Exhaust fumes in car
If it is not there, get one from a scrapyard. One version appears to be available new from Skoda still - 6Y0 823 723 A Not sure if that is the correct one for your car or not, if you tell me the VIN I can check.
Can you post a photo of your engine bay? There is a rubber seal that goes along the top of the 'water box' (the section below the windscreen wipers), and all the way around the engine bay, to seal against the underside of the bonnet. This should keep any leaked exhaust gases from entering the ventilation system inlet (which is inside the water box). This is quite a dangerous situation. If the leak is upstream of the catalytic converter (like at the head/manifold junction) you could be breathing carbon monoxide (CO) which can make you fall asleep and die.
Constant live when IGN is on
Any of #57 - #66 inclusive, where there is a fuse fitted.
Window weather seals
Browse here to find the part numbers of what you require. https://www.lllparts.co.uk/catalogs/skoda/CZ/FAB/697/8 May be able to order from them too.
- Window motor repair service
ULEZ and other similar schemes we are being told are all about clean air for everybody but are they really just a means of making money from motorists?
Is anti Islamophobia really a thing?
oxygen sensor in exhaust
It is a CUNA engine, car was built 24/02/16. Part number of after-cat sensor is 04L 906 262. Is that what was fitted as the replacement? Or aftermarket equivalent? Your oxygen sensor wiring is as shown here G130/Z29 seems like the one you need to focus on. The red wires are both fed by fuse 8 in the engine bay fusebox (10 Amp). The black/white wire going off the top of page will not be relevant.
Wiring Diagram
Within erWin, when logged in:- Go to Individual vehicle info tab, select repair info, then model, then circuit diagrams. There may be more than one huge pdf of circuit diagrams depending on year. When you have paid your 'flat rate' they will have download buttons. Save somewhere safe, then, use ctrl-F within them to find specific functions. Or the index/menu drop down on the left.
Drive shafts ??
Secondhand genuine from ebay. Photo of perceived problem?
Not charging battery
Measure either side of the fuse that connects alternator to battery. First one of the strip fuses above battery, usually.
Mk 2 Scout 2.0 TDI 140 Engine Cooling Radiator - correct size please
Fling your VIN my way and I can tell you which rad part number you have.
o2 sensor bank 1 error code p0030
Hope the mating connector in the loom is OK?
Parts list
@mczakk PM incoming in a minute.
Retrofit Cruise Control
I'm seeing signs of availability (on partslink24) on kits suited to Roomies built on or after 28/05/2012, is the one you're looking at a 12-reg or 62? If the latter there's a decent chance it was built after that date. Sorry, but cross-checking those part numbers against what's on offer at LLL parts suggests they're gone too. ☹️ Have you @Rheumy got an image of the connector involved? May well be able to still buy that?
Hmm, how many connectors, pins, wires...?
It will have the combined unit; I think March 2010 saw the last of the separate central convenience control units in Roomsters. @Tech1e almost certainly knows the answers to your other queries. If you message me the VIN I could look up which BCM part number it has, if that's any help.
Need to know engine code as well if you would like me to try to look up wiring info. A quick glance at a guessed CUNA engine circuit suggests there are two oxygen sensors, which surprised me, and possibly the garage that may have replaced the wrong one?
Parts list
@mczakk were you able to navigate the parts catalogue link I supplied?
P0170
Follow the hard plastic pipe from the brake servo (behind brake fluid tank) towards the engine. At each point where it connects to the one-way valve, look and feel with finger tips all around it for cracks. If there is another connection of hard pipe nearer the engine, check there also.
P0170
Manual or automatic gearbox?
P0170
Can be because of a brake servo vacuum hose that has developed cracks and is leaking air. Which engine size does your car have?
Parts list
https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT
Explanation for Fuse-Relay box configuration
Breezy_Pete replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanSome of these things that look like just relays contain circuit boards which make them 'control units' rather than just simple relays. Usually the outer cover can be unclipped to reveal these extra components.
Radiator fans on constantly - even with ignition off, cold engine.
No need, the number you suggested is correct.
