the truth about electric cars
You defined the sun belt as being 35N to 35S, which doesn't include NZ as its most northerly point is over 40S, plus Australia goes as far south as 44S so it's not entirely within the sun belt.
New Member with a few questions, sorry!
1) No, the under bonnet sound deadening is only fitted to diesel versions. 4) I have a 1.8TSI (also the EA888 engine) and use 95RON most of the time, maybe once every 3 months or so I fill with 98RON.
Also in that "sun belt" are some of the countries with the lowest per capita earnings in the world, transformation there is making the gap between "the haves" and "the have nots" even wider, so it's not as rosy a picture as you paint.
Octavia 3 ignition key not working
What do you mean not working? Remote unlock/lock doesn't work? If not KESSY, key turned in ignition doesn't start car? If KESSY, key in car but car doesn't start when pressing start button? BTW I always use a CR2032 from a reputable battery manufacturer like Duracell - the Octavia 3 seems very sensitive to battery condition and even brand new batteries from some manfacturers don't work.
Carplay
MIB3 in a 2018 model? I don't think so as all Octavia 3's have MIB2 or MIB2.5 systems. Do you have Swing, Bolero, Amudsen or Columbus?
Is the worst thing about EVs actually the apps?
It was over 30 years ago that all EU countries agreed to work towards a harmonised standard of 230V. The UK was allowed to adopt a tolerance of -6%/+10% instead of -10%/+10%, the UK DNOs are finally proposing that the UK also adopt the -10% lower tolerance. Proposed Changes to UK Mains Voltage Limits Explained
Key problem
Octavia key fobs are very sensitive to the battery - even some brand new batteries don't work. It seems that time since manufacture and even manufacture are important. I always fit Duracell CR2032 - they do fit despite being 0.7mm thicker than the CR2025 that Skoda fit.
It's nit just about purchase price it's also about running costs, which if an owner cannot charge at home or work means public charging - so something needs to be done to make public charging universal throughout the whole UK (allowing the costs of installation to be offset against business taxes would be helpful), and also to control or limit the cost per kWh of public charging (cutting the VAT rate to 5% or even zero rating would be a good start).
Seeking replacement Head unit Display Screen
pab567 will get in touch and assist with all those questions.
12v battery low
Have you monitored the battery voltage under various conditions - ignition off, ignition on, just after starting, while driving several minutes after starting and while braking? Those measurements will give clues whether the Battery Management System is working correctly. I use something like this in the 12V socket LED Voltmeter USB
I've always been puzzled why the Type Approval regulations specify brightness of the indicators, but say nothing about their proximity to other (brighter?) lamps which make them more difficult to see? They've allowed form (design & aesthetics) to override function (visibility) IMHO.
OT slightly but: Some of the worst examples of barely visible rear indicators are where the indicator is a iny amber dot surrounded by the brake and side lights, and yesterday I saw a car where the front indicator is in the same lens as the halogen DRL so all you see is a slight increase in the amber/orange light.
According to this road transport accounts for 15% of global CO2 emissions, so while it's significant it's not the major source.
- Octavia 2015 1.6TDI error: start-stop system
DPF ON CAR CLEAN ADVICE XX
Module 13 is the ACC radar???
Car Bluetooth not working after using Android Auto flash drive on the car
I really think you need to find someone locally with either OBDeleven or VCDS and ask them to do a scan for you.
What scanner did he use? A non-specific VAG scanner is unlikely to detect faults in the infotainment system, as they are often restricted to critical systems such as engine, ABS, transmission, etc.
Refilling Air Conditioning Refrigerant — How Difficult?
When done properly the refrigerant usually also contains an ultra-violet sensitive dye (as well as the oil for the compressor) that can be used to help locate leaks.
Octavia 2025 SEL - Front heated Windscreen
That's correct on the Mk4, the heated screen has an all over film not the individual heated elements. As the screen heats then I'd suggest that even though it's not a Skoda branded screen it's a proper replacement.
To save more guessing it might be an idea to post a fault code scan of 5F made with either OBDeleven or VCDS.
- DAB Radio has weak/no signal
@pab567
Most members of this site are not representative of the car driving population of the UK, which you seem to keep forgetting. Most UK residents do not have solar on their homes, and even less have solar with batteries. A significant proportion do not have driveways so cannot be sure of parking within a cable reach of their home. Taking all these factors into account there is a large percentage who will be dependent on public chargers, so the cost and UK wide availability of public EV charging is what is limiting EV take up.
Head Unit display failure !!
So that's a 14 reg not an H reg!!! HJ is the location it was registered - the Bournemouth office. 14 is the 6 month period it was registered March 2014 to August 2014. VDD is the "random" letters specific to your vehicle.
I'm puzzled by 2014 being H reg? In the UK a 2014 would be either 14 or 64 reg? Or are you not in the UK?
