Everything posted by inspectorman
2.0TDI Octy mk3 Winter Wheels on 1.5 TSI Octy mk4?
Correct for 16 inch wheels. 2.7 / 3.3 fully loaded. This from a 1.5 TSI 150 Mk4 hatchback. 2.7 / 2.8 ; 2.7 / 3.4 laden for 17 inch wheels.
Software
In reply to TheWanderer's question; I used the Australian site to identify five (5!) software upgrades. Contacted my local dealer, who agreed they needed to be done. And so they were. Anyone attempting to use Skoda UK's useless checker, or not having an issue, would have been none the wiser. Front desks response to my question about why the Skoda UK checker was so useless; "The UK recall checker does work but these are not classed as "safety recalls" so wouldn't be showing on that site." So we are doomed to drive unimproved / unfixed cars until Skoda UK deigns to tell us.
ACC Braking when overtaking
I had this excitement today. But it cleared after 15 minutes. I have also briefly had the (if you've set 70 you must want 44 - 70kmh being 44 mph) excitement a month ago. In both instances the car had done a software update in the previous days. For now, it's almost as if it took 20 min of driving to reregister it's in the UK. Those who have this as a permanent fault, however, would say it's a rubbish theory.
Noise when breaking
If he's done the pads and discs it's not going to be a stone trapped by the pads. Have a look at the big metal shields behind the brake - circular in size and about the same diameter or bigger than the disc. They're cheaply made and the mounting points give up, leading to them flopping about. Sometimes called a dust cover or brake shield.
Front headlights, fog lights and heating stopped working
It'd be strange to have headlights and radio on the same circuit. Left and right are also normally separately fused. Scanning the car will help if you have anyone with the gear nearby. My guess would be the switch on the end of the ignition barrel.
Rapid Spaceback radio upgrade
- Software Update Recall/Campaigns
After months of the UK checker being "temporarily unavailable" I tried the Aus checker to get - 5 outstanding upgrades / campaigns. 48P9 69BN 90Q9 97C1 97EQ Confusingly, I had 97EQ applied last December. So asked my dealer to check. Apparently, 97EQ had a fourth part, also named 97EQ, released in January. Not at all destined to muddy the waters. So I need to have all five done. And " The UK recall checker does work but these are not classed as "safety recalls" so wouldn't be showing on that site." Which is not consistent with the "unavailable" message, or the info being available on the Aus site. So how many owners never know about these recall campaigns? My understanding of recalls is that the manufacturer should initiate contact. Clearly not. This is not a complaint - infotainment issues for me have been transitory and rare.- Anyone know whether the spare tyre from a Mark II will fit the Mark IV?
A 10 year old tyre is not perfectly good; it's close to the end of its life, even if it's never turned a wheel. 195/65 R15 will be 2.8% faster rolling than a 205/60 R16, and skinnier in width - 7.68 in rather than 8.07 in. ET (offset) needs investigating, too. Inflation kits are certainly mostly useless. I'd flog the wheel to someone less fussy and get a new spare.- USB C charging
Power to the ports usually needs the engine on. But how the system shuts down is certainly complex and radios (for example) remain powered until the car is exited and locked. A lead with an indicator (like this) will tell you whether it's powered or not. Or use an inline ammeter/voltmeter- Engine sound
Did they take the belt off to assess the true condition of the rollers / pumps? Hard to spot anything except gross errors if the belt is still on - wear may be hidden by the tension of the belt. I'd get them to do that and put a new belt on at the same time - seems like an odd harmonic from the belt / rollers to me.- Luggage Partition Net
My mistake - I am confusing the "boot net programme" with the "partition net". The mount points are probably hidden under your roof lining - be bold and hack holes in it to find them!- Luggage Partition Net
The net programme for the saloon uses the rear seat latch loop on the C pillar for the upper location of the partition and side nets.- faulty brake disc?
