Breezy_Pete
Sponsor
Joined
Last visited
Currently
Viewing Topic: Every day’s a school day!!
Individual handbrake cable adjustment
No drums on a vRS @VWD.
All cylinder misfires and sensor fault codes
Is one of the hvac codes G65 low pressure? If so that may explain why AC isn't triggering fan action, just not getting the high side pressure up sufficiently to trigger it. I wonder if you've got some wiring damage that's affecting the positive feed to the coilpacks at high temps? The oxygen sensor heater fault may point to a bust wire at the interconnect down on that bracket in front of the gearbox. Is it an AZQ engine code or a BME?
- All cylinder misfires and sensor fault codes
Have you looked at the brake servo vacuum hose at all? They tend to crack and leak at the joints of the hard plastic sections, and the plastic will be softer when hot, so more likely to open up. I would think this is more likely the cause of your misfires than the temperature. Two radiator fans or just one? The thermoswitch is a common source of leakage, and can generally be fixed by just tightening a little, 29mm spanner or deep socket. If you take the connector off to get a socket on, may as well bridge some pins of the loom connector whilst there to test each speed. I'll find a helpful photo shortly showing which pins to short. Ignition needs to be switched on to check full speed, but not the low speed.- All cylinder misfires and sensor fault codes
Does the temperature gauge ever go above halfway? Did your fuse check include blade fuses 8 and 11under the cover to the right of the strip fuses on the battery holder?- Brake light circuit current sensor.
LED lamps may well be even less reliable.- Skoda felicia radiator fan !HELP NEEDED!
Breezy_Pete replied to a post in a topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanMaybe the coolant flow is low for some reason?- Skoda felicia radiator fan !HELP NEEDED!
Breezy_Pete replied to a post in a topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanThe coolant temperature may be 100 at the engine, but with ambient temperatures low at this time of year, will probably be a lot lower at the thermoswitch. An IR thermometer pointed at radiator fins close to the thermoswitch may give clues about whether this hypothesis is correct/not.- First breakdown in 12 years.
A thread here where the OP eventually told us that some injector cleaner fixed his red-hotness:- Intermittent electronics error fault, when cold. Engine runs fine.
I wasjust hoping you might find something that could explain the bad behaviour. Of course there may well not be anything visibly broken. A bad solder joint might be seen, maybe with magnification. PM me anything showing the circuit board, if you get in there for a look, please. 🙂- Intermittent electronics error fault, when cold. Engine runs fine.
I hope you will still do a post mortem on your old BCM ?- P0171 Help
Yep. No sense in replacing it if the readings are good.- Electric windows not working
If both of the windows don't open when the key is held in the unlock position (with door previously shut and locked) I'd say you may well need a repair to the driver's side motor module. Pop round with door card off and try a known good one 🙂- Fabia mk1 1.2L HTP 64hp, turns over but wont start. Fuel pump issue?
Yes, very little charge in that, get a charger on it.- P0171 Help
Look what it's reading in engine ECU measuring blocks when engine is at ambient and operating temperature.- Fabia mk1 1.2L HTP 64hp, turns over but wont start. Fuel pump issue?
Just a couple of ideas I had. Does your courtesy light come on when driver's door is opened?- Fabia mk1 1.2L HTP 64hp, turns over but wont start. Fuel pump issue?
Fuse 14 is associated with ECU relay for your engine.- Fabia mk1 1.2L HTP 64hp, turns over but wont start. Fuel pump issue?
If only 4 volts is getting to the pump it probably won't work, but there are two different relays that supply this voltage at different times, one when driver's door is first opened, the other when engine ECU tells it to. Seems unlikely both have a problem. Please check the two fuses I've mentioned.- Fabia mk1 1.2L HTP 64hp, turns over but wont start. Fuel pump issue?
Do you hear the fuel pump run as you open the driver's door, after unlocking the car from outside at least half an hour since last used?- Fabia mk1 1.2L HTP 64hp, turns over but wont start. Fuel pump issue?
Fuel pumps rarely give trouble.- Fabia mk1 1.2L HTP 64hp, turns over but wont start. Fuel pump issue?
See if fuse 52 is blown. Check fuse 14 too. Diagram attached: Mk1 Fabia Cabin Fuses.pdf- Once again, a fuse question
The fuse will stay powered. 👍- Once again, a fuse question
The radio may well have a permanent feed to it, but be switched off (and on) by CAN communication. Many electronic modules are like this.- Once again, a fuse question
@rdemirel, I guess you're referring to your Karoq, rather than a Citigo, in which case you'd be better off in the model-specific forum for that car.- Once again, a fuse question
This was from August 2011, there's another list from May 2013, but I expect there's a lot of overlap. Ones that are unused on any given car may not have a terminal in both sides of the fuse socket, and if so won't work. - All cylinder misfires and sensor fault codes
