Danoid
Everything posted by Danoid
  1. I’d always avoid additives as not needed here usually, but saying that your car has done crazy miles BTW diesels do lower MPG in winter, so keep that in mind too
  2. Oh I’m intrigued, how much better do they perform compared to the Xenon’s? Looking at the spec of these they are 4500lm, whereas Osram NBL is 3200lm so on paper it’s better already
  3. The chances are low, especially in our cars where you can’t get to the back of the lights easily, but MOT testers are not allowed to remove anything during testing. There are notes about if it’s xenon they’ll be a warming up period, whereas LED is instant so they could tell the difference straight away If you were in an accident and other person said “I was dazzled” or something and it was a serious accident then they’d check but in all honesty it would only be a fatal accident they’d check everything. Also as they’re not E marked and that is legislation you are breaking the law and obviously insurance is technically invalid Osram in other European countries have a direct Halogen to LED replacement which is road legal but UK is slow to get with times
  4. Im not sure where you are if you have restrictions on what bulbs you can use, there’s no E marked LED DS3 so illegal to use on cars in UK, will pass MOT though. If you don’t care about that then I’d give these a go https://autobeam.co.uk/collections/led-full-beam/products/led-d3s-dipped-beam-unit
  5. I’m sure I’ve seen settings in vcds Tbh I’d much rather the car speedo to over read in case any mobile speed cameras are out fishing Ross-Tech ForumsError trying to set tire circumference on 2018 VW GTI DSG.Hello, I have been trying to adjust my tire circumference via 17-Instrumentation/Coding/Long Coding/ Byte 3/ but the setting will not take from "varient 3". I need "varient 4" for my larger tire size
  6. You may need to take in consideration that is during the Covid years, could be as simple as too hard to get it booked in and they done the service themself or it was serviced at a different garage. I wouldn’t be concerned at all, especially as I took ownership of my mums old Passat b5.5 which didn’t have an oil change in 10 years!! Ran perfectly but obviously I did change it when I owned it
  7. Excellent thank you, it’s been behaving correctly recently but it’s clearly on its way out, job for warmer months
  8. Have you got a link to the camera you got please? I’ve been debating whether to get one, as long as it’s 100% plug and play, no cables to cut and splice into I’m interested. Looks like your car is a 2016 too, mines an estate if that matters for the camera link Thanks
  9. Ah, I thought so, I’ve got exactly the same issue From the video I’ve seen there’s a tiny pin, did you remove that and not use it? From what I can tell it’s only there until it’s inside the car then it can be removed but not entirely sure
  10. Have a look for a good independent garage who specialises in ze German cars The problem with all motorway miles is the revs are low, so a good thrashing when warm is good but that also causes more soot. When safe to do so go on the motorway but keep it in low gear for 15 mins so the revs around 2.5k
  11. If it was me it would go back and I’d look elsewhere, purely because if I buy a car I expect it to be tip top and not have to worry over something. If it was an ABS sensor which I had recently it was very easy to diagnose, firstly there was a fault and secondly I was able to do a live scan and see that one of abs sensor was recording 0kph, others were receiving speeds, £40 later and I bought and replaced it and job done. Go here and enter your reg https://www.tayna.co.uk/?gad_source=1&gad_campaignid=23075948330&gbraid=0AAAAADtA3JfkKNBjGbzc-58IXDD5RbPbo Look for Varta AGM battery (probably best you can get) if the dealer won’t pay for it and to have it “coded” in then yeah give it back. Also for a car that’s at temp the idle speed looks way too high, can’t remember if mine was higher when abs sensor was knackered but car was grim to drive, started off okay but as soon as I got off my drive and drove all the errors popped up
  12. I made a guide for someone on here not too long ago, it’s quite in depth but have a read Skoda Columbus Map Update.pdf
  13. They do make cars financially sustainable, but for them not us
  14. As you’re off https://www.tufferman.co.uk/collections/garage-shelving-v1 ahem
  15. Personally the new ppm for hybrids and EV’s put me off longer, nor would I get a hatchback as estates much more appealing
  16. The only thing I can think of which I’m sure you’ve done is adjust the seat to ne higher then lower the steering column if needed
  17. There’s that but still there’s no E marked ones available that I’m aware of Annoying as I’d love them
  18. Be careful with putting leds in, will void insurance and could get pulled over. Apparently they’re cracking down on retrofits because of “dazzling”
  19. Annoyingly my cars started erroring with the Workshop P error message I’m aware there’s the bypass kit which looks fairly fiddly but do-able, however I don’t have the message all the time, is there anything I can do other than fitting the bypass kit? Think mines a DQ250? 2016 190ps 6speed I had a quick look and the plastic bits are white on mine
  20. What’s the requirement? I ask this because there is an option for something like Easy Entry, but needs coding I believe the seat goes back when you open the door, then goes back to your set position with ignition on Might be an option?
  21. I’ve got the SEL, so standard suspension, yes it’s soft but in UK it’s perfect because nearly all road surfaces crap and you can at least have a conversation Father in laws Audi A4 black edition has mix firmer suspension and can’t talk in it because it’s such a harsh ride Until roads are built and maintained properly I’ll always go with softer suspension
  22. It does need some parameters to be changed for optimal battery performance What was the error code?
  23. Hmm why did you change the abs wiring loom and which one? You really need to get it scanned before chucking parts at it. Looks like wheel speed sensor issues as I’ve had that recently but a scan will show you whats up