- Rear brakes
Holy thread resurrection! Well, she has a 2018 Spaceback now; rear discs weren't wonderful before the MoT in March but passed fine; three months later the outer surface began to delaminate. Along with amusing pinging noises as bits of disc flew off onto the wheel / bodywork. 28K miles. Desperate OE quality discs - Mintex now fitted again. Fronts are OK. And this weekend I get to help a friend with a Fabia with exactly the same wear issue. Fortunately it's a pretty easy job.- Satnav version query
I seem to recall this might be a legacy zip issue if either you are on a FAT32 file system, or an older version of Windows. There used to be a 4GB limit. If the three copies of the mapping zip file you have downloaded are identical you probably have a successful map download. Try downloading and using Peazip ( https://peazip.github.io/ ).- Satnav version query
Whereabouts are you? I bet someone local on this forum would give you a hand if you asked nicely. Updating the nav database is pretty straightforward.- Octavia Mk4 1.5 tsi se manual estate
Lane assist can be quickly turned off, but on every drive. Somebody smarter than me will be along along eventually to show us how we can turn it off and the car remembers the setting. Not much use on bendy narrow UK roads with inconsistent markings. 1. If you're super sensitive, you can detect a little stumble 1/10 times on a cold pull away, once in the first 100 yards. If you grew up juggling manual chokes, this is pretty good. 2. Nothing guaranteed, but if there is a tendency in all the reporting, the early cars off the line seem to have had more problems than later ones. Plenty of owners out there not complaining on forums so the odds are pretty good. SEL good for the following bits; heated front seats, adaptive cruise control, heated adjustable folding mirrors, front and back parking sensors, Columbus 10" display. Chrome window surrounds not so much. But only you know what you like. Offered specs may have changed. 3. No idea.- Octavia mk4 1.5TSI
For a 1.5 TSI manual - not a hybrid - I've a consumption figure over 6000km of 5.6 l / 100km. Measured brim to brim on 98 RON petrol. My usage pattern looks similar to yours, except here 87mph / 140 km/hr will get you into trouble. All the UK cars have a virtual cockpit -navigation in front of you is handy at times. Out of the rest of your list the only essential I can see is the parking sensors - you can't really see the edges of the car. Columbus is a good idea. Apart from that the best feature which may not be available on lower specification models is the adaptive cruise control - big advance over the normal / basic cruise control.- Cruise control won’t turn on
- Anyone available to code a new (AGM) battery in Northampton please?
There is a map of VCDS owners. Unfortunately no-one in Northampton has signed up but MK, Bedford and Kettering all have people who may or may not wish to help. A 5 minute job. https://tinyurl.com/yn6mmtyk- Fan not working
This panel is just in front of your knees, not too obvious, and will require a sharp tug to get the cover off. Fan is 24.- I've been Silly! Fuse help please
This is the fuse panel from a 2018 1.0 SE Tech. I would say your feed needs to plug back in to the bottom row, 2nd position in from the left. If the fuse protecting the car circuit is 7.5A then that's confirmation. This is marked as infotainment screen in the handbook. Who knows if this will fix your issues? Other suspects are 15 (A/C) (2nd from right on lower minifuses), 24 (blower for A/C) (5th from left on right hand middle row between the square fuses), not 31 - (this is also fuel pump so the car won't run). Finally - not impossible the previous owner just stuck it in a switched live socket that worked for him. But that wouldn't explain your other faults.- Front Dash rattle
Glove box lid. Solved with a little bit of sticky backed foam. The weedy plunger springs in the dash are meant to hold the lid down on its catches - but it's all plastic on plastic with no damping or softness, and scope to move L/R / up/down a little. Hence the noise.- Front Dash rattle
xx- Is it worth having a rear wiper on a 2020 Octavia Hatch?
1. No. In my view it's an ugly superfluity. 2. The aerodynamics seem to clean the rear screen pretty well. With or without magic polysiloxanes. 3. I have replaced a number of VAG and other rear wipers over the years. The material selection for the hollow spindle affair used to supply water is always driven by accountants rather than engineers. It breaks. 4. Never had the joy of supply pipe joins failing and slowly filling spare wheel wells with water. after they've saturated the boot carpet. 5. No semicircular scratches on the rear screen from a gritty rear screen wiper. 6. But I wouldn't remove it if it came with one fitted! - Software Update Recall/Campaigns
