm , if yours is not vented then it should be 300mm. I’m buying these personally very soon, but getting my local dealer to install them for £150, expensive I know but independent was around £5 cheaper https://www.eurocarparts.com/p/brembo-brake-disc-10444224A https://www.eurocarparts.com/p/brembo-brake-pad-10144208A
  17. Very similar, I’ve been doing more searching and Wurth HSS-2000 looks to be the ideal product to use for relubing, not exactly cheap mind you. I’ll be purchasing that as it sprays like a liquid then turns into a grease, so it’ll penetrate in nicely, I’ll spray the door latch lock itself as well
  18. For my car it was lack of lubrication and back to normal for now. I did only use plusgas though so not expecting it to long, unless it dislodged a bit of grit/dirt
  19. Yesterday I did spray a little plus gas by the handle bit, didn’t seem to do much. but today… So I guess it needed some time to think about it and now behaving
  20. Possibly but surely it would be hard to open from the inside as well, hmm
  21. Forgot to mention when the door is open the handle isn’t stiff and opening from the inside is fine when the door is closed. My old car (Passat b5.5) had an issue like this but there was a cable with a plastic end and you could move that forward a few notches to make it tight again. Does the Superb have this hidden somewhere rather than visible on the Passat?
  22. So after 4 or so years I have my first problem with my superb. The drivers door is quite stiff to open, I’ve sprayed it to see if it helps but I doubt it. Any ideas? https://youtube.com/shorts/EpO9gO7Uq1Y?feature=share BTW I don’t normally open my doors like that, just showing the difference between 1 finger opening on rear compared to the fronts 😀
  23. What colour is your car? I rather like it I believe, never seen that as an option hmm
  24. I actually used that on my wife’s Fiat 500 drums, worked a treat if not a little messy. I’m going to go with the brembos and if they do go funky eventually then I’ll hammerite them
