No heating
You never answered my question on 27th December about whether this is a car with a DSG gearbox. Is it, or is it manual?
Which size (guage) and amp rating wire is this?
Brown wire is chassis earth, so no voltage is what you should expect.
Passenger side electric window- switch or wiring issue?
I don't think vcds will have any visibility of these modules. Bellows wiring breaks are extremely common in the mk2 Fabia, start with visual inspection on both sides.
Front caliper slider pins
Fair enough, but he probably just needs one M8 bolt of the right length.
@Carlston that autodoc kit looks completely wrong judging by the picture. Wouldn't trust it at all. And you gave him all the part numbers I had already, except the bolts he actually needed. But still better than sep's effort. 😛
Windscreen washer nozzles: adjustable or not?!
If you do opt for replacement, remove old one(s) then run the pump for a sec before fitting new, in case there's any bits of debris loitering in the last bit of the pipework.
That diagram is just showing how to remove them, not an adjustment. In my experience replacement every few years is worthwhile. Should only be a few quid each, e.g. Skoda Water Jet 5J0955985 - LLLParts
239mm set-up shown here: floating caliper brake; brake caliper housing; bra... - Fabia(FAB) [EUROPA 2006 year] (7zap.com) Two different length Allen-head (6mm tool) bolts going through two different length stainless tubes, no rubber/plastic closure caps on this version, unfortunately. Part numbers for all the bits including pads shown there.
Changing drivers door (electrics)
The car won't have any of the wiring to work window or lock, I think.
middle silencer
45mm/1.75". You should learn to work these parts catalogues mate, it's not that hard. Just look at the coupling pieces ("dual clip") for the relevant engine code: exhausty bits for a 2001 fabia
Starter solenoid
Did you try this?
- Window motor repair service
Cruise control wiring loom
Yes, it could go to te fusebox, but I found it easier just to splice it into the appropriate wire at the brake switch connector. The other wire can go direct to the correct engine ECU pin, but won't be long enough as supplied, cos it'll only be intended to reach to the inside bulkhead connector. Nothing to stop you extending it though.
1.2 TSi Oil level light on after new sensor fitted
Check cabin fuse 3 is intact first, it should be a 7.5A rated one; then with ignition on, measure between pins 1 (black/yellow wire) and 2 (brown wire) of the sensor connector hoping to see 12V. That, if seen, confirms that 2 of the 3 wires are intact. The third one from pin 3 ends up at the instrument cluster, pin 11 of the 32-way connector there.
Do you have access to a multimeter?
Mk 1 HTP 1.2 12V Rough idling
The splits usually can be found in the areas where the hard plastic pipe attaches to other things like the non-return valve. Areas marked in pink, feel all the way round them with fingertips as well as checking visually.
Fuel Pump Primary Circuit Malfunction
@wodgey The wire from the fuel pump relay (position 4 in the relay holder) to the engine ECU starts at a contact labelled 4 or 86 under the relay, and goes via an inaccessible connector deep behind the dash to pin number 80 of the 81-way connector at the engine ECU. The wire is blue with red stripe all the way. Here's a view of what I guess is the mating face of the ECU connector in question, with pin 80 marked in red:
Power Steering Dangerous? Electrical? (thank you) • Skoda Fabia Mk II 2011
Perfect, just the CBZ was needed, thanks. There's apparently a four-way connector pair 'front left of engine compartment', through which this wire passes, so that's probably the next place to look after ensuring that the alternator connector is fully 'home'/clicked into engagement. The other wire from the alternator connector also goes to this four-way, along with two wires from the control solenoid of the aircon compressor, below the alternator. From that four way interconnect it's continuous all the way into the control unit in the cabin from which it starts. Left in the description of location is left as viewed sitting in the driver's seat facing forward, so right as you look into the engine bay from in front of the car. I haven't spotted such a connector in the photos above, it may be that you need to look from under the car to see it, possibly.
Air recirculation timer?
A fault, I think. The recirculation motor/potentiometer modules are renowned for failing on pretty much every mk1.
VW group fasteners, mostly plastic; images and part numbers
Seen first on clubgti.com, seemed too handy not to propagate further: https://www.yumpu.com/en/document/read/38656239/audi-vw-renoks/5 Could be handy if you break one, and want to replace, but can't see a part number on it.
It's the one going to that alternator connector, so follow that back wherever it goes. If you can tell me your engine code I may be able to find some info about intermediate connectors it may pass through, using the wiring diagrams.
Skoda Octavia 61 plate 1.4 Tsi low oil pressure warning light
Dunno on your engine, often in front right or rear left corner of engine head, but not always. Generally the only single-wire electrical plug to be found. If you can tell me your engine code (letters ahead of engine number on V5c) I may be able to find the location out (usually just by scrutinising images in ebay listings of that engine code).
Mk1 vrs back box
Different pipe ODs. vRS is 55mm, other diesel engines (and 2.0 petrol) 50mm; other petrol engines are either 45mm or 38mm. Adaptor pieces could be used instead of the usual parallel dual-sleeve connections though, to adapt diameters.
Washer motor not running
Oh, I'm mildly surprised. I fixed a Golf with same problem yesterday by changing the equivalent fuse, which by coincidence was top right, after I started checking them from bottom left... 😆
