tetley
Everything posted by tetley
  1. Just realised you were asking about the 1Z0920903R. 1Z0920903R is from the VRS Black Edition and appears to be a petrol cluster. (I need to add it it to my cluster part numbers list). Confirm with the seller first before buying. Kev.
  2. Hi I suspect the cluster is a European model non VRS cluster with the clock faces swapped over from the original factory fitted cluster to make it look like a UK model cluster. That would not be a problem as the circuit board are the same anyway, if correctly coded. Petrol VRS (UK only) cluster part numbers are 1Z0920943C SW: 01xx, 1Z0920943H SW: 03xx, 1Z0920943L SW: 04xx and 1Z0920943R SW: 06xx. 1Z0920943F SW: 03xx is the non VRS of the VRS "H" suffix. In answer to your question yes 1Z0920943R SW: 06xx would be a suitable (and better) replacement for a UK model petrol VRS. There is a separate handbrake 'On' warning lamp (rev counter side) as opposed to using the ABS warning lamp in a duel role (Handbrake On/Brake Failure). Coding is the main problem as the cluster stores the Immobiliser code and the SKU needs to be retrieved from both clusters to use VCDS for the swap. Kev.
  3. Do you know if the cluster been replaced before by a previous owner?
  4. Is 1Z0920903F a maxidot instrument cluster? Do you have mph on the speedo clock face or only kph? Can you check the part number, 1Z0920943F would make more sense. Kev.
  5. On my Octavia Mk2 all the interior lights are on a single fuse so I would suggest removing that fuse as being a easier option.
  6. @East_Yorkshire_Retrofits should be able to carry out those retrofits.
  7. @pab567 Would be the best forum member to ask. Now I have flagged him he should be able to answer.
  8. It depends on which engine is fitted.
  9. According to the internet:- "This is MIB2 By LG and have Component protection.Not have code." Also, this may be of help :- https://forums.ross-tech.com/index.php?threads/41942/
  10. No, but I have thought about it for future reference. I think it would be OK but obviously I have not tried it. The overall combined battery length would be shorter but by bending the end pins you could meet the solder points. The 150mAh cells are thinner than the 200mAh cells. VCDS (diagnostics) measures the battery's internal resistance to determine status so this should not change (in my opinion) between the 200mAh and the 150mAh, only increasing as the cells age and deteriorate. I have also thought about soldering a red cable into the positive solder point and a black cable on to the negative and running both wires from the alarm through the bodywork into the dash and mounting a new battery holder behind the dash to make future battery replacement easier. Bare in mind, I work in finance so the above is just my speculation. Kev.
  11. Here's some fixings. https://www.ebay.co.uk/itm/172733827491 Kev.
  12. Typically referred to as an undertray. https://www.ebay.co.uk/itm/326451837462 https://www.ebay.co.uk/itm/356116377659 You can check the correct part number by providing your registration. Kev.
  13. tetley replied to tetley's topic in Skoda Karoq
    Thanks.
  14. tetley posted a topic in Skoda Karoq
    Skoda Karoq SEL 1.5 TSI DADA DSG (2023) Just been out to top up the coolant in my wife's car. As it's under warranty I have never been under the bonnet before. Should it have an engine cover or is it from the factory that exposed? Thanks, Kev.
  15. On the MK2 all clusters include a handbrake on light. This is in addition to the warning message that appears should you pull away with the handbrake engaged on maxidot fitted clusters. The switch for it is in the handbrake mechanism in the centre tunnel. Probably the same on a MK3? Because it's part of the standard equipment.
  16. Did you vacuum fill or just pour it into the expansion tank? When changing the coolant this year I had to use a vacuum to fully fill with the new coolant. Kev.
  17. It is more complicated than that. The immobiliser code needs to be obtained from the old cluster and written to the new cluster for the car to start. This can't be done via VCDS. An EEPROM reader is required to read the data from the old cluster and to transfer to a new cluster. I had to travel from Leeds to Norfolk to get mine done. It is easier and cheaper to just get it refurbished. Kev.
  18. I drive a petrol engine Octavia, not a diesel. From what I can understand from the Skoda workshop manual (ElsaWin) the first step is remove the top engine cover. Could there be a misprint in Haynes? TDI Remove Engine Top Cover.pdf TDI Remove Intake Manifild.pdf I used a CEGA engine code for reference. Kev.
  19. When starting with the lights on they should go in and out and then up and down i.e. there are four separate movements. Other than that I can't really help. Kev.
  20. Is this the sort of thing you are after .......
  21. Hello and welcome to the forum. To be honest, I didn't know such a thing existed. I have never read any forum post about replacing the analogue cluster with a full digital display. It would be great if it could be done. If you do go ahead with this a write up would be well received. Kev.
