Everything posted by defsix
Glove box light switich
The microswitch is in the geared device that slows the opening and closing mech.
- Mirror dip
- Low oil level dq381 while change
- Display showing boot open when closed and warning chime sounding when driving - Skoda Superb MK3 SE with power boot
Drivers mode
I see the UPD2 now alright. Another thing I need to add to the list of things to do!
Drivers mode
That only refers to Gearbox mode being lost on restart. FL models won't keep Drive Select position on restart because of emissions. Same reason you can't code out the start/stop
LED High Beam Assist issue
You've got to put them on first for them to work. They will auto dip then.
- S3 owners - electric tailgate / hatch closing from inside
- Battery issue !?!
Seat adjustment, resets when getting in
I'll add this to the list of things to do/try 😜
I have mine set to the key, Via the profile settings all working as designed. Yet the chair will not persistently sit at the extreme position. I have the ass full down and the thigh one fully up. They always go back just a fraction after a few hours.
You feel more planted in the seat. I always thought the seating position was high, coming from an A4
I agree with this too. 1cm makes all the difference.
Adding USB ports in armrest?
How did you attach it?
I do like your idea. Does the phone stay solid on the charger? iPhone? Or Android?
Issues with AC
Arrow down usually, indicating direction of flow.
- Removing nav map from virtual cockpit
This morning, I finally stopped a vibration that in the cabin that has been irritating me for the past 6 months. It sounded to be above / behind the glove box, it occurred when the car was at 1100rpm. So at cruising RPM. Now I do have a USB cable and Camera cable ran for the past 2 years. I assumed this had moved. I've had the glove box out more times than I can count. Clothe taper every cable and plug. Cable ties where I could. And still it vibrated. In the end i narrowed it done to the passenger air vent. Where it connects to the duct behind. This duct was vibrating off the vent duct above. Packed in some foam between the 2 ducts and no more vibrations. What a journey!
MIB toolkit tips
Thanks for the inspiration 😁
MIB toolkit tips
I wanted to educate myself further on the Toolbox. Not looking for anything specific.
MIB toolkit tips
MIB toolkit tips
I'd see the GitHub before, I was looking for further details on each customization. And what each option does exactly.
MIB toolkit tips
Has anyone seen a guid to using the Toolbox with our vehicle's?
