Everything posted by Cairus
Error code B201000 17 instrument cluster
Has the oil been changed or serviced recently? Here, as always when I have this error, all the interval data no longer fits.
Fault codes after changing battery
So, personally, I've never had a calibration error due to undervoltage, but I also assumed that it was deleted.
Spolier Paint Bubbling?
Warrenty of painting 3 years in Austria
£20 for VCDS scan
You can't use VCDs on the airbag control unit anymore, nor can you use other standard tools. Only online via ODIS or other expensive tools. You can't add keys anymore; the 7-digit PIN is no longer available. CS encryption is required because of the immobilizer. Coding without SFD is useful, yes. Starting with SFD 1, it's been put in a drawer for me.
The marked position is correct. The sensor is mounted on a support plate with fine adjustment screws for aligning the sensor. The plate is then screwed onto the grill. However, the support plate is prone to breaking, which is when this error occurs. The Octavia 3 Facelift have the Same Position
£20 for VCDS scan
It's interesting what he can do with VCDs on the MQB Classic and MQB EVO. He should add which platform it is to his list. VCDs are almost useless on the MQB or EVO. However, I think VCDs has a very good error log and backup function. I bought an unlimited V2 years ago and paid €460 back then.
£20 for VCDS scan
I was called, how can I help?
Do Superbs have heated seats?
Are you serious about the question?
I now have confirmation. mib2 Amundsen, SW 0480 with SW1804 climate control doesn't work. I flashed the climate control, and the display was immediately in the mib.
- Headlight flashing stopped working after VCDS Tweaks attempt
Headlamp day time light bars
AliExpress?
the headlight is not suitable for this
- Facelift Crystal Style taillights in the VFL
- Virtual cockpit retrofit errors
Still have fault after replacing rear boot struts - Still wont open fully and wont close at all
Connect obd11 Go to unit 6D BASIC Settings Teach flap opening angle Start Open the Trunk Close the Trunk Stop Basic Settings
You have set the Basic Settings?
The actuator for the tailgate naturally has a wiring harness. The yellow and blue wires in these often break. If these actuators are replaced, the wiring harness in the interior also Part of the actuator.
Coding again
What is in the Error Log?
Re-programming Keys? Superb Mk3 2017
why don't you complain?
S3 FL - side assist and rear cross traffic assistant - retrofit problem
Yes, in unit 76 set RCTA Active
ODIS is not necessarily necessary. With an Autel IM508S, for example, it also works
This only works if the key is registered in the vehicle's immobilizer but has lost its synchronization.
So, I looked through some backups of my server. All vehicles that had the pop-up had a ECU with a software version 2002.
