Everything posted by Blue8793841
Misfire cylinder 4
Could have carbon build up on the valves, worth taking the manifold off and investigating
No Engine cover?>>
There was a bulletin on some models to remove the engine cover
Braking Questions - pad wear.
Rear pads are almost always less thick than the front and they last longer as the braking efficiency is lower on the rear.
Confused about Timing belt change interval.
The end note is that they aren't going to pay for your engine when it goes bang
Does the Karoq work as a 1L Petrol?
I agree, fuel economy will be noticeably higher even without trying
Few questions regarding a used Superb (including 1.5 vs 2.0 TSI and mpg question)
All depends what driving you do, 1.5 can get 60+ mpg on motorways
Gear changes
Sounds like low voltage problem worth checking the charging system/battery
I feel the 1.0 actually feels nippier than the 1.5 untill you get to high speeds
DPF regens too often
Are you using quality fuel? I've seen people using Archoil 6400-D and going from 200 mile regens to 800 miles between regens.
Oil leake
I haven't got the tpi to hand, as I only downloaded the data for my vehicle which is 1.5, but if you log into erwin you can easily find it. It mainly effected the smaller and older engines. As the others suggest you would have to remove the gearbox and make and inspection.
Help - Told Engine gone, any advice appreciated!
Problem is a lot of these vehicles are not getting serviced at the dealers. Maybe the first 2 or 3 years but after that they go independent so these tpis etc never get carried out.
Oil leake
The tsb is not a figment of my imagination
Oil leake
You would be surprised what sort of ideas they come up with now.
Oil leake
Remove flywheel bolts and add thread lock.
ScottieSkoda
They are very common for the shoes to stick to the drum. Brake dust and moisture causes it then the vehicle has been standing for a while. Maybe the cylinders were leaking but as for the bearings they probably got you on that one.
Oil leake
Looks like it could be the old oil leaking past the flywheel bolts problem. Not seen it on the newer stuff before though.
DSG oil change at 4 year service, 20k miles?
Id think you would be fine to let it go a bit longer unless you have some sort of extended warranty then I'd get it done.
- Buying an Octavia 1.8TSI with reconditioned engine?!
Skoda Octavia mk 3 servicing
Need to check the history of the car really to see what it's had done in the past.
ScottieSkoda
They saw you coming by the looks of it
Rubber v carpet vote...update as controversial mat debate rolls on!
I'll add these to my basket, they aren't the stinky ones are they?
Road noise in cabin
I've just got some Yokohama v701 and they are rated at 67db which is about the lowest you can get. I'll try post an update when I have the wheels on the car.
I've seen them spin the thrust bearings on the crankshaft.
Can anyone identify this hose please?
I've fitted quite a few on both the 1.5 and 1.0 you should be able to do the job yourself, just be careful as they are easy to break.
Rear wiper blade for L & K estate
The motor is a common fault
