Everything posted by Frenchtone
Perspex(?) 'A' Frame Black Cover
An update! The technician who installed the screen and broke the offside 'A' frame cover also damaged the offside front corner of the roof lining and the little plastic 'ticket' clip! Been in contact with French Carglass, visited the local depot today, thechief has asked me to get prices for the pieces and also the installation work for the lining, I hope it all comes to fruition.
Best Skoda ever?
^ I agree with JR, I have had a 'lazy' left eye all my life, never caused me a problem,but, as above, oblique angled right hand junctions need a different strategy, ie last minute approach at 90'!
Thanks for that, it is a late pre FL Adventure model, and yes thats the piece, I suppose it comes with all pieces as shown making up item !
Hi All, Just had the screen replaced and the technician broke, whilst taking off, the black plastic 'A' frame cover. Anyone give me it's Skoda code please? It is the offside one! Thanks in advance!
Exhaust Inspection System dashboard warning light
I had that with a faulty abs sensor, couldn't id the problem then some kind soul suggested it was a possibility, and indeed it was, front o/s. replaced with an expensive Bosch sensor, the cheap ones had different internal resistance readings -- no probs since!
Yeti owner's previous 'cars with character'
Singer Chamois (Imp) with a Paul Emery front end suspension upgrade and half a hundred weight of sand in the front bonnet boot, a great drive, like **** to a blanket!
"Service now ! " message on dash.
Think so!
Think you need to [press the trip reset button and turn on ignition whilst pressing!
Yeti 16 inch wheel trims (covers)
I think the Kopacek ones are -25% until midnight, but I do take your point!! 😉
Try the link, Super skoda/kopacek [email protected]
Yeti lights fault
should have been white not black!!
Yeti lights fault
Could be the switch, I had similar some time ago, took out the swich, opened it up and some of the tracks on the pcb had failed, put some fine wire jump pieces in to bypass the failed section and it worked. try to get a genuine vw switch most are compatible but the backlight might be red not black. Cheapo chinese jobs seem to fail quickly, i think the tracks are not to the same standard as vw ones! good lick
- Yeti 2017 Dash lights on - warnings and fix!
Infotainment head unit issues
Has the car a fuse box in the engine compartment? If so, try removing fuse 8 for a couple of mins -- Think its fuse 8 look at the manual to check! It might work!!
Front windscreen wiper / washer system
Ok, it was caused by the bonnet not being clicked fully home, --- silly me!!! ;-(
Ok, got low washer bottle message this week, just refilled the bottle, tried the wipers / washers, , would not work, looked in the manual for a fuse number, non found, rear washer wiper working fine! Anyone had this problem, what fuse do I check etc?? Help please TIA
Rear lights to DRL's.
^ ^ ^ I enquired years ago for my Yeti, was told back then it could not be done with VCDS / Carista / Obd11, only using the genuine VW kit, can't remember its name though!
- Yeti Diesel Power
Yeti Diesel Power
Mine, a pre FL Adventure 140 has a red I and a red x
ABS speed “ring”
Is your ABS sensor a cheapy, less than £10 if so, I suggest you get a bosch or similar costing around £20, I had similar probs which disappeared when the more expensive sensor was fitted, I thought it was all smoke and mirrors, but apparently not!
Greenline 1.6tdi ride quality impressions
^ ^ Yes they do, had to get one when re registering my Yeti here a la frog!!
Why not talk with your local insurance office for their views?
Badges
Have you tried looking on Ebay? Some dealerships put ads for things on there!
Music through Amundsen
format of sd card, is it fat or ntfs(?),may work trying other formats, my amundsen + was recommended to use fat32!
