the truth about electric cars
You are arguing with one of the 10 members I have blocked, just saying...
- Skoda Fabia 2003 AWD 1.8CC BUILD
Car Park Fires, Transporters / Ships, any fires, any EV,s involved or not thread, were they the cause just there and so made fighting the fire harder.
You mean liquids like "electricity"; like "bird nests"...? In the last 2 vehicle fires I've witnessed, one was an electrical fire in the ventilation fan controls (V**xh*11 Z@f1r@), and the other happened when a hot turbo set light to a recently built bird nest in the engine bay.
vRS Lens Halogen Headlights Conversion
I think the only way to do what you want to to buy a set of wrong hand drive headlights. Sorry.
Well, done; you win a block!
First bong this Autumn.
2 degrees below freezing you mean!!
Pricing for a reluctant sale
I'll take it off your hands for a oner guv'.
Briskoda Stickers
@ColinD - Wrong forum I know, but what's the state of play on stickers?
Will i lose all my deposit
No idea. I have not read the contract which you signed when/by placing the deposit.
I've been actively avoiding that video precisely because of that title.
Phantom Oil Leak…
Oil level is not part of the MoT. Neither is "oil consumption" unless the car makes "objectionable smoke".
"Girning" at tick over.
Don't understand; Definition of "girning".
Skoda Fabia Bohemia 1.4Tdi 56 Plate
You just need one for this engine code; it doesn't have to come from a "Bohemia" edition, or even a Skoda as long as you have the Skoda badge from the existing cover.
Start-szop battery charging
The black cap in the red circle, at least on my monitor (and apparently @Stonekeeper as well).
Kodiaq 1.5 TSI Problems After Transmission Oil Change
Almost certainly. I think that the most likely cause is that the incorrect fill method documented has left you with an over-filled transmission.
Also @stvan I thought that too.
In hindsight…
Worn suspension, lack of servicing, low (or high) coolant and/or oil levels... In which context the last time I saw a tyre that was through to the bands the ball joint on that front corner was totally FUBAR.
Difficult starting / No power following cam belt change 5J BNV built Mar 2009
I wondered, but tooth counting is the only way to prove that either way...
Most people I know stop at Tebay for reasons (yes plural) other than "just refuelling". They only stop at Burton in Kendal if they are out of fuel or need a "comfort stop" right now.
OCTAVIA VRS SPARK PLUGS.
@Mantaraman - No idea about a removal procedure, but I think this proves that the supplying stealer is telling porkies if they're that stuck.
@16csvt Did you count teeth between adjacent pulleys before and after the belt change? Have you reset the electronic fuel timing?
MK2 3T B6 fresh air recirculation flap motor part number
Yes, but I don't know the answer to your original query, so didn't reply to it.
ECO mode not staying engaged
I've no idea why the car would need to break; If the slope is such that you are trying to maintain constant velocity but the car is picking up speed due to gravity, then it may need to brake.
Niggly little throttle problem
Well, done, you're blocked.
@titan1 The issue is that I don't know what your slab of text is supposed to say and I don't see why I should expend effort on understanding what you meant correctly and then doing you the favour of giving you a correct solution. I'd block you but 5 posts in 11 years says that's not worth the effort.
