Warning lights issue
Yeah, that battery sounds like it's very end of life, unless you have a significant current drain.
Coolant Fan Control 2: P1662 - 35-00 - Short to ground (VCDS Fault Code)
@makymak I'm very happy to look up the correct module part number for your car if you wish. Just need VIN.
EPC warning light?
And believing the dealer when they say they couldn't see any stored codes is perhaps a little over-trusting.
EPC warning light?
OK but if you can provoke it by driving behaviour, you can potentially read the code while it's lit?
Phil69
Welcome to the forum Phil. I'm afraid I can't advise you on purchasing a Superb or cars in general, but I think there are lots of happy owners on here who may be more use. Hope you get some more input.. Pete
EPC warning light?
Anyhow, to the problem. Find a local VCDS user who may be willing to scan the car for you to see why the EPC light is being lit? A generic OBD reader may have failed to pick up the stored info.
EPC warning light?
Actually I suspect the software guys have done exactly what they've been asked to do. But I guess that doesn't really contradict what you've just said.
EPC warning light?
Only if the programmers wrote the software in the radio and engine ECU in such a way that it allows this to happen.
EPC warning light?
The CAN bus just sends the messages. The controllers are what tells you about the message contents. It's like you're trying to blame the phone line for someone telling you bad news.
EPC warning light?
CAN is just a communication network, CAN Bus Explained - A Simple Intro [2023] – CSS Electronics You guys seem to be trying shoot the messenger. How the data conveyed by the bus is used seems to be the problem you think there is.
Real World Fuel economy - 1.0TSI vs 1.6TDI
You may also be better off just looking at comparative figures on spritmonitor.de where there tends to be large datasets of crowd-sourced brim-to-brim records.
best place to get genuine skoda replacement parts ?
This is a handy catalogue and vendor of genuine bits at decent prices. Catalogue is not 100% up to date, but better than many of the online ones you may find. Car Parts Catalog - LLLParts
Message me with the VIN of the car please @kareems, and I can check which part number it should have.
Where is the air intake located on a 2021 Octavia estate 1.5 TSI?
See if you can locate these items on your car: Car Parts Catalog - LLLParts
Switch off cigarette ligther 12v when car closed
Yeti appears to have a quite different fuse panel.
I suspect the situation is the same as described here, with your car having the wires/fuse sockets in the necessary positions 'halfway down' Fuse 40: https://www.briskoda.net/forums/topic/520005-👋-how-to-cut-power-to-the-cigarette-lighter-when-the-car-turns-off/?do=findComment&comment=5815406
OBD2 problem
Check cabin fuse 3 (5 Amp), especially if the car doesn't have A/C.
Skoda Fabia abs pump problems
Cheap and easy fix, fortunately. Your red/green wire may possibly go to a different position (No. 4, I think) than in the video, but hopefully you'll see the same crack problem at its location. Halfords have a selection kit that includes the correct 40 Amp one: https://www.halfords.com/motoring/tools/fuses-electricals-and-fixings/fuses/halfords-assorted-oto-strip-fuses-30>60-amp-fuse133-705310.html
👋 How to cut power to the cigarette lighter when the car turns off?
Fit a relay in series with the feed wire to it, with relay coil powered by an ignition switched 12V.
Fuel pump relay
Ta, so check engine bay fuse no. 14 (10 Amp), which supplies the coil of that relay amongst other things. Then cabin fuse no.49 (25 amp) which is power that the relay switches to the fuel pump. If both of those are OK it may be that the engine ECU isn't grounding the other side of the relay coil 'cos it's unhappy with something.
Fuel pump relay
I'll pop back to the circuits for a look-see. Engine code would be handy.
Fuel pump relay
1.9 SDI timing VCDS?
Interesting, thanks for posting. I see from the few other posts by @poloSDI that he/she had a 2006 Polo (for example this one), so if this thread relates to that car you were right, ASY! 😁 A good example of why it's always a good idea to tell the world exactly what car/engine code you are trying to work with when asking for help.
Skoda fabia mk2 gateway modul (location and issues)
J533 shown like this on the relevant circuit for your build date (12 Oct 2010). J519 is the Onboard supply control unit/vehicle voltage control unit. In some of the later versions it is shown as a separate unit, presumably what your images above show.
Yes, that's why I said it. 😁 If you let me know the VIN of the car, I can find out the date of manufacture and be more certain.
