Edela
Everything posted by Edela
  1. You keep repeating 48V, but I think you are confusing PHEV and mHEV. The battery is 350V here.
  2. It is charged while HV battery is charged. For sure battery is defected, as many were. Many of us here went through this. It comes to a multiple fw updates for ECUs and battery replacement. For most of us, that was the final solution. So no, PHEVs as they are not a problem as long as all fw problems are sorted and as long as you don't get that covid battery, which were sitting on a factory lot for a year. Still, some folks were saying it did not help them, which made me think their workshops did not update everything they had to.
  3. Mine had this issue, it would not discharge battery even overnight, not even mention in 10 minutes like in OP's case. Octavias are actually known to become completely dead when voltage drops, with no prior warning. Been there myself. @Octawia can't really think what could be wrong in your case apart of defective battery, which coincidentally died at exactly this moment after being loaded by central lock. Does not seem too probable, but again, tons of cars with defective batteries out there, and I can't think so far of another explanation. I would check battery voltage first thing. Also, it is not such a big of a problem to tow the car from underground, unless it is some extremely tight spot. Pickup truck picks the front, rollers under the rear wheels and here we go.
  4. They already have for a while, just not Octavias. Though Octavia with next gen PHEV system comes, too, no mention still of the launch date.
  5. If it is braking with noticeable deceleration, yes and you can easily see at night how your brake lights reflected on road signs or things along the road behind you. To turn off what exactly? Brake light lighting on when car decelerates? Of course not, and why would you want to do it?
  6. Someone here was reporting receiving 1985 OTA on H56 hardware, but that was the only case I've ever seen on this forum or elsewhere. So it is quite confusing why it was possible for that user, but seemingly no other car running on H56 is getting it.
  7. 1300 unit, few hours of work, tax. Count 1700+.
  8. It is not a bug, but feature. Not many cars are capable of OTA updates besides minor app and manual updates.
  9. I had the same problem with Spotify, and the only way to make it stop launching was to remove it from AA launcher list. Youtube music I use, or default Samsung music do not start up if I forbid them starting in AA settings. Are you talking about USB on the rear view mirror? Cause all others are indeed for data transfer and dashcam should go into mass storage mode. As for 1 and 3, I have 1941 too, but no such issues. It might be your phone related, not the car.
  10. Not familiar with FL cars too much, but yeah, pulling fuse for infotainment would be first thing I'd try. Check in car manual fuse diagram, on pre-FL it is fuse 30 for infotainment and 19 for communications module, which may be at fault here.
  11. You don't need that on modern cars though. In car manual there should be requirements listed to activate DPF regen. On my previous Skoda which was a diesel, it was enough to drive steady at speed above 80km/h and car would initiate regen at lower rpm.
  12. Now this is surprising. Congrats! You saved yourself about 2k.
  13. Not sure what is the real reason behind, but I think Skoda did some bad decisions with this car. Say, not letting us control the force of regen could be a marketing thing, since Superb has to be more expensive, and that is one of very few things differentiating it. But at least they could give an option to use full available regen on demand, which now can be done only via cruise control. Switching regen on with gear paddle also does not make any sense, since it gives very weak regen but overrides any other logic, like following the car in front or adjusting speed in front of intersection. Idk, the car could be way smarter and comfortable to drive if these small things were fixed. So I was surprised too when even in the settings they removed an option to choose at least default mode of regen, like it wasn't great already but became even worse.
  14. This error stays in car logs and will be visible to them even if does not pop up again, and that's enough to get it replaced under warranty. Also, if I could give just one advice to anyone with this car... go get extended warranty.
  15. From my experience and what I collect around on social media, PHEVs have very little to no issues at all with HV system. All the other problems are shared across the platform, no matter you take PHEV, MHEV, or just ICE. Same 12V issues are constant across all options. But surely, PHEV only makes sense if you can charge it overnight at cheap tariff. In any other case I'd go for MHEV or just EV, depending on weekly mileage.
  16. I use a similar stick for 128GB as well, formatted for exFAT. No problem playing. So I guess don't waste money on another stick yet. I navigate in music player to the stick as a source and then select folder and a file in it to start playing. Though I'm on 1941, and what you describe is another reason I'm not in a rush to upgrade my infotainment further.
  17. That's the fault of poor traction control these cars have. I had wheel spins on both Turanza and Eagle (though more on Eagle) before I got used to start the way to avoid it. Had FL rental last year and the same issue was there, though don't remember what tyres it had. Apart of that, as someone who likes to go 170 in heavy rainfall, I would choose Bridgestones over pretty much anything else I had a chance to try, both Turanza and Blizzak.
  18. Do they? Not the quietest tyres in my experience, though much quieter than stock Goodyears. But Octavia in general isn't great for tyre noise whatever tyres you install. I prefer a bit more noise but excellent performance, rather than chasing that 1dB to cut and getting some crap result overall.
  19. Genuine question - WTF? Mind making a picture of how your car looks like now? I mean, there is nothing to inspect really, it is a very common issue. They must have ordered a new screen and replace it on spot, not letting you drive around like that...
  20. I disconnected mine, no problems. Just in case connected it back before MOT and then disconnected again.
  21. You may disconnect sensors under the seat. Though I think more practical would be to store stuff on the floor or in the trunk indeed.
  22. Indeed, that doesn't make sense. It is charging 12V battery only in the process of charging HV battery. So when my infotainment was switching on at night, my car was fully charged by 6am, and when I was coming at 9am, 12V battery was already dead. 3 hours was enough to drain it. But then again, for some reasons beyond my comprehension, this is a common issue across EVs.
  23. Idk, I'm used to hard reboot module if it looses connection. Just make sure ignition is off. If manipulating settings helps without rebooting hardware, then that's even better.
  24. Check that your car has connection, a little globe icon should be white. If it does not (icon is grey), switch off ignition and pull fuse 19 for a minute.
