john999boy
Honorary
Everything posted by john999boy
  1. It isn’t just Skoda but more a supplier issue as my Cupra suffered the same problems.
  2. Surely if it's just bad contacts then either adjusting them or adding solder pads will save an awful lot of trouble and be loads faster to do?
  3. Google will assist - it's not too hard to do but it's easier to watch.
  4. It's totally transparent with VAG cars.
  5. @e-Roottoot Would I be correct in thinking that you weren’t logged in as Freedom members shouldn’t be seeing Ads?
  6. It can do that as it may be moving to another station from a different area but on the same network - think stations like Capital. Also if DAB drops out then it might be set up to revert to FM.
  7. Maybe that was the speed limiter underneath the CC stalk?
  8. If the steering wheel has three stalks then you have ACC - only two and it’s normal CC.
  9. The switch has three positions - off, on & switched.
  10. Is it possible to sort by albums and not playlists?
  11. Whereabouts are you based @DSL? I've not got around to fitting mine yet due to the weather being still relatively good.
  12. I’m gobsmacked to find this out! Old dogs & new tricks spring to mind.
  13. I wonder if this will give another recently acquired Karoq owner ideas for future reference?
  14. Quite often it can be just the nozzle which is blocked.
  15. Are you sure as a local vlogger has it on his current model 3 and has specced it on his incoming MY21 car too?
  16. Sometimes they are a bit of a tight fit so you may have to trim the plastic surrounds on the car.
  17. I'm sure that quite a few people would appreciate your experiences with the new car.
  18. When I changed mine I had to do an audio reset to set in the change. Maybe worth trying?
  19. Only Freedom members have an unlimited amount of time to edit their posts so I've done it for you. If you see other instances then please feel free to hit the Report button instead of asking within the thread.
  20. Park Aid has additional sensors to allow it to work and a RVC isn't a requisite. Reverse parking needs reference cars though.
  21. The post may well be relevant to the title but has absolutely nothing to do with the thread!
  22. Do you have the full/expensive self driving abilities or the free ones?
