Is my Idle sound normal?
OK, what spec (VW 500 series number) and viscosity are you running? What kilometerage since the last change?
@Kyoki It might be a little tappety; does it get quieter as it warms up?
Restraint airbag light
1) Fix the actual problem 2) Turn off the latching warning light using VCDS or a dealership computer.
Fabia vrs mk1 - Trouble starting
The smell (if any) is very diagnostic. If you have the DERV smell, then you have either failed glow plugs or they weren't reconnected properly when you changed the head gasket. The fact that it clears fast is a comment on how fast the TDi (any tune) head warms up.
engine oil viscosity change.
No. It's not even like the 0W (or 5W) value will apply once the engine's been running about 2 minutes (since the oil won't be at 0C any more). The one difference it might make is that you have "some" oil pressure before the engine even fires with 0W (I did with Mobil 1).
White smoke, smelling of DERV? I've got an idea and the answer to this will confirm or deny it.
Octavia VRS MK3 stage 1 remap
@Kirky2k2 @MarkyG82 - I am a professional software engineer, but when it comes to remapping cars I only know enough to know that if you foul things up you can totally brick the ECU. I'd do my own work on an Emerald or a Megasquirt, but not on a manufacturer system.
Modification places
Bedrock VW in Motherwell. They're even pure dead handy for you to visit.
No power supply to Right Rear door
It's probably a broken wire in the rubber bellows to that door. Taking it much further requires access to the car, and a multimeter.
Struggling to figure out as to why my fuel mileage seems to go down quick
Correction and possible explanation inline, italic. More seriously, it's a weighted average figure that places more emphasis on recent miles. I've used my old Octavia (TDi 110) mostly for commuting including a 1 mile climb at journey end going to work. I got an acceptable overall consumption. I also used it for meeting people off a car ferry, covering about twice the distance on a more level route including my commute except for that last mile. I could complete the trip to the ferry terminal with more remaining range than I started with. So I think you're placing too much reliance on the trip computer figures.
DieselMonte's 2012 Monte Carlo Project. (175hp 6 speed swapped)
Too hot in the workshop and/or using too much hardener.
Needing help on my Skoda rapid
Fastest/cheapest way to get a diagnostic then would be a mobile a/c service or Kwik Fit's "N Colder or you don't pay" offer. I leave sorting out exact details to you since you know your exact postal address.
DSG 7-speed gearbox complete failure - are Skoda UK likely to pick up repair costs?
Do you get aviating porcines often in Bucks?
OTOH it also increases your risk of bricking the car.
Charger compressor oil ?
Erwin.
Car won’t start when warm
It would be a coincidence, but it could also be a bad solenoid...
Bolt found on top of undertray.
Er, that's a set screw, not a bolt. The threads go all the way up to the head.
Vrs petrol emissions
That's an Engine Management System light, not just an emissions light.
Skoda Superb Sportline 2.0 TDI 2018 New owner questions
At a guess...
Problems after removing stock resinator in my Skoda Octavia VRS 2014 TSI
@kubalol90 - When you removed the resonator, you changed the engine back pressure. This could cause a misfire, and sorting that means either replacing the resonator or remapping the engine.
Does oil extractor empty all the sump oil?
Dunno. Is the dipstick tube over the sump well so that the extractor can reach the base of the well?
LED Replacement Warning
Maybe, if the reflector is designed for the different beam pattern, but again, since you're not using ballasts you have more lumens down the road (probably) than you should...
Put proper bulbs back, or fit ballasts to the LEDs, thus undoing any "advantage" they offered.
Six speed, gearbox conversion, is it worth it?
It does; ISTR 35mph/1000rpm in top, but I think you can change the CRP set to lower this.
Reversing Lights
One car I had, the reversing lights flashed when you went in or out of reverse, and could be held on by holding the stick to the outside of the gate. Issue was a bent switch bracket, which we just lived with, and testing yours should be free...
